Specify RAM size to store data while running Linux
Accepted Solution Solved
Accepted Solution
I'm trying to store data in RAM while running Linux. I cannot figure out how to specify the OS that it can only use the half memory.
I already try to change to modify the "memory" field in the device tree, to add a uEnv.txt size to alter the boot procedure, to modify the zynq_zed.h file.
Maybe I'd need to configure the u-boot or the FSBL compilation, but I didn't find out how to do it.
Can someone give me a clue?
Already, thank you
Re: Specify RAM size to store data while running Linux
@crochetx you can look at the following thread to see how you can modify the device-tree to add a memory reserve section for your needs. Basically you need to do this:
reserved-memory {
  #address-cells = <1>;
  #size-cells = <1>;
  ranges;
  vin_reserved: vin@0x10000000 {
    reg = <0x10000000 0x40000>;
https://forums.xilinx.com/t5/Embedded-Linux/Zynq-Petalinux-reserve-a-DDR-memory-region/td-p/529237/page/2
All Replies
reserved-memory {
  #size-cells = <1>;
  ranges;
Thank you Muzzafer, now it works.
Thus the solution is :
  add the new field 'reserved-memory' in the device tree.
  'reg' specifies the address of the beginning of the reserved memory and its length.
Thank you
