eliezer
Sourcing Petalinux 2020.1 results in bus errors and wipes my PATH
I successfully built a project in Petalinux 2020.1 for the first time yesterday. Obviously I had no issues sourcing Petalinux then.
But now whenever I try to source Petalinux 2020.1, I see this:
$ source ~/2020.1/settings.sh
Bus error (core dumped)
-bash: sed: No such file or directory
PetaLinux environment set to '/home/emiron/2020.1'
-bash: grep: No such file or directory
WARNING: /bin/sh is not bash!
bash is PetaLinux recommended shell. Please set your default shell to bash.
WARNING: /bin/bash is not bash!
/bin/bash is Petalinux recommended SHELL variable. Please set your SHELL variable to /bin/bash.
/home/emiron/2020.1/tools/common/petalinux//utils/petalinux-env-check: line 466: basename: command not found
After which, all my commands are broken because $PATH is completely empty.
Running Ubuntu 16.04.6.
ibaie
Hi @eliezer
As you can see in the error messages it seems that your default shell is not Bash and Petalinux requires bash as shell. This is already documented in the UG1144
PetaLinux tools require that your host system /bin/sh is 'bash'. If you are using Ubuntudistribution and your /bin/sh is 'dash', consult your system administrator to change yourdefault system shell /bin/sh with the sudo dpkg-reconfigure dash command.
Ibai
ibaie
Hi @eliezer
Ibai
eliezer
That was it. I had set it to bash previously. Strangely, when I logged back in to my computer, the shell was BASH, and I didn't have this issue any more.
