U-Boot: USB/DFU removal
Hello All,
Chip: xczu4ev
Petalinux: 2017.3
Component: U-Boot
I am trying to reduce the size of U-Boot, and remove potential attack vectors of the board, one of these is USB DFU.
It seems that no matter what I do I cannot get U-Boot to build when I disable DFU and USB.
I have tried with a custom board config, and doing petalinux-configure -c u-boot, I always end up with build failures related to symbols from DFU and/or U-Boot....
Any ideas / pointers on where to look would be most appreciated.
I have already seen:
https://forums.xilinx.com/t5/Embedded-Linux/How-do-I-remove-USB-from-U-Boot/m-p/840014#M24868
https://forums.xilinx.com/t5/Xilinx-Boards-and-Kits/ZCU-102-boot-from-USB-DFU/m-p/826793#M16912
Mark
Re: U-Boot: USB/DFU removal
Hi Msmith,
Please try below steps, it will build, I already verified with 2017.4 SW.
By default DFU config is disabled, You just need to disable the USB & usb command as well.
1. petalinux-config -c u-boot
    Device Drivers --->[] USB support ---> un select
2.  Command line interface  --> Device access commands  --> [ ] usb   -- Un select , save & exit.
3. petalinux-build
4.petalinux-package --boot --fsbl images/linux/zynq_fsbl.elf --fpga images/linux/download.bit --u-boot
Thanks & regards
Aravind
Hi Msmith,
3. petalinux-build
Thanks & regards
Aravind
Hello Aravind,
After removing a few extra hash defines from my main config header it seems fine. I'm sure I tried that in the past, must have missed something last time!
Annoyingly I cannot seem to put the relevant config changes in my defconfig. It simply ignores them.....
Specifying:
CONFIG_CMD_USB=n
CONFIG_CMD_DFU=n
CONFIG_USB=n
or
# CONFIG_CMD_USB is not set
# CONFIG_CMD_DFU is not set
# CONFIG_USB is not set
I'll mark this as solved, but I don't really think its a good way, I should be able to control this via the defconfig, thanks for you help.
Mark
It is worth noting that this only worked becuase i have control over the board include file. If I try this with a standard config (say zcu106) it failed to compile due to "THOR_DOWNLOAD" being defined.
