10-29-2018 09:51 AM
I got a do_populate_lic error when I follow the ZCU111-rfsoc-rfdc-getting started inside rdf0476 when I got the the step petalinux-build. I have the vivado license for ZCU111 and I also have a eval license for petalinux tool. My system is Centos 7. Here is the Error message:
ERROR: device-tree-xilinx+gitAUTOINC+682c126ef6-r0 do_populate_lic: QA Issue: device-tree: The LIC_FILES_CHKSUM does not match for file://xadcps/data/xadcps.mdd;md5=f7fa1bfdaf99c7182fc0d8e7fd28e04a
device-tree: The new md5 checksum is c494762543607e287f742a5ec8fc971a
ERROR: device-tree-xilinx+gitAUTOINC+682c126ef6-r0 do_populate_lic: Fatal QA errors found, failing task.
ERROR: device-tree-xilinx+gitAUTOINC+682c126ef6-r0 do_populate_lic: Function failed: populate_lic_qa_checksum
10-29-2018 10:08 PM
Hi @leongnrl
Make sure you are building the same version of petalinux as that of RFSoC TRD
Best Regards
Shabbir
11-01-2018 09:03 AM
The petalinux version is 2018.2, same as the TRD.
11-01-2018 01:43 PM - edited 11-01-2018 01:44 PM
Hi @leongnrl,
From the logs I see problem is the TRD petalinux project is pointing to 2018.1 device-tree release tags not 2018.2. https://github.com/Xilinx/device-tree-xlnx/commit/682c126ef65f1bac3f853f6158a5b37109cdad94
Refer release notes https://www.xilinx.com/support/answers/70896.html
From where did you get this TRD files?
11-02-2018 08:35 AM
I was trying to with petalinux ver 18.1 before that's why I posted the wrong error message. Here is what I got for ver 18.2
device-tree-xilinx+gitAUTOINC+f38738e568-r0 do_populate_lic: Function failed: populate_lic_qa_checksum
11-02-2018 11:30 AM
Hi @leongnrl,
Form where did you get this TRD design files from Lounge access?
11-02-2018 11:46 AM
I got this from the search result from Xilinx site.
11-06-2018 08:20 AM
Any update on this issue?
11-14-2018 11:59 AM
Hi @leongnrl,
I don't see the RFSoC TRD files mentioned in xilinx websites or wiki.
Can you point me where you downloaded these files.
11-16-2018 09:01 AM
This is associated with UG1287 - Zynq UltraScale+ RFSoC RF Data Converter Evaluation Tool User Guide (ZCU111) (ver 2018.2).
Victor
01-30-2019 02:12 PM
@leongnrl did you resolve this? If yes, how? I am getting the same issue when creating a project from the zcu102 bsp for 2018.1 or 2018.3.
02-11-2019 12:20 PM
I ended up reinstalling Ubuntu, I couldn't figure out what the problem was but I was able to build the same bsp on other desktop so it was related to my machine. I verified the Petalinux depedencies were of the same version on both machines; it could be that there's another dependency that's not advertised? After re-installing Ubuntu I was able to successfully build the BSP without issue.
