Visitor akhilchandra
U-Boot Cross Compile
[s_me0131 @ it002017 ~ / submarine Digilent-Dev] $ make CROSS_COMPILE = arm-linux-Xilinx gnueabi-
make: arm-Xilinx linux-gcc-gnueabi: command not found
/ bin / sh: arm-Xilinx linux-gcc-gnueabi: command not found.
dirname: missing operand
"Dirname --help" gives further information.
Generating include / autoconf.mk
/ bin / sh: line 2: arm-Xilinx linux-gcc-gnueabi: command not found.
Generating include / autoconf.mk.dep
/ bin / sh: arm-linux-Xilinx gnueabi-ld: command not found.
Generating include / spl-autoconf.mk
Generating include / tpl-autoconf.mk
Arm Xilinx linux-gcc-gnueabi -DDO_DEPS_ONLY \
-g -Os -ffunction-sections -fdata-sections -fno-common -ffixed-R9 -fno-strict-aliasing -mno-unaligned access -mfpu = neon -D__KERNEL__ -I / usrf02 / home / AGME / stu / s_me0131 / submarine Digilent Dev / include -I / usrf02 / home / AGME / stu / s_me0131 / submarine Digilent Dev / arch / arm / include -fno-builtin -ffreestanding -nostdinc -isystem -pipe -DCONFIG_ARM -D__ARM__ -march = ARMv5 -Wall -Wstrict-prototypes \
-o lib / asm-offsets.s lib / asm-offsets.c -c -S
make: *** [lib / asm-offsets.s] Error 127
Teacher muzaffer
Re: U-Boot Cross Compile
did you source the proper settingsxx.sh script (ie /opt/Xilinx/Vivado/2015.3/settings64.sh).
Also in your CROSS_COMPILE variable there is a space after Xilinx. Is that space really there in your Makefile?
BTW, for my system the cross_compile variable is "arm-xilinx-linux-gnueabi-".
