pierlum
Voyager
Voyager
Share folder petalinux on local network
is there a way to share a folder of petalinux running on zcu106 on my local network? For example installing in petalinux NFS or samba?
Thank you very much
shabbirk
Hi @pierlum
Yes you can configure NFS boot in petalinux. Refer to page 60 of below ug1144
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug1144-petalinux-tools-reference-guide.pdf
pierlum
Voyager
Voyager
Hi @shabbirk ,
thanks for the help. If I only wanted to share a petalinux folder on my local network is there a way to do this?
watari
Hi @pierlum
You can choose your best way from the followings.
1. NFS server
I suggest you to use "NFS server", if you want to share your folder as MPSoC is server.
2. NFS client
I suggest you to use "NFS client", if you already have NFS server.
3. Samba
I suggest you to use "Samba", if your client PC is Windows.
Best regards,
ericzerbib
in my case I use sshfs but it's doesn't work with dropbear ssh I have set in my petalinux openssh and it works pretty well
sshfs root@192.168.0.10:/ /mnt/petalinux -o allow_other
