06-19-2020 07:45 AM
Hi all,
we are using boards with Zynq FPGA (xc7z015) with xilinx fsbl, u-boot and linux. We have u-boot (V2018.01) config from the board manufacturer, it is attached. If u-boot is used with default config for QSPI boot, booting into Linux works perfectly. Now, we would like to add cryptography capability and encrypt our bitstream. According to Xilinx documentation, we need for this zynqaes command which is enabled with u-boot CONFIG_CMD_ZYNQ_AES define. However, if we add this define and the others below to allow u-boot to compile, this u-boot binary hangs up during boot and we cannot even reach u-boot shell.
CONFIG_SHA256=y
CONFIG_CMD_MD5SUM=y
CONFIG_CMD_ZYNQ_RSA=y
CONFIG_CMD_ZYNQ_AES=y
The only message which appears on the UART port is:
initcall sequence 0407db50 failed at call 040013cc (err=-12)
### ERROR ### Please RESET the board ###
Can you advice us what is wrong, what else should be changed in the config or how to debug this issue?
Thank you in advance,
Michael
