Source code of Petalinux kernel
I understand Petalinux is a free software.  If so , is the source code of the kernel also available?
Where can I see the source code of the kernel?
Re: Source code of Petalinux kernel
Check this link
--Hem
Note sure which petalinux SDK version your are reffering?
My answer  assume you are using latest release petalinux 2013.10.
bash> cd $PETALINUX/components/linux-kernel
This is default linux kernel (3.8) shipped with Petalinux 2013.10
Happy browsing!!!!
Please refer this link for  further documentation.
http://xgoogle.xilinx.com/search?getfields=*&numgm=5&filter=0&proxystylesheet=support&client=support&site=Answers_Docs_Forums&getfields=*&ie=UTF-8&num=200&oe=UTF-8&output=xml_no_dtd&requiredfields=-Archived:true&show_dynamic_navigation=1&sort=date:D:...
Check this link
--Hem
Scholar helmutforren
@htsvn , I need to see the source for the PetaLinux 2012.12 scripts and executables, the ones that are named "petalinux-*".  The github link you provided indeed has the source for the 2012.12 kernel, but that doesn't include the source that I am looking for.  Do you know where the remainder of the source might be?
The petalinux tools are not open source.  I'm not really sure why it is not but this is why I wrote my own configuration and build scripts instead of using petalinux
jeff
