igal_kroyter
Supporting SGTL5000 on ZCU102 via I2C
I am trying to configure the ZCU102 to support the SGTL5000 audio CODEC. Working with 2017.1.
I have connected the the SGTL evaluation board I2C pin (data & clock) to connector J160 on the ZCU102 board pins (5 & 7), these pins exposes the I2C0 port.
I understand that somewhere this port is defined (couldn't find where...) so I updated the device tree in system-user.dtsi file with the following lines:
amba: amba {
&i2c@ff020000 { status = "okay"; sgtl5000@0a { compatible = "fsl,sgtl5000"; reg = <0x0a>; clocks = <&clks 150>; micbias-resistor-k-ohms = <2>; micbias-voltage-m-volts = <2250>; VDDA-supply = <&reg_3p3v>; VDDIO-supply = <&reg_3p3v>; }; };
I have also added the SGTL5000 driver via kernel configuration.
but when I tried to compile I got this error: FATAL ERROR: Unable to parse input tree
Could someone advice on the matter?
thanks,
Igal
hpoetzl
Voyager
Voyager
Hey @igal_kroyter,
but when I tried to compile I got this error: FATAL ERROR: Unable to parse input tree ...
The problem with your device tree snippet is that for itself it is fine, except that it is very likely on the wrong I2C bus but it refers to two other sections with &clks and &reg_3p3v, which might or might not be there.
It would help a lot if you could upload the complete device tree for further analysis.
Thanks in advance,
Herbert
-------------- Yes, I do this for fun!
igal_kroyter
hpoetzl
Voyager
Voyager
Hey @igal_kroyter,
thanks for the reply the device tree file is attached.
I wasn't referring to the part you modified, I was referring to the entire device tree as it is uploaded to the device.
This one will have a .dts extension.
Herbert
igal_kroyter
hpoetzl
Voyager
Voyager
Hey @igal_kroyter,
If you are aware of any other file then please point me to the correct one.
The problem here is I have no clue about your design and project, so I don't know what files you are using ...
xilinx-zcu102-zu9-es2-rev1.0-2017.1/project-spec/meta-user/recipes-bsp/device-tree/files
Assuming this one is the one you are using in your project, then the problem is as expected because none of the labels (clks, reg_3p3v) is present there.
Will take a moment for me to adapt the section to your device tree an check which I2C bus is the correct one ...
Best,
Herbert
hpoetzl
Voyager
Voyager
Hey @igal_kroyter,
So your device tree (if that is the one you are actually using in your project) is missing the declarations for the first I2C bus (i2c0), so the first step is to enable this controller.
Once that is done, add the following section for the SGTL5000 ...
&i2c0 {
sgtl5000@0a {
reg = <0x0a>;
Hope this helps,
Herbert
igal_kroyter
Device Drivers → I2C support → I2C Hardware Bus support
Moreover,
I have copied the I2C1 configuration and reconfigured
i2c0: i2c0@0xFF020000 {
			#address-cells = <0x1>;
			#size-cells = <0x0>;
			clocks = <0x38>;
			compatible = "xlnx,ps7-i2c-1.00.a", "cdns,i2c-r1p10";
			interrupts = <0x12>;
			reg = <0x0 0xff020000 0x1000>;
				sgtl5000@0a {
					reg = <0x0a>;
and got the following error: ERROR (duplicate_label): Duplicate label 'i2c0' on /amba/i2c0@0xFF020000 and /amba/i2c@ff020000
Which means that the i2c0 is defined somewhere...
Please advise.
Igal
hpoetzl
Voyager
Voyager
Hey @igal_kroyter,
Yeah, looks like the device tree you provided is not the one you are actually using.
Please advise.
Let's assume, that the i2c0 definition is proper and we just need to enable and augment it.
I.e. let's try the following...
&i2c0 {
    status = "okay";
    sgtl5000@0a {
        reg = <0x0a>;
Let's see how that goes and what the kernel has to say ...
Hope this helps,
Herbert
igal_kroyter
		i2c@ff020000 {
			sgtl5000@0a {
				reg = <0x0a>;
Though I cannot close yet the post because I need to access the SGTL5000 evaluation board.
Which I said connected it via J160, through the pins and the board stuck upon power on.
if I remove the pins (which are connected on the board to I2C DATA & clock) the board boots up correctly.
Any suggestions?
Igal
hpoetzl
Voyager
Voyager
Hey @igal_kroyter,
This is very likely identical to not adding anything at all because it does not refer to the right section.
You are connecting to an I2C bus which is used for many other devices, so if your device happens to pull down the I2C bus, it will prevent other devices on the bus from working.
What do you mean by 'remove the pins'?
Best,
Herbert
