Visitor hoople
Trouble booting Linux kernel on custom board
We have a custom board with a xc7z030 on it.  But other than the part difference the board design is taken very closely from the ZC706 board.
I built a BOOT.BIN file with the normal work flow (UG980) and copied it to the SD card, but I get nothing at all on the terminal, not yet knowing if the hardware works or not, I switched to the QSPI to see if that works.  That got me along farther so I decided that I’ll come back to the SD card once I get everything working from the QSPI.  So far I’ve got the FSBL and u-boot running, but there’s where more trouble begins.
The problems:
First, (and this is probably just an annoyance) I don’t know how to keep it from trying to do a network boot (see BOOTP in the terminal view below).  How do I skip this?
Second, even though FSBL and u-boot are running from the QSPI, it’s looking to the SD card for the kernel.  I managed to get the kernel to load by running mkimage on a fit file (see attached) to include an uncompressed vmlinux image and my dtb into a image.ub file and placing that on the SD card.
The questions:
How can I configure u-boot to use the zImage and dtb that I loaded into the QSPI with via my BOOT.bin file?
Why can’t I boot from the SD card?  The hardware doesn’t seem to be the problem since I can read the kernel from it.
This should be all quite automated with Petalinux work flow but it doesn't seem to be the case...  okay, so that isn't a question, but might spur some usefull feedback.
Any insight you can offer will be greatly appreciated!
Gem.e000b000 Waiting for PHY auto negotiation to complete...... done
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
Retry count exceeded
Device: zynq_sdhci
Manufacturer ID: 3
OEM: 5344
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.4 GiB
Bus Width: 4-bit
reading image.ub
8682512 bytes read in 455 ms (18.2 MiB/s)
## Loading kernel from FIT Image at 01000000 ...
   Using 'conf@1' configuration
   Trying 'kernel@1' kernel subimage
     Description:  PetaLinux Kernel
     Type:         Kernel Image
     Compression:  gzip compressed
     Data Start:   0x010000f0
     Data Size:    8666112 Bytes = 8.3 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: 0x00008000
     Entry Point:  0x00008000
     Hash algo:    crc32
     Hash value:   c1fc3020
   Verifying Hash Integrity ... crc32+ OK
## Loading fdt from FIT Image at 01000000 ...
   Trying 'fdt@1' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Compression:  uncompressed
     Data Start:   0x01843dd4
     Data Size:    15104 Bytes = 14.8 KiB
     Architecture: ARM
     Hash algo:    crc32
     Hash value:   32b880b8
   Booting using the fdt blob at 0x1843dd4
   Uncompressing Kernel Image ... OK
   Loading Device Tree to 07ff9000, end 07fffaff ... OK
Starting kernel ...
Here’s my bif file:
the_ROM_image:
       [bootloader]/home/mattadsitt/Metha2/Custom_5_1/METHA20_Custom.linux/images/linux/zynq_fsbl.elf
       /home/mattadsitt/Metha2/Custom_5_1/METHA20_Custom.sdk/metha_top_system_wrapper_hw_platform_0/metha_top_system_wrapper.bit
       /home/mattadsitt/Metha2/Custom_5_1/METHA20_Custom.linux/images/linux/u-boot.elf
       [offset = 0xF00000]/home/mattadsitt/Metha2/Custom_5_1/METHA20_Custom.linux/images/linux/zImage.bin
       [offset = 0x1800000]/home/mattadsitt/Metha2/Custom_5_1/METHA20_Custom.linux/images/linux/system.dtb
       [offset = 0x1810000]/home/mattadsitt/Metha2/Custom_5_1/METHA20_Custom.linux/images/linux/urootfs.cpio.gz
and here's my fit file
/dts-v1/;
    description = "Metha 2.0 kernel and FDT blob";
    #address-cells = <1>;
    images {
        kernel@1 {
            description = "M2.0 Linux kernel";
            data = /incbin/("./vmlinux");
            type = "kernel";
            arch = "arm";
            os = "linux";
            compression = "none";
            load = <0x00008000>;
            entry = <0x00008000>;
            hash@1 {
                algo = "crc32";
        fdt@1 {
            description = "Metha 2.0 DTS";
            data = /incbin/("./system.dtb");
            type = "flat_dt";
            arch = "arm";
            hash@1 {
                algo = "crc32";
    configurations {
        default = "conf@1";
        conf@1 {
            description = "Linux kernel and FDT blob";
            kernel = "kernel@1";
            fdt = "fdt@1";
Observer dtrask
Re: Trouble booting Linux kernel on custom board
Somebody out there must have an answer to this. I am having the same trouble figuring out how to stop the network boot and just go straight to the SD card. It's annoying to wait 17 seconds ever time I power-on or reset for a network boot that is never going to happen.
there is a very useful guide for different boot options (QSPI, SD card, eMMC) on zedboard.org website: http://zedboard.org/support/design/4701/76
it's called "Booting Picozed Using QSPI and eMMC"
I have used this guide for setting my custom board.
Best Regards,
Rocco
