JPK17
UART routed to PL via EMIO not working in Petalinux.
Hi all,
I am using zynq Arty-Z7-20 board. Vivado version v2020.2.
I have mentioned steps followed and shared my block design.
1. UART1 --> EMIO
2. UART1 TX [external] --> to pin Y18 (Arty-Z7-20)/JA PMOD, Pin 1 --> constraints file.
3. UART1 RX [external] --> to pin Y19 (Arty-Z7-20)/JA PMOD, Pin 2 --> constrainst file.
ie...
set_property -dict { PACKAGE_PIN Y18 IOSTANDARD LVCMOS33 } [get_ports { ja_r1 }];
set_property -dict { PACKAGE_PIN Y19 IOSTANDARD LVCMOS33 } [get_ports { ja_t1 }];
4. Synthesized/Implemented and Generated Bitstream with no issues
5. Export Hardware (including Bitstream).
6. Create petalinux project using zynq template.
7. When I build project without setting UART1 as EMIO no building error.
8. After setting UART1 as EMIO on build project several time, I have got this error.
ERROR: [Common 17-55] 'get_property' expects at least one object.
What is the issue?
Thank you.
JPK17
