U-Boot Initialization Issues
I'm getting this message when U-Boot runs:
Loading Environment from FAT... *** Warning - bad CRC, using default environment
I believe it is trying to load the binary file uboot.env that is created if one saves the environment from U-Boot. But I don't want to mess with this at all. I simply want to load from uenv.txt and boot Linux.
I've used platform-top.h in meta-user to winnow down the default environment (see below). How do I bootstrap the environment? In other words, how can I get it to load my uenv.txt when it runs rather than uboot.env?
#define CONFIG_EXTRA_ENV_SETTINGS \
	SERIAL_MULTI \
	CONSOLE_ARG \
	PSSERIAL0 \
	"environment_text_file=uenv.txt\0" \
	"import_environment=echo \"Importing environment from SD ...\"; " \
		"env import -t ${environment_address} $filesize\0" \
	"load_environment=load mmc 0 ${environment_address} ${environment_text_file}\0" \
	"environment_address=0x00400000\0" \
	"script_exists=test -e mmc 0 /uenv.txt\0" \
	"uenvboot=" \
		"if run script_exists; then " \
			"run load_environment; " \
			"echo Loading environment from ${environment_text_file}.; " \
			"run import_environment; " \
			"fi; " \
		"if test -n $uenvcmd; then " \
			"echo Running uenvcmd ...; " \
			"run uenvcmd; " \
		"fi\0" \
	"autoload=no\0" \
	"default_bootcmd=echo No default boot command is defined.\0" \
rfs613
You can prevent the "Warning - bad CRC" by changing the u-boot configuration:
- disable CONFIG_ENV_IS_IN_FAT
- enable CONFIG_ENV_IS_NOWHERE
That said, I would recommend sticking with uboot.env rather than the text file. The two are almost identical - uboot.env contains all of the strings from the text file, plus a CRC checksum. The checksum provides useful detection in case of file corruption.
If your goal is to be able to easily modify the environment from Linux, there are existing tools for that: fw_printenv and fw_setenv. These are part of u-boot and may well be included in your target already.
rfs613
Thanks. I came to that conclusion last night and read that there is a utility to generate uboot.env. I'll write it myself if I have to but it seems like a good way to proceed.
