xhpohanka1
USB gadget in u-boot
is it possible to use ethernet gadget on zynq board using u-boot-xlnx tree?
I have tried xilinx-v2019.1 release but unfortunately with no success. I can use usb in u-boot in host mode, but driver probably lacks support for using gadget. Anyone has some solution?
best regards
Jan
aravindb
Hi @xhpohanka1
You cannot use u-boot for verifying Ethernet gadget. u-boot is not having support for Ethernet gadget & we have not tested in u-boot. You have to use the Linux for Ethernet gadget to work.
Please follow this link for reference:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842272/Zynq+Linux+USB+Device+Driver
Thanks & regards
Aravind
