The FLASH memory in petalinux
Hi, i'm following the instructions from Petalinux from scratch
http://developer.petalogix.com/wiki/BoardGuides/Custom/Tutorial
They used a device called Flash 2Mx32
that is used to mount FS-BOOT for mount petalinux.
All the test passes but whe i try to download the bitstream this appears :
fs-boot.c: In function 'is_in_flash':
fs-boot.c:233: error: 'CONFIG_XILINX_FLASH_START' undeclared (first use in this function)
fs-boot.c:233: error: (Each undeclared identifier is reported only once
 .....more errors.
I'm using the xps_sysace that is a IP for the compact flash . What controller should i used?
Thank you for the help and the answers!
The technology is a reflection of the fanaticism of men for survive.
Re: The FLASH memory in petalinux
I didn't go through the tutorial, but I believe the Flash refers to parallel Flash, not a CF card. So an EMC controller rather than xps_sysace should be used.
-XF
Really no, the only flash that can be used in this board it's using a compact flash.
So, I use one CF and then I change  the petalinux bsp file adding  xps_sysace ip core in the list
PARAMETER name = flash_memory, desc ="Name of Flash Memory Controller used with PetaLinux", type = peripheral_instance, range=(opb_emc,plb_emc,mch_opb_emc, xps_mch_emc,xps_sysace,none), default = none;
But whe i generate the NetList  this error appears :
Running generate for OS'es, Drivers and Libraries ...
# PetaLinux BSP generate...
ERROR:MDT - petalinux () - expected integer but got ""
       while executing
   "format "0x%08x" $mem_start"
       (procedure "do_memory_setup" line 75)
       invoked from within
   "do_memory_setup $os_handle "FLASH_MEMORY" XILINX_FLASH"
       (procedure "::sw_petalinux_v1_00_b::generate" line 39)
       invoked from within
   "::sw_petalinux_v1_00_b::generate 65281136"
Copying Library Files ...
ERROR:MDT - Error while running "generate" for processor microblaze_0...
make: *** [microblaze_0/lib/libxil.a] Error 2
opb_emc
plb_emc
mch_opb_emc
xps_mch_emc
Any suggestions??
Message Edited by pablogomez on 10-10-2008 07:47 PM
Did you copy autoconfig to petalinux enviroment (using petalinux-copy-autoconfig)?
