Stuck at starting kernel...
I know this is a really noob-like question.
But yes indeed my kernel hangs at starting kernel... This happend suddenly cause before it was working then i made my rootfs size bigger and it stopped.
My partitions
Name         ADDR    SIZE
BOOT.BIN 0x0  0x600000
uImage 0x620000 0x400000
system.dtb 0x1020000 0x50000
uramdisk.image.gz 0x1070000 0x2000000
POC.bit 0x3070000 0x200000
To clarify; the POC.bit is my bitstream. I cheated this in in the QSPIboot configuration in zynq-common.h in u-boot-xlnx to fpga loadb it into the system. Back then this worked cause when I would add it into the BOOT.BIN it wouldn't work so this was my work-around.
Now when I updated to this partitions, WITH THE SAME FILES, it stopped working and also the fpga loadb did not work anymore. I don´t think (yes i'm sorry i think, a lot happened in the meanwhile.) I changed any configurations.
Also to say the filesystem is made with buildroot but this has never given any problems.
I will include my zynq-zc702.dts, if you guys need anything else just ask me :) I hope someone knows why this is happening. Also I did first look in 100 posts to find my solution but also because I had this once before and then I actually did find the answer there I find this one so strange.
The last thing is that I know my partitions are wrong but that is because I modified zynq-common.h to work. I also included that file, I changed the qspiboot= part and also the addresses and sizes of the different components.
Greetings,
Senkoo
Here is the device tree, it kept giving errors.
// SPDX-License-Identifier: GPL-2.0+
 *  Copyright (C) 2011 - 2015 Xilinx
 *  Copyright (C) 2012 National Instruments Corp.
/dts-v1/;
/include/ "zynq-7000.dtsi"
	model = "Zynq ZC702 Development Board";
	compatible = "xlnx,zynq-zc702", "xlnx,zynq-7000";
	aliases {
		ethernet0 = &gem0;
		i2c0 = &i2c0;
		serial0 = &uart1;
		spi0 = &qspi;
		mmc0 = &sdhci0;
		usb0 = &usb0;
	memory@0 {
		device_type = "memory";
		reg = <0x0 0x40000000>;
	chosen {
		bootargs = "console=ttyPS0,115200 root/dev/ram rw earlyprintk clk_ignore_unused";
		linux,stdout-path = "serial0:115200n8";
	gpio-keys {
		compatible = "gpio-keys";
		autorepeat;
		sw14 {
			label = "sw14";
			gpios = <&gpio0 12 0>;
			linux,code = <108>; /* down */
			wakeup-source;
			autorepeat;
		sw13 {
			label = "sw13";
			gpios = <&gpio0 14 0>;
			linux,code = <103>; /* up */
			wakeup-source;
			autorepeat;
	leds {
		compatible = "gpio-leds";
		ds23 {
			label = "ds23";
			gpios = <&gpio0 10 0>;
			linux,default-trigger = "heartbeat";
	usb_phy0: phy0@e0002000 {
		compatible = "ulpi-phy";
		#phy-cells = <0>;
		reg = <0xe0002000 0x1000>;
		view-port = <0x0170>;
		drv-vbus;
&amba {
	ocm: sram@fffc0000 {
		compatible = "mmio-sram";
		reg = <0xfffc0000 0x10000>;
&can0 {
	status = "okay";
	pinctrl-names = "default";
	pinctrl-0 = <&pinctrl_can0_default>;
&clkc {
	ps-clk-frequency = <33333333>;
&gem0 {
	status = "okay";
