TFTP boot kernel panic in 2017.4
- Vivado, SDK, Petalinux: 2017.4
- Device:                           Zynq-7000
hello,
I am trying to boot using TFTP. I successfully followed UG1144 (satisfying all requirements) and am able to transfer the image over FTP. However, the boot fails and enters kernel panic mode.
I attached the complete console output, here is an excerpt:
Hit any key to stop autoboot:  4  3  2  1  0
Zynq> set serverip 192.168.1.3
Zynq> run netboot
Using ethernet@e000b000 device
TFTP from server 192.168.1.3; our IP address is 192.168.1.16
Filename 'image.ub'.
Load address: 0x10000000
Loading: *#################################################################
	 9.1 MiB/s
done
Bytes transferred = 54588240 (340f350 hex)
   Using 'conf@1' configuration
   Verifying Hash Integrity ... OK
   Trying 'kernel@0' kernel subimage
     Description:  Linux Kernel
     Type:         Kernel Image
     Compression:  uncompressed
   Loading Kernel Image ... OK
   Loading Ramdisk to 04f77000, end 07fffeb4 ... OK
   Loading Device Tree to 04f6d000, end 04f768d2 ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 4.9.0-xilinx-v2017.4 (user@machine) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP PREEMPT Sat May 12 12:31:17 WEST 2018
[<c039c884>] (bus_add_driver) from [<c039d980>] (driver_register+0xa0/0xe0)
[<c039d980>] (driver_register) from [<c0101858>] (do_one_initcall+0x100/0x120)
[<c0101858>] (do_one_initcall) from [<c0800da4>] (kernel_init_freeable+0x190/0x1d8)
[<c0800da4>] (kernel_init_freeable) from [<c05e5c20>] (kernel_init+0x8/0x10c)
[<c05e5c20>] (kernel_init) from [<c0106d18>] (ret_from_fork+0x14/0x3c)
Code: e5933000 e0833002 e5936000 f57ff04f (e5903000)
---[ end trace 382ee50588efee24 ]---
Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
CPU0: stopping
CPU: 0 PID: 0 Comm: swapper/0 Tainted: G      D         4.9.0-xilinx-v2017.4 #1
---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
The image itself is fine, I can boot from SD and in qemu.
Tags (3)
Re: TFTP boot kernel panic in 2017.4
Donyiu have a debbuger open? If so, close this before trying the netboot from uboot
No, I did not. I had no instance of Vivado or SDK open.
Is your Programmable logic programmed via the FSBL?
