Re: UIO Interrupt handling with petalinux
@deppenkaiser,
I am not sure that depends on the board but how you code and how you design your hardware and software....just wait until someone else replies, but I believe they will tell you the same. FYI, I am currently working with a pynq, zedboard and petalinux 2017.4.
You may right, but now i have easter holiday i will test it later.
You have a working Version me not. You are able to compare both i'am not.
You would help me so much if you will compare my complete Code that i was posted (only a few lines) with your working Code. juergen.kratochwill@grapho-metronic.com shows a difference, that i will test after the easter days next week; more differences are not visible.
@aripod,
juergen.kratochwill@grapho-metronic.com,
@jrhtech
Are you using the petalinux default configuration for "zynq"
petalinux-create -template zynq -name myproject
or do you use the bsp from your board manufacturer?
Zynqberry, zed board and trenz t04xx. I found zed board the easiest. Vivado design self built (no pre-made Bsp) petalinux-create like you wrote, import. Hdf file built project... Used uio with 2016.4,2017.1 now 2017.4.
Does not sound like a board related issue...
the code I pmd you is all you need and it proved to be working with several different uio devices and I told you some differences in your code that might be the source of the error. Good luck testing!
@deppenkaiser,
Check out this blog.
i have solved my tcp/ip-select issue, so it's more clearly now.
Now i followed your guidance again and use the (void*) cast, it doesn't help. Now i have done everything that was told me and it is not working.
Here is the code:
bool UIOAccess_Initialize(SUIOAccessPtr pUIOAccess, index_t nDeviceNumber, index_t nMapNumber)
    bool bRetVal = false;
    uiostr_t info = { 0 };
    FILE* hSize = NULL;
    sprintf(info, "/sys/class/uio/uio%d/maps/map%d/size", nDeviceNumber, nMapNumber);
    sprintf(pUIOAccess->file, "/dev/uio%d", nDeviceNumber);
    pUIOAccess->fd = INVALID_FD;
    pUIOAccess->page_size = sysconf(_SC_PAGESIZE);
    if ((hSize = fopen(info, "r")) != NULL)
       rewind(hSize);
       fscanf(hSize, "%x", (uint32_t*) &(pUIOAccess->map_size));
       fclose(hSize);
       if ((pUIOAccess->fd = open(pUIOAccess->file, O_RDWR)) != INVALID_FD)
          pUIOAccess->base_addr = (memadr32_t) mmap(NULL, pUIOAccess->map_size, PROT_READ | PROT_WRITE, MAP_SHARED,
             pUIOAccess->fd, pUIOAccess->page_size * nMapNumber);
          bRetVal = ((void*) pUIOAccess->base_addr) != MAP_FAILED;
    return bRetVal;
bool UIOAccess_ActivateInterrupt(SUIOAccessPtr pUIOAccess)
    if (pUIOAccess->fd != INVALID_FD)
       int nValue = 1;
       bRetVal = write(pUIOAccess->fd, (void*) &nValue, sizeof(int)) != -1;
    return bRetVal;
bool UIOAccess_WaitForInterrupt(SUIOAccessPtr pUIOAccess)
       int nValue = 0;
       bRetVal = read(pUIOAccess->fd, (void*) &nValue, sizeof(int)) != -1;
    return bRetVal;
int ReadSwitches(SUIOAccessPtr pUIO)
     MEMORY_ACCESS(pUIO->base_addr, GPIO_CHANNEL_1_DIRECTION) = 0xFFFFFFFF;
     MEMORY_ACCESS(pUIO->base_addr, GPIO_GLOBAL_IRQ_ENABLE) = 0x8000000;
     MEMORY_ACCESS(pUIO->base_addr, GPIO_IRQ_ENABLE) = 0x00000003;
     return MEMORY_ACCESS(pUIO->base_addr, GPIO_CHANNEL_1_DATA);
int main()
    SUIOAccess uio_sw = { 0 };
    if (UIOAccess_Initialize(&uio_sw, 1, 0))
        while(true)
            MEMORY_ACCESS(uio_sw.base_addr, GPIO_IRQ_STATUS) = 0x3;
            printf("Switches: %d\n", ReadSwitches(&uio_sw));
            if (UIOAccess_ActivateInterrupt(&uio_sw))
                UIOAccess_WaitForInterrupt(&uio_sw);
        UIOAccess_DeInitialize(&uio_sw);
    return 0;
The "ReadSwitches" function test the uio device and the propper Input configuration of the Interrupt source. Here the "/proc/Interrupts" file again:
What is wrong with my example?
@aripod,
@jrhtech,
now it works!
I had an error in my macro. I used the wrong pointer arithmetic (Offset calculation with wrong pointer type). But i'am still wondering why i could set the propper direction of the GPIO. Therefor i must set the values into the correct Register!?
But now i know that my macro was wrong.
Glad you found it. I mentioned to you earlier that you should make sure that you are writing actually the register you think you do!
Well yes, but they also have a default setting from vivado. So in your case that most likely correlated then with the value you wanted to set...
yes, you told me that...
But i had to gpio's with both directions and both works. A Default can either be write ore read but not both.
I learned a lot because i had an issue, so it's ok :-)
