Visitor bercik1314
Setting GPIO values (PS-PL EMIO) from userspace linux don't work if SPI (EMIO) enabled
Hi Dear,
I have the question about ZedBoard. I have a linux on it and SPI enabled (PS - master, PL - slave). I sending data from PL to PS and it works fine, but if any interface in EMIO is enabled (e.g. SPI or UART) I cannot set GPIO values from userspace linux. I can export GPIO by putting: "echo 960 > /sys/class/gpio/export", then I can set it as output: "echo out > /sys/class/gpio/gpio960/direction", but if I would like to set value to '1': "echo 1 > /sys/class/gpio/gpio960/value", it cannot set. There is no error, but if I put: "cat /sys/class/gpio/gpio960/value" in output I get '0'.
If I disable SPI in EMIO, GPIO works fine - I can set values. Can anyone help me? I will be grateful for your help. Thanks!
--Robert
Visitor bercik1314
Re: Setting GPIO values (PS-PL EMIO) from userspace linux don't work if SPI (EMIO) enabled
I found the solution. In / sys / class / gpio / gpio960 / value there is a value GPIO as input, not output. So, If i change this value to '1' in this file will be 0, but it will be 1 in the physical output. Thanks for suggestions.
-- Robert
what is the SPI connected to in the PL?
Visitor bercik1314
Thanks for reply.
I created IP block (SPI slave) in PL side that is connected to the another IP block that increment integer value. This value is send to PS via SPI. I noticed situations when GPIO works fine but SPI don't work. If one of it works fine, second don't. Exists any solution of this problem? Thanks!
Robert,
If you want to control the pins with GPIO then you will need to switch the function. Look in the Zynq 7000 TRM ug585. Section B.28 System Level Control Registers. Find the register for each pin you want to control from GPIO (MIO_PIN_xx) and switch it to GPIO (from SPI in your case) As a hack you can use the devmem. Has an example switch serial port to GPIO control
#enable GPIO clock
devmem 0xF800012C 32 0xD50445
#switch MIO 46, 47 to GPIO
devmem 0xF80007B8 32 0x1400
devmem 0xF80007BC 32 0x1400
Visitor bercik1314
-- Robert
