hoanggiamta
UIO files not created in petalinux 2017.2
Dear all,
I use the following setup in order to build my custom PL running under control from the host via UIO:
- Ubuntu 16.04
- Petalinux 2017.2
- Vivado 2017.2
- ZynqMP ZC102
However, when Petalinux running on Zynq, there are no UIO files created.
- ls /dev/uio  --> empty
- ls /sys/class/uio/  --> empty
But:
- ls /proc/devie-tree/uio  --> uio0  uio1  uio2
So do you think that I successfully built a device-tree with my 3 uio nodes, but I failed to register these 3 uio nodes in /dev  & in /sys/class/uio? Can you have any recommendation for my case?
Here is the steps I followed:
- step 1: create a Petalinux project:
     petalinux-create --type project --template zynqMP --name my_petalinux_project -s dir_to_BSP/Xilinx-ZCU102-v2017.2-final.bsp
- step 2: cd to the project, then config:
    petalinux-config --get-hw-description=my_vivado_project.sdk
   In this step: go into Kernel Bootargs:
       generate boot args automatically --> "y"
       enable kernel earlyprintk  --> "y"
       Auto generated bootargs: --> "earlycon clk_ignore_unused uio_pdrv_genirq.of_id=generic-uio"
- step 3:
    petalinux-config  -c kernel
    In this step: go into Device Drivers  --> Userspace I/O drivers: Userspace I/O platform driver with generic IRQ handling --> "y"
- step 4: Modify system-user.dtsi in project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi, and the content of system-user.dtsi after modification is:
/include/ "system-conf.dtsi"
    uio0 {
            compatible = "generic-uio";
            status = "okay";
            reg = <0x0 0xa0000000 0x0 0x10000>;
    uio1 {
            status = "okay";
            reg = <0x0 0xa0010000 0x0 0x10000>;
    uio2 {
            status = "okay";
            reg = <0x0 0xa0020000 0x0 0x10000>;
I also modified system-top.dts in components/plnx_workspace/device-tree-generation/system-top.dts by appending the following content in the top level:
uio0 {
            status = "okay";
  uio1 {
            status = "okay";
  uio2 {
            status = "okay";
- step 5:
    petalinux-build
- step 6: Package:
    petalinux-package --boot --format BIN --fsbl images/linux/zynqmp_fsbl.elf --fpga images/linux/config_mpsoc_wrapper.bit --u-boot images/linux/u-boot.elf -o images/linux/BOOT.BIN --force
- step 7: Copy BOOT.BIN and image.ub to SD card and boot the ZynqMP board.
After booting, I could not find UIO files in /dev/ and in /sys/class/uio/ as mentioned above?
Can anyone help me to point out the problems and how to fix? Thank you very much.
