Uartlite kernel error
uartlite_bd.pngBlock Diagram
I have an external device I am trying to talk to using the uart lite core. The only other UARTs in the design are the two PS UARTs. You can see my block diagram above.
I am using Petalinux. I believe that I have the device tree setting correct. While the kernel is booting I get this error message:
[ 4.094996] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 4.096406] uartlite a0010000.serial: ttyUL2 too large
[ 4.096454] uartlite: probe of a0010000.serial failed with error -22
I have not been able to solve this problem. In the kernel configuration I have increased the max number of UARTs to 16 everywhere I could find. That has not solved this problem. Any pointers would be appreciated. Thank you!
Visitor jol14
Re: Uartlite kernel error
I had this error before. It is causes by the following definition in the uartlite.c driver
#define ULITE_NR_UARTS        CONFIG_SERIAL_UARTLITE_NR_UARTS
This parameter can be found in the "petalinux-config -c kernel" command:
 │ Symbol: SERIAL_UARTLITE_NR_UARTS [=1]        │
  │ Type  : integer        │
  │ Range : [1 256]        │
  │ Prompt: Maximum number of uartlite serial ports        │
  │   Location:        │
  │     -> Device Drivers        │
  │       -> Character devices        │
  │         -> Serial drivers        │
  │ (1)       -> Xilinx uartlite serial port support (SERIAL_UARTLITE [=m])        │
  │   Defined at drivers/tty/serial/Kconfig:633        │
  │   Depends on: TTY [=y] && HAS_IOMEM [=y] && SERIAL_UARTLITE [=m]
If this didn't solve your problem you may consider upgrading to 2018.3.
They removed this parameter from the driver and configuration menu.
I believe that these parameters are set correctly. Please see below to confirm. The error still persists.
Hi dustin.nicholes@gmail.com,
- Please follow the below wiki link for test procedure
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842249/Uartlite+Driver
Best Regards
Abhinay PS
Give kudos to a post which you think is helpful and reply oriented.
