jianwenchang
The RPU and APU share interrupts collide
 rpu shares scugic with apu, and axidma's interrupt is handled by RPU. When RPU receives axidma's MM2s_introut or S2MM_introut interrupt, RPU can handle the interrupt normally, but Linux system struck,When RPU can normally output logs from the Console, the Console cannot receive any input and the LINUX LOG cannot be output.It is worth mentioning that I have removed AXIDMA from the kernel configuration,How can I solve this problem? thanks
sulcas.mindaugas
Try to use XScuGic_InterruptMaptoCpu() function in RPU code, this function maps interrupt to selected CPU and prevents system from hanging
jianwenchang
hi sulcas,
Thank you very much for your reply. I have tried to use this function to allocate interrupts to the specified CPU, such as 0 or 1. or 4.This is available on Zynq7K part, but on MPSOC devices, it does not seem to work,I don't even know what the CPU ID is, how is the ID assigned?The ids of a53x4 are 0,1,2,3, right?R5x2 is 4,5, or 0,1, right?Looking forward to your reply. Thank you very much!
sulcas.mindaugas
CPU ID parameter XPAR_CPU_ID can be found in xparameter.h file. It should be 0 for R5_0 core and 1 for RPU_1 core. Also disable or delete AXIDMA device tree node in you linux project so that linux wont try to interact with AXIDMA while baremetal application is using it. I hope this information will help you
jianwenchang
Thank you for your reply. This issue has been resolved. The reason is that the Shared memory Allocated by me conflicts with the memory used by Linux
