Trouble loading a 2018.2 FIT image using 2017.x U-Boot
I have a Zynq-7000 based board that uses QSPI to boot and eMMC to store the kernel.  The QSPI contains BOOT.BIN (ie, FSBL, PL bitstream, U-Boot) and the eMMC contains image.ub (the FIT image with kernel, rootfs and DTB).  Therefore, the two (bootloader and kernel) are not always in sync.  It's possible to update the eMMC with a newer kernel but leave U-Boot alone.
If U-Boot from Petalinux 2017.4 (on QSPI) tries to load an image.ub from 2018.2, the following happens:
U-Boot 2017.01 (Feb 22 2018 - 10:45:13 -0800)
Board: Xilinx Zynq
DRAM:  ECC disabled 512 MiB
MMC:   Card did not respond to voltage select!
sdhci@e0100000 - probe failed: -95
sdhci_transfer_data: Error detected in status(0x208000)!
SF: Detected n25q128 with page size 256 Bytes, erase size 64 KiB, total 16 MiB
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
U-BOOT for MiniZed
Hit any key to stop autoboot:  0
boot Petalinux
reading image.ub
34487736 bytes read in 11877 ms (2.8 MiB/s)
## Loading kernel from FIT Image at 10000000 ...
   Using 'conf@system-top.dtb' configuration
   Trying 'kernel@1' kernel subimage
     Description:  Linux kernel
     Type:         Kernel Image
     Compression:  gzip compressed
     Data Start:   0x10000104
     Data Size:    3636380 Bytes = 3.5 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: 0x00008000
     Entry Point:  0x00008000
     Hash algo:    sha1
     Hash value:   4a47a1db3bbecb65e7fcb67908ac1cca4965d01c
   Verifying Hash Integrity ... sha1+ OK
## Loading ramdisk from FIT Image at 10000000 ...
   Trying 'ramdisk@1' ramdisk subimage
     Description:  petalinux-user-image
     Type:         RAMDisk Image
     Data Start:   0x1037c054
     Data Size:    30832598 Bytes = 29.4 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: unavailable
     Entry Point:  unavailable
     Hash algo:    sha1
     Hash value:   569a51e69f8a29b58c25d7c9b1529fc3f310051a
## Loading fdt from FIT Image at 10000000 ...
   Trying 'fdt@system-top.dtb' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Compression:  uncompressed
     Data Start:   0x10377ea0
     Data Size:    16625 Bytes = 16.2 KiB
     Architecture: ARM
     Hash algo:    sha1
     Hash value:   01130f4c9f84719b08b7a87918f58c29be0dc508
   Booting using the fdt blob at 0x10377ea0
   Uncompressing Kernel Image ... Error: inflate() returned -5
Image too large: increase CONFIG_SYS_BOOTM_LEN
Must RESET board to recover
resetting ...
The opposite (U-Boot 2018.2 loading a 2017.4 image.ub) doesn't have the same issue and boots normally.
I noticed that starting with 2018.x the kernel portion of the FIT image is compressed.  In 2017.4, it isn't compressed.
Is there any way to create a FIT image using Petalinux 2018.2 that's backwards compatible with U-Boot from 2017.x?
Re: Trouble loading a 2018.2 FIT image using 2017.x U-Boot
Hi @andrewkrenz,
Yes backward compatibility is not possible.
Sandeep
Hi Sandeep,
What is the reason for this?
Andrew
Hi @andrewkrenz,
2018.x release is based on 4.14 kernel which is tested with u-boot version v2018.1 not using v2017.01
Refer PetaLinux release notes https://www.xilinx.com/support/answers/71201.html
https://www.xilinx.com/support/answers/70277.html
Sandeep
