Uartlite on PetaLinux
Hi all,
I have a question, which may sound a little stupid but I need to understand this.
I am used to writing drivers for my custom IPs using the baremetal method. I am currently working on a project that requires me to use Petalinux and I am still trying to figure out more about it. So I am trying to configure a camera through uart and I am thinking of using UartLite IP. There is a good example by xilinx that does loopback( Transmitter to Receiver). To test this design on putty, echo command  is used.https://xilinx-wiki.atlassian.net/wiki/pages/viewpage.action?pageId=63144421 . If I want to send a series of commands to the camera(registers and data),  in SDK a .c file will do this easily. In Petalinux how can this be done( I mean a series of commands that will be sent) ? or Will I have to send them  one at a time like the echo command.
Thank you
