Ubuntu 2018.3 build error
I am trying to create an ubuntu 2018.3 image to install it on Zynq zcu102 ver1.1 following the tutorial bellow but when I am reaching at petalinux-build command I am receiving an error about "ERROR: Nothing PROVIDES 'virtual/pmu-firmware'". I have stuck, I cannot find any solution and I would be very happy if you could help me.
Tutorial: https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841937/Zynq+UltraScale+MPSoC+Ubuntu+part+2+-+Building+and+Running+the+Ubuntu+Desktop+From+Sources
Thanos
Tags (3)
HI @p8grs
Can ypu please try to remove this content "virtual/pmu-firware" from below file & build again.
vim ./project-spec/meta-plnx-generated/recipes-core/images/petalinux-user-image.bb
Thanks & regards
Aravind
I tried that but it did not work because it was my problem, I was trying to run petalinux 2018.3 bsp on petalinux 2017.3 installation (long story why). I download petalinx 2017.3 bsp and everything worked perfect even when I combine the BOOT.bin and image.ub with 2018.3 ubuntu in the tutorial above. Thank you for your time anyway.
