Timing measurement on read/write to Share Memory
We currently performed “executing-time timing measurement” on both A53 side and R5 side using ZCU102 board and get the following results:
Buffer size = 1024 bytes
loop 1000 times
A53 Release (uSec)
Min
Max
Running Avg
Fill the buffer byte by byte
1717
1786
1720
Local memcpy
180
231
180
shrmem memcpy - write
180
190
180
shrmem memcpy - read
180
190
180
loop 1000 times
R5 Release (uSec)
Min
Max
Running Avg
10260
10260
10260
Local memcpy
1188
1190
1188
4156
4228
4157
29175
30407
29189
shrmem blockwrite
4288
4290
4288
shrmem blockread
29688
29739
29694
We have the following questions:
  1. Why does “shrmem memcpy – write” is much much slower in R5 comparing to A53 (4,157 versus 180 usec)?  Here we copy 1024-byte buffer from local-memory to share-memory; then we loop these processing 1000 times.
Start time = clock_gettime()
memcpy()
End time = clock_gettime()
Executing_time = end time – start time
On A53, we use clock_gettime () to get Start time and End time.
On R5, we use XTime_GetTime() to get Start time and End time.
  1. Why does “shrmem memcpy –read” is much slower than “shrmem memcpy – write” on R5 (29189 vs. 4157)?   Whereas, the read and write is quite symmetric on A53 (180 vs. 180).
  2. Do these timing measurements seems reasonable to you?
Thank you
Andrew
