JM_Park
The peekpoke app stopped
Hello.
When I ran the peekpoke Application in ZCU102 with Petalinux 2018.3, the app stopped.
Here is a picture about this problem.
I already ran my FPGA configuration to read and write on BRAM when ZCU102 boots.
Anybody knows how to solve this problem??
watari
Hi @JM_Park
Because there is not proper module as address is 0xa0001000 in your design, the app stops.
Would you make sure module in dtb and your board design by Vivado ?
Best regards,
watari
Hi @JM_Park
Would you share the following result to investigate the route cause ?
ls /sys/devices/platform/amba_pl@0/
Best regards,
JM_Park
Thank you for your reply.
Here is the result,
watari
Hi @JM_Park
Best regards,
JM_Park
Umm... I see..
You mean.. For running this app, must have module to access memory?
Then.. Sorry but, Would you please give me some information about creating/applying module or similar things..?
