TRD Reference Design ZCU102
Hi all !
I tried to rebuild the TRD_reference Design for ZCU102 (ZynqUltrascale+ MPSoC) module by module by following the procedure explained at http://www.wiki.xilinx.com/Zynq+UltraScale+MPSoC+Base+TRD+2017.2 , but
i am unable to figured out how could we create the individual device tree files such as located in the TRD reference design directory such as :
/home/path-toTRD/project-spec/meta-user/recipes-bsp/device-tree/files
Tags (2)
Re: TRD Reference Design ZCU102
There are DTG (Device tree generator) scripts in the petalinux tools that actually generates these dts/dtsi files. You dont need to bother about this. These are exported by the HDF file.
http://www.wiki.xilinx.com/Build+Device+Tree+Blob (Refer section:- Creating a Device Tree Source (.dts/.dtsi) files)
Best Regards
Shabbir
Thanks it solved the problem!
If the issue is resolved after following this thread, kindly select the accept this as solution button, that will stop others from responding on top of this thread
Best Regards
Shabbir
