bleinweb
Supporting SRAM in Xilinx Linux
For a class, I've been working on trying to get Xilinx Linux up and working on MicroBlaze for an already built custom board with a Virtex-4 (XC4VLX40-12FF1148).  The board has an asynchronous SRAM module built into it that I want to use for system memory.
Right now I am trying to use the XPS_MCH_EMC driver to access it.
When generating the DTS file I get the following error.
WARNING:MDT - : Bank 0 of EMC core sram_emc is used in asynchronous mode.  We
   assume this core is connected to a flash memory, although in some older
   designs this configuration may have been used to interface to a peripheral.
   Current design recommendations suggest using an EPC core to interface to such
   peripherals.
IP connected to bus:
ERROR:MDT - device-tree () - No memory nodes found!
       while executing
   "error "No memory nodes found!""
       (procedure "gen_memories" line 134)
       invoked from within
   "gen_memories $toplevel $hwproc_handle"
       (procedure "generate_device_tree" line 154)
       invoked from within
   "generate_device_tree "xilinx.dts" $bootargs $consoleip"
       (procedure "::sw_device-tree_v0_00_x::generate" line 13)
       invoked from within
   "::sw_device-tree_v0_00_x::generate 38002400"
Looking at gen_memories in the device-tree_v2_1_0.tcl file I can see the exact line where it is ignoring my memory module because it is asynchronous (and therefore assumed to be flash).
The warning above the error suggests I should interface with the SRAM using the EPC, but the I can see that the script file doesn't even look at EPC controllers as memory.  According to this post, I guess I should try and hack a DTS file by hand, but the task seems a little daunting.
I was wondering if instead it would be ok to hack the device-tree script to allow using the MCH EMC core asynchronously instead.
Are there any issues that might pop up if I were to try and do this?
Thanks!
bleinweb
Sorry, I meant to mention that we still are using version 10.1 of the toolset.
Actually, now that I think of it, is the DTS generator even supposed to be compatible with 10.1?
Thanks again!
linnj
Sorry for the delayed response.
You shouldn't even need a driver for SRAM I would think.
