kayas257
U-boot bootcount_limit driver
I would like know how to enable bootcount_limit driver in uboot using Petalinux tool for xilinx zynqmp devices.
Your help will be appreciated.
Thanks & Regards,
Kayas Ahmed
Tags (3)
kayas257
I have solved the problem by also defining #define CONFIG_BOOTCOUNT_ENV in platform.h
Thanks & Regards,
Kayas
aravindb
HI @kayas257
Please enable below config in platform-top.h file & build , hope it should work.
vim "project-spec/meta-user/recipes-bsp/u-boot/files/platform-top.h"
#define CONFIG_BOOTCOUNT_LIMIT
Thanks & regards
Aarvind
kayas257
Hello @aravindb
This is the error I get, if i do what you said.
autoboot.c:300: undefined reference to `bootcount_load'
Thanks & Regards
Kayas
kayas257
Thanks & Regards,
Kayas
