ewong3
USB mass storage errors
I'm using linux-xlnx kernel 4.0.0 and having issues with USB mass storage devices.  I can seemingly detect and mount them, but when I go to access them (with ls), I get this error:
[ 5833.301488] usb 1-1: USB disconnect, device number 4
[ 5833.321397] sd 2:0:0:0: [sda] UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
[ 5833.328977] sd 2:0:0:0: [sda] CDB: opcode=0x28 28 00 06 fb 45 a8 00 00 b0 00
[ 5833.336024] blk_update_request: I/O error, dev sda, sector 117130664
[ 5833.342561] JBD: Failed to read block at offset 26008
[ 5833.347566] blk_update_request: I/O error, dev sda, sector 0
[ 5833.353221] sd 2:0:0:0: [sda] UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
[ 5833.360811] sd 2:0:0:0: [sda] CDB: opcode=0x28 28 00 06 fb 46 58 00 00 40 00
[ 5833.367857] blk_update_request: I/O error, dev sda, sector 117130840
[ 5833.444664] JBD: recovery failed
I tried this patch: https://forums.xilinx.com/t5/Embedded-Linux/Problem-w-USB-mass-storage-on-ZC702-using-linux-xlnx-4-9/m-p/782428#M20879
But still get the error.  Any suggestions? Thanks for any help.
