Participant dreddthejudge
U-Boot Ethernet Lite problem with AXI4Lite
I am working on an SP605 board with ISE 14.7. Also I am using the u-boot-xlnx with v14.7 tag.
When I run u-boot on the memory, I call the dhcp command, however I cannot establish a connection.
I have enabled the debug mode, so that I could only see that no data is read from the "Ethernet Base Address".
How could I solve this problem?
PS: With the same bit file, I successfully started a Linux kernel on the memory and established a connection with the DHCP server. The Ethernet Lite IP is connected on AXI4 Lite.
