UIO is not listed under /proc/interrupts and mapped to IRQ_F2P
Hello there,
I'm working with zc7020, and I'm having 2 pins connected to IRQ_F2P through Concat IP as shown below. Both Interrupt getting High alternately every after 5 sec, as written in verilog code. I'm receiving interrupts in Bare Metal. I want it to work with Linux.
Also, I did below settings in Kernel
petalinux-config -c kernel
o Device Drivers
   <*>Userspace I/O driver
       <*> Userspace I/O platform driver with generic IRQ handling
       <*> Userspace platform driver with generic IRQ handling and dynamic memory
Along with this, I've added following in system-user.dtsi
amba_pl {
		#address-cells = <0x1>;
		#size-cells = <0x1>;
		compatible = "simple-bus";
		ranges;
		uio@0{
			compatible="generic-uio";
			status="okay";
			interrupt-controller;
			interrupt-parent=<0x4>;
			interrupts=<0x0 0x1d 0x4>;
		uio@1{
			status="okay";
			interrupts=<0x0 0x1e 0x4>;
With all above settings, I'm able to see uio0 and uio1 in dev/.
Plus, They are also present in sys/class/uio but map0 or map1 is not present.
Also, if i do cat /proc/interrupts then I don't see UIO 0 or 1 listed there.
Can anyone help me out with this.???
Do I need to do any other settings to get interrupts working in Linux.???
Lokesh
Lokesh J.
> Thanks you for your quick response. I'm new to Linux.
I'd suggest to start by reading https://www.kernel.org/doc/html/latest/driver-api/uio-howto.html
(you can ignore the part about maps, since you seem to be interested in the interrupt only)
> Could you please tell me - How to open the driver i.e. dev/uio0.??
> Is there any example code for interrupt setup and theirs handler.??
The basic idea is explained in the "Writing a driver in userspace" section of the uio-howto document.
There are lots of examples available, a quick google search found this one: https://yurovsky.github.io/2014/10/10/linux-uio-gpio-interrupt.html (look at the "Userspace" section).
That's great!
That is expected, because you did not define a reg = <addr size> in your devicetree. So there is nothing to map. You can still use it for interrupts without a mapping.
You'll need to open the device (eg /dev/uio0) in order for the interrupt allocated. While it is open, you should see an entry in /proc/interrupts.
After opening the device, you would typically perform a read() or a select() in order to wait for an interrupt.
After the interrupt occurs, your code will need to perform a write() in order to re-arm the interrupt.
Hi @rfs613 ,
So, Could you please help me more.??
Lokesh
Lokesh J.
Hi @rfs613 ,
I'm following the link what you have shared.
After Compiling the code I'm seeing following warnings
implicit declaration of function ‘write’; did you mean ‘fwrite’? [-Wimplicit-function-declaration]
implicit declaration of function ‘read’; did you mean ‘fread’? [-Wimplicit-function-declaration]
Also, if I move forward by Ignoring the warnings. I'm getting following Prints on Board Terminal
Could you please help me with this.??
Lokesh
Lokesh J.
You can fix the warnings by adding #include <unistd.h> at the top of the file. The is from the SYNOPSIS section of the man page https://man7.org/linux/man-pages/man2/write.2.html.
The input/output error suggests that the interrupt is not configured correctly. When you call write(), the following code in kernel is being execute (see https://elixir.bootlin.com/linux/v4.4.197/source/drivers/uio/uio.c#L557
static ssize_t uio_write(struct file *filep, const char __user *buf,
			size_t count, loff_t *ppos)
	struct uio_listener *listener = filep->private_data;
	struct uio_device *idev = listener->dev;
	ssize_t retval;
	s32 irq_on;
	if (!idev->info->irq)
		return -EIO;              // EIO = input/output error
So the input/output error indicates that the interrupt (IRQ) has not been setup in the UIO driver. The next question of course is why is the interrupt not setup.
Assuming that you are using uio_pdrv_genirq driver, then the interrupt is obtained from the devicetree using platform_get_irq() function, see https://elixir.bootlin.com/linux/v4.4.197/source/drivers/uio/uio_pdrv_genirq.c#L149. I suspect this is failing, in which case, you should see "failed to get IRQ" error (line 154) appearing during the kernel boot.
	if (!uioinfo->irq) {
		ret = platform_get_irq(pdev, 0);
		uioinfo->irq = ret;
		if (ret == -ENXIO && pdev->dev.of_node)
			uioinfo->irq = UIO_IRQ_NONE;
		else if (ret < 0) {
			dev_err(&pdev->dev, "failed to get IRQ\n");
			return ret;
Check that you are specifying the correct interrupt and interrupt-parent in your device tree.
Do not forget my friend that the interrupt number seen in a device tree node is not the 'real' interrupt number assigned on the SoC. There is an offset of 32.
Let's say the interrupt number in the SoC is 121, then the number you have to put in the device-tree node will be 153. Why? Because.
