UIO: Device Tree confusion, no UIO created
I am trying to create a UIO solution for data transfer with the PL. I am using petalinux SDK 2016.2
My initial design is a simple PL (a custom axi_perpiheral) that I can write to and read from via the PS (this works in bare metal).
I managed to get a working app in petalinux using mmp /dev/mem, just hardcoding the peripheral's base address and then writing to the desired register. As my goal is for dma transfer from the PL, I want to try and perform the simple read / write via UIO. So,
I have enabled Userspace IO  platform driver with generic IRQ handling in the kernel config, and ran petalinux-config --get-hw-description targetted at my hdf file.
When I look at the device tree files however, pl.dtsi is empty. Is this right?? Do I need to change this?
I have changed the system-conf.dtsi so the bootargs line reads:
bootargs = "console=ttyPS0,115200 earlyprintk uio_pdrv_genirq.of_id=generic-uio";
My system-top.dts contains:
/dts-v1/;
/include/ "system-conf.dtsi"
          uio_axi_ps_ready@43C00000 {
              compatible = "generic-uio";
              reg = < 0x43C00000 0x1000 >;
              interrupts = < 0 57 0 >;
              interrupt-parent = <&intc>;
Where 0x43C00000 is the base address of my axi peripheral.
I then build the kernel and package the boot image, but when I boot on my device (zynq) I do not see any UIO listed with modprobe -l
Any help I'd be very grateful
- Marc
Re: UIO: Device Tree confusion, no UIO created
As the commenter stated earlier. The user space io drivers are set as modules. So, this is why you aren't seeing this.
Go to petalinux-config -c kernel
Device drivers
User space io drivers
<*> userspace io platform driver ..
Did you change the UIO driver to be a module?  In other releases it was built in.
Jeff
To be honest, I don't really know what I've created...! At least not how to describe it...
Doing some more digging, I do find my (device?) if I run:
cat /sys/class/uio/uio0/name
 Anyway, I have an app which basically opens /dev/uio0, then mmap and then I write and read reg values using the pointer. It seems to work ok now (after a couple of issues with MAP_SIZE)
Now onto dma...!
As long as your device tree is correct you can read in the size instead of needed IMG to know it.  I open this path and read in the value
sprintf(uio_size_path, "/sys/class/uio/uio%d/maps/map0/size", uio_num);
Jeff
Mentor watari
Mentor
Hi marc.pearson
Could you execute the following command on your linux ?
% ls /proc/device-tree/amba_pl
Thank you.
Best regards,
I am having the same problem. No uio device is available in /dev
Using bootargs = "earlycon=cdns,mmio,0xFF000000,115200n8,uio_pdrv_genirq.of_id=generic-uio";
ls /proc/device-tree/amba_pl outputs the following:
#address-cells     dma@000400000000   gpio@000400020000  name
#size-cells        dma@000400030000   gpio@000400040000  ranges
compatible         gpio@000400010000  gpio@000400050000
My pl.dtsi:
    amba_pl: amba_pl {
        #address-cells = <2>;
        #size-cells = <2>;
        compatible = "simple-bus";
        ranges ;
        axi_dma_receive: dma@000400000000 {
            #dma-cells = <1>;
            compatible = "xlnx,axi-dma-1.00.a";
            interrupt-parent = <&gic>;
            interrupts = <0 92 4>;
            reg = <0x00000004 0x00000000 0x0 0x10000>;
            dma-channel@400000030 {
                compatible = "xlnx,axi-dma-s2mm-channel";
                dma-channels = <0x1>;
                xlnx,datawidth = <0x20>;
                xlnx,device-id = <0x0>;
        axi_dma_transmit: dma@000400030000 {
            #dma-cells = <1>;
            interrupts = <0 91 4>;
            reg = <0x00000004 0x00030000 0x0 0x10000>;
            dma-channel@000400030000 {
                compatible = "xlnx,axi-dma-mm2s-channel";
                xlnx,device-id = <0x1>;
        axi_gpio_int: gpio@000400020000 {
            #gpio-cells = <2>;
            #interrupt-cells = <2>;
            gpio-controller ;
            interrupt-controller ;
            interrupts = <0 89 4>;
            reg = <0x00000004 0x00020000 0x0 0x10000>;
            xlnx,all-inputs = <0x1>;
            xlnx,all-inputs-2 = <0x0>;
            xlnx,all-outputs = <0x0>;
            xlnx,all-outputs-2 = <0x0>;
            xlnx,dout-default = <0x00000000>;
            xlnx,dout-default-2 = <0x00000000>;
            xlnx,gpio-width = <0x1>;
            xlnx,gpio2-width = <0x20>;
            xlnx,interrupt-present = <0x1>;
            xlnx,is-dual = <0x0>;
            xlnx,tri-default = <0xFFFFFFFF>;
            xlnx,tri-default-2 = <0xFFFFFFFF>;
        axi_gpio_rst_clr: gpio@000400010000 {
            #gpio-cells = <2>;
            gpio-controller ;
            reg = <0x00000004 0x00010000 0x0 0x10000>;
            xlnx,all-inputs = <0x0>;
            xlnx,all-outputs = <0x1>;
            xlnx,gpio-width = <0x2>;
            xlnx,interrupt-present = <0x0>;
        axi_gpio_rx_tx_data_count: gpio@000400040000 {
            #gpio-cells = <2>;
            gpio-controller ;
            reg = <0x00000004 0x00040000 0x0 0x10000>;
            xlnx,all-inputs-2 = <0x1>;
            xlnx,gpio-width = <0x20>;
            xlnx,is-dual = <0x1>;
        watchdog_gpio_irq: gpio@000400050000 {
            #gpio-cells = <2>;
            gpio-controller ;
            interrupts = <0 90 4>;
            reg = <0x00000004 0x00050000 0x0 0x10000>;
uio driver support is also activated in the petalinux config
Device drivers
@stephenm do you happen to know if there is a way to do this when using the standard yocto build flow, rather than with petalinux? I'd like to enable UIO in my design, but don't have the liberty of using the menuconfig gui.
you can create a recipe (recipes-kernel\linux\linux-xlnx)
Then a bsp.cfg file here, and add the config here
Then in recipes-kernel\linux\linux-xlnx_%.bbappend
SRC_URI += "file://bsp.cfg"
FILESEXTRAPATHS_prepend := "${THISDIR}/${PN}:"
