Participant guru@ignitarium
Setting Up a Desktop Environment on Zynq Ultrascale + MPSoC for ZCU104
Can please suggest the different ways to set up Graphical User Interface (GUI) for petalinux 2018.2 on ZCU104 Evaluation Kit board.
I have tried to configure the rootfs package using (petalinux-config -c rootfs) command to make changes. By configuring XFCE package, OpenCV package. After configuration i have built the petalinux using the command (petalinux-build). Successfully the packages is built. The BOOT.BIN and image.ub are transferred to sd_card. Once the sd_card is booted the following output are shown below.
Welcome to minicom 2.7
OPTIONS: I18n
Compiled on Feb  7 2016, 13:37:27.
Port /dev/ttyUSB1, 20:47:26
Press CTRL-A Z for help on special keys
................... TIMEOUT !
Hit any key to stop autoboot:  0
Device: sdhci@ff170000
Manufacturer ID: 3
OEM: 5344
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 14.8 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading image.ub
368284084 bytes read in 23983 ms (14.6 MiB/s)
  Using 'conf@system-top.dtb' configuration
  Trying 'kernel@1' kernel subimage
    Description:  Linux kernel
    Type:         Kernel Image
    Compression:  gzip compressed
    Data Start:   0x10000108
    Data Size:    6977074 Bytes = 6.7 MiB
    Architecture: AArch64
    OS:           Linux
    Load Address: 0x00080000
    Entry Point:  0x00080000
    Hash algo:    sha1
    Hash value:   bb93d5902bde343543ee37e138210059a9d55f08
## Loading ramdisk from FIT Image at 10000000 ...
  Trying 'ramdisk@1' ramdisk subimage
    Description:  petalinux-user-image
    Type:         RAMDisk Image
    Data Start:   0x106b09fc
    Data Size:    361267752 Bytes = 344.5 MiB
    OS:           Linux
    Load Address: unavailable
    Entry Point:  unavailable
    Hash algo:    sha1
    Hash value:   f0072d04f6664606448ed02a191f54aefa50bee0
  Trying 'fdt@system-top.dtb' fdt subimage
    Description:  Flattened Device Tree blob
    Type:         Flat Device Tree
    Compression:  uncompressed
    Data Start:   0x106a7840
    Data Size:    37110 Bytes = 36.2 KiB
    Hash algo:    sha1
    Hash value:   987e376db6912a65b0115cf38fecafdf02bb1643
  Booting using the fdt blob at 0x106a7840
  Uncompressing Kernel Image ... OK
  Loading Ramdisk to fffffffff2777000, end 07fff228 ... "Synchronous Abort" ha4
ELR:     10102270
LR:      100a0b60
x0 : 0000000000000028 x1 : 00000000106b09fc
x2 : 0000000015888228 x3 : 000000000d888fff
x4 : 00000000106b09fc x5 : 0000000000000038
x6 : 000000007fe61e10 x7 : fffffffff2777000
x8 : 000000007dd94480 x9 : 0000000000000008
x10: 00000000ffffffd8 x11: 000000007ff00000
x12: 000000007fe9e048 x13: 000000007dd93600
x14: fffffffff2777000 x15: 0000000000000008
x16: 0000000000000002 x17: 0000000007fff228
x18: 000000007dd94df8 x19: 0000000015888228
x20: 0000000008000000 x21: 00000000106b09fc
x22: 000000007fe9dfa8 x23: 000000007fe9df80
x24: 000000007fe9df78 x25: 0000000010000108
x26: 0000000000000001 x27: 0000000000000000
x28: 0000000000080000 x29: 000000007dd945c0
Resetting CPU ...
resetting ...
Xilinx Zynq MP First Stage Boot Loader
Release 2018.2   Sep 18 2018 - 17:42:08
How to resolve this Loading Ramdisk Error....
