U-boot building problem
Hi all
I have ported linux 2.6.37 kernel on ML507 board. That is running very fine. next i want to use u-boot as bootloader.
I have downloaded latest u-boot that has ML507 support from Xilinx Open Source Wiki and  i am using ELDK 4.1  cross compiler to build U-boot image . my commands are as follow
make ml507_config
make
but I think make utility is not starting the biuld process giving error like
invalid option
Should i need some modification regarding make utilty or the compiler version and source code for u-boot are not comfortable to each other.
Can any one tell the exact process.
thanks and regards
Visitor bleinweber
Re: U-boot building problem
That is kind of strange.  Using the ELDK 4.2 cross compiler that is linked to on this Xilinx Linux wiki page I've had no problems compiling it with the instructions provided on the U-Boot page there.  Perhaps the 4.1 tools won't work with the U-Boot version there.
Also, another step that I had missed is that you need to copy the xparameters.h file from your project into <u-boot>/board/xilinx/ml507/ directory.  I'm using the ML405, so it may not apply to you, but there were some options missing in my the xparameters.h file that I needed to copy from the original xparameters.h in the folder there, so keep a backup of that file.
U-Boot is booting on my system just fine.  I do have other problems however...
I tried building uboot with ELDK4.1 , It compiles without any issues.
Madhubala
Hi Madhbala
I have tried for that bt cant so can u give me your exeact steps and is there any cross compiler path setting taht i have to do
The steps are the same as mentioned in the Xilinx wiki page ,
You need to set the paths (PATH)of your compiler directory and also set CROSS_COMPILER name and ARCH in your environment.
ARCH=powerpc CROSS_COMPILE=ppc_4xx-
Example if you have csh shell , then
setenv PATH /home/madhu/tools/eldk/4.1/usr/bin:${PATH}
setenv CROSS_COMPILE ppc_44x-
setenv ARCH powerpc
Hope that answers