	phy-mode ="moca";
	pinctrl-0 = <&pinctrl_gem0_default>;
	phy-reset-gpio = <&gpio0 11 0>;
	phy-reset-active-low;
	fixed-link {
		speed = <1000>;
		full-duplex;
&gpio0 {
	pinctrl-0 = <&pinctrl_gpio0_default>;
&i2c0 {
	status = "okay";
	clock-frequency = <400000>;
	pinctrl-names = "default", "gpio";
	pinctrl-0 = <&pinctrl_i2c0_default>;
	pinctrl-1 = <&pinctrl_i2c0_gpio>;
	scl-gpios = <&gpio0 50 0>;
	sda-gpios = <&gpio0 51 0>;
	i2c-mux@74 {
		compatible = "nxp,pca9548";
		#address-cells = <1>;
		#size-cells = <0>;
		reg = <0x74>;
		i2c@0 {
			#size-cells = <0>;
			reg = <0>;
			si570: clock-generator@5d {
				#clock-cells = <0>;
				compatible = "silabs,si570";
				temperature-stability = <50>;
				reg = <0x5d>;
				factory-fout = <156250000>;
				clock-frequency = <148500000>;
		i2c@1 {
			#size-cells = <0>;
			reg = <1>;
			adv7511: hdmi-tx@39 {
				compatible = "adi,adv7511";
				reg = <0x39>;
				adi,input-depth = <8>;
				adi,input-colorspace = "yuv422";
				adi,input-clock = "1x";
				adi,input-style = <3>;
				adi,input-justification = "right";
		i2c@2 {
			#size-cells = <0>;
			reg = <2>;
			eeprom@54 {
				compatible = "atmel,24c08";
				reg = <0x54>;
		i2c@3 {
			#size-cells = <0>;
			reg = <3>;
			gpio@21 {
				compatible = "ti,tca6416";
				reg = <0x21>;
				gpio-controller;
				#gpio-cells = <2>;
		i2c@4 {
			#size-cells = <0>;
			reg = <4>;
			rtc@51 {
				compatible = "nxp,pcf8563";
				reg = <0x51>;
		i2c@7 {
			#size-cells = <0>;
			reg = <7>;
			hwmon@52 {
				compatible = "ti,ucd9248";
				reg = <52>;
			hwmon@53 {
				reg = <53>;
			hwmon@54 {
				reg = <54>;
&pinctrl0 {
	pinctrl_can0_default: can0-default {
		mux {
			function = "can0";
			groups = "can0_9_grp";
		conf {
			slew-rate = <0>;
			io-standard = <1>;
		conf-rx {
			pins = "MIO46";
			bias-high-impedance;
		conf-tx {
			pins = "MIO47";
			bias-disable;
	pinctrl_gem0_default: gem0-default {
		mux {
			function = "ethernet0";
			groups = "ethernet0_0_grp";
		conf {
			slew-rate = <0>;
			io-standard = <4>;
		conf-rx {
			pins = "MIO22", "MIO23", "MIO24", "MIO25", "MIO26", "MIO27";
			low-power-disable;
		conf-tx {
			pins = "MIO16", "MIO17", "MIO18", "MIO19", "MIO20", "MIO21";
			bias-disable;
			low-power-enable;
		mux-mdio {
			function = "mdio0";
			groups = "mdio0_0_grp";
		conf-mdio {
			slew-rate = <0>;
			io-standard = <1>;
			bias-disable;
	pinctrl_gpio0_default: gpio0-default {
		mux {
			function = "gpio0";
			groups = "gpio0_7_grp", "gpio0_8_grp", "gpio0_9_grp",
				 "gpio0_10_grp", "gpio0_11_grp", "gpio0_12_grp",
				 "gpio0_13_grp", "gpio0_14_grp";
		conf {
			slew-rate = <0>;
			io-standard = <1>;
		conf-pull-up {
			pins = "MIO9", "MIO10", "MIO11", "MIO12", "MIO13", "MIO14";
			bias-pull-up;
		conf-pull-none {
			pins = "MIO7", "MIO8";
			bias-disable;
	pinctrl_i2c0_default: i2c0-default {
		mux {
			groups = "i2c0_10_grp";
			function = "i2c0";
		conf {
			bias-pull-up;
			slew-rate = <0>;
			io-standard = <1>;
