troykay
Sourcing Petalinux 2019.2 settings.sh on Ubuntu 18.04.1 error: environment: line 301: ((: 10#29b: value too great for base (error token is "10#29b")
This seems to be an [occasionally] common enough question, but I can't find an answer that fixes the annoyance.
I'm getting an error when sourcing the Petalinux 2019.2 settings.sh file:
tkay@ub180401:~$ source /opt/Xilinx/Petalinux/2019.2/settings.sh
PetaLinux environment set to '/opt/Xilinx/Petalinux/2019.2'
INFO: Checking free disk space
INFO: Checking installed tools
environment: line 305: ((: 10#29b: value too great for base (error token is "10#29b")
INFO: Checking installed development libraries
INFO: Checking network and other services
WARNING: No tftp server found - please refer to "PetaLinux SDK Installation Guide" for its impact and solution
I'm running a supported release of Ubuntu (18.04.1) for PetaLinux 2019.2:
tkay@ub180401:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 18.04.1 LTS
Release: 18.04
Codename: bionic
The default shell is bash.  I've reconfigured dash to make sure it was set to 'no':
tkay@ub180401:~$ ls -altr /bin/sh
lrwxrwxrwx 1 root root 4 Mar 11 14:10 /bin/sh -> bash
All of my locales are en_US.utf8:
tkay@ub180401:~$ cat /etc/default/locale
LANG=en_US.utf8
tkay@ub180401:~$ locale
LANG=en_US.utf8
LANGUAGE=en_US.utf8
LC_CTYPE="en_US.utf8"
LC_NUMERIC="en_US.utf8"
LC_TIME="en_US.utf8"
LC_COLLATE="en_US.utf8"
LC_MONETARY="en_US.utf8"
LC_MESSAGES="en_US.utf8"
LC_PAPER="en_US.utf8"
LC_NAME="en_US.utf8"
LC_ADDRESS="en_US.utf8"
LC_TELEPHONE="en_US.utf8"
LC_MEASUREMENT="en_US.utf8"
LC_IDENTIFICATION="en_US.utf8"
LC_ALL=en_US.utf8
It's not a file I can troubleshoot or edit:
tkay@ub180401:~$ file /opt/Xilinx/Petalinux/2019.2/tools/common/petalinux/utils/petalinux-env-check
/opt/Xilinx/Petalinux/2019.2/tools/common/petalinux/utils/petalinux-env-check: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, for GNU/Linux 2.6.32, BuildID[sha1]=77aca9945d2ed01b4c9aad29fb7a1d123ad09441, stripped
All of its libraries seem to be present and accounted for:
tkay@ub180401:~$ ldd /opt/Xilinx/Petalinux/2019.2/tools/common/petalinux/utils/petalinux-env-check
linux-vdso.so.1 (0x00007fff085fb000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f5a8f3b9000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f5a8efc8000)
/lib64/ld-linux-x86-64.so.2 (0x00007f5a8f5bd000)
Running the application outside the settings.sh environment shows:
tkay@ub180401:~$ /opt/Xilinx/Petalinux/2019.2/tools/common/petalinux/utils/petalinux-env-check
tr: extra operand ‘v’
Only one string may be given when deleting without squeezing repeats.
Try 'tr --help' for more information.
ERROR: You have tools that don't meet the version requirements:
-Detected make version is less than the expected 3.81
-Detected tar version is less than the expected 1.24
Please install them with your operating system package manager, and try again
Neither make nor tar are less than the expected value:
tkay@ub180401:~$ make --version
GNU Make 4.1
[snip]
tkay@ub180401:~$ tar --version
tar (GNU tar) 1.29
[snip]
It doesn't seem to actually affect the outcome of the script.  Thoughts?
