Ubuntu Desktop Linux Turorial with Vivado 2015.1
I followed the Ubuntu Desktop Linux Turorial (provided by Zedboard.org website) with Vivado 2013.4 and everything work. But now, I would like build the project with Vivado 2015.1 and I have some problems. I modified some scripts for builded the project and I finally achieved to generate the bitstream and made all files for run Ubuntu. The problem is when the Kernel is running I have this message :
adv7511-hdmi-snd fpga-axi@0: adv7511_hdmi_snd: ASoC: CODEC DAI adv7511 not registered
and the desktop not appear on the HDMI screen but Linux work because I can communicate with it through UART.
I think I have forgotten to modifie something but what ? Have you any idea ?
Jo
Re: Ubuntu Desktop Linux Turorial with Vivado 2015.1
I solved my problem, the interrupt ID have changed so I modify the devicetree and everything work.
Jo
@jordanairbusds
Can you check the device-tree entries for adv7511 are correct?
I haven't the details you are working on ,but i have seen the similar discussion in Analog device forum see if this helps for you.
https://ez.analog.com/thread/19582?tstart=0
Let me know if that helps.
Achutha
Jo