	pinctrl_i2c0_gpio: i2c0-gpio {
		mux {
			groups = "gpio0_50_grp", "gpio0_51_grp";
			function = "gpio0";
		conf {
			slew-rate = <0>;
			io-standard = <1>;
	pinctrl_sdhci0_default: sdhci0-default {
		mux {
			groups = "sdio0_2_grp";
			function = "sdio0";
		conf {
			slew-rate = <0>;
			io-standard = <1>;
			bias-disable;
		mux-cd {
			groups = "gpio0_0_grp";
			function = "sdio0_cd";
		conf-cd {
			bias-pull-up;
			slew-rate = <0>;
			io-standard = <1>;
		mux-wp {
			groups = "gpio0_15_grp";
			function = "sdio0_wp";
		conf-wp {
			bias-pull-up;
			slew-rate = <0>;
			io-standard = <1>;
	pinctrl_uart1_default: uart1-default {
		mux {
			groups = "uart1_10_grp";
			function = "uart1";
		conf {
			slew-rate = <0>;
			io-standard = <1>;
		conf-rx {
			pins = "MIO49";
		conf-tx {
			pins = "MIO48";
			bias-disable;
	pinctrl_usb0_default: usb0-default {
		mux {
			groups = "usb0_0_grp";
			function = "usb0";
		conf {
			slew-rate = <0>;
			io-standard = <1>;
		conf-rx {
			pins = "MIO29", "MIO31", "MIO36";
		conf-tx {
			pins = "MIO28", "MIO30", "MIO32", "MIO33", "MIO34",
			       "MIO35", "MIO37", "MIO38", "MIO39";
			bias-disable;
&qspi {
	u-boot,dm-pre-reloc;
	status = "okay";
	is-dual = <0>;
	num-cs = <1>;
	flash@0 {
		compatible = "n25q128a11";
		reg = <0x0>;
		spi-tx-bus-width = <1>;
		spi-rx-bus-width = <4>;
		spi-max-frequency = <50000000>;
		#size-cells = <1>;
		partition@qspi-fsbl-uboot {
			label = "qspi-fsbl-uboot";
			reg = <0x0 0x100000>;
		partition@qspi-linux {
			label = "qspi-linux";
			reg = <0x100000 0x500000>;
		partition@qspi-device-tree {
			label = "qspi-device-tree";
			reg = <0x600000 0x20000>;
		partition@qspi-rootfs {
			label = "qspi-rootfs";
			reg = <0x620000 0x5E0000>;
		partition@qspi-bitstream {
			label = "qspi-bitstream";
			reg = <0xC00000 0x400000>;
&sdhci0 {
	status = "okay";
	pinctrl-0 = <&pinctrl_sdhci0_default>;
&uart1 {
	status = "okay";
	pinctrl-0 = <&pinctrl_uart1_default>;
&usb0 {
	status = "okay";
	dr_mode = "host";
	usb-phy = <&usb_phy0>;
	pinctrl-0 = <&pinctrl_usb0_default>;
Hello again,
I've tried another uImage I made in the past and this one hangs at the following:
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
mmcblk0: mmc0:0001 HAG2e 14.7 GiB
mmcblk0boot0: mmc0:0001 HAG2e partition 1 4.00 MiB
Initializing random number generator... mmcblk0boot1: mmc0:0001 HAG2e partition 2 4.00 MiB
mmcblk0rpmb: mmc0:0001 HAG2e partition 3 4.00 MiB
 mmcblk0:
PuTTYPuTTYPuTTYPuTTYdone.
Starting CAN
Starting network:
I don't know why...
Hi @senkoo
If you think rootfs size is bigger and is greater than 128 MB, you can make below changes to petalinux project:
1. Mention the Bootm length in platform-top.h #define CONFIG_SYS_BOOTM_LEN
2. Undef the CONFIG_SYS_BOOTMAPSZ in platform-top.h
Hi @shabbirk,
The size of my uramdisk.image.gz is 14,0 MB so I don't think I'll need to worry about it being bigger or greater then 128MB.
Thanks for your response :)
Greetings,
Senkoo
