puv97
Ubuntu Desktop on ZCU102
Hi !
I'm following the tutorial https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841937/Zynq+UltraScale+MPSoC+Ubuntu+part+2+-+Building+and+Running+the+Ubuntu+Desktop+From+Sources but only the petalinux configuration. I'd like to use mi own XSA file but with my XSA file and the petalinux configuration the ZCU102 doesn't boot with Ubuntu Desktop it shows in the serial port the message:
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2) ]-
I'm not sure if I have tu put something particular in the hardware design or if only with the processor IP it is enought.
I'm so new with this, thanks !
puv97
I found the solution following the SD preparation of the tutorial https://www.dspsandbox.org/ubuntu-on-zynq-and-zynqmp-devices/ . Doing that steps the ZCU102 is working with Ubuntu 18.04.
Thanks !
Prasanna_K
Hi @puv97 ,
Run the below in uboot before loading the images.
setenv bootargs 'console=ttyPS0,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait'
 If this doesn't solves the problem, share the complete boot log.
Prasanna
puv97
It doesn't allow me to type anything before or after.
There is attached the log file.
watari
Professor
Professor
Hi @puv97
How do you format /dev/mmcblk0p2 ? Also what is this file system ?
At least it seems wrong file system or partition table...
puv97
Hi, I have a 256GB SD card with a 32GB partition in FAT32. In this partition I paste the files BOOT.bin and image.ub which I created following the tutorial.
Might I do anything else ?
Thanks !
Prasanna_K
Hi @puv97 ,
You need to make 2 partition of your sd card, one with fat32 and the other with ext4. Follow the below procedure and you should be good.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842385/How+to+format+SD+card+for+SD+boot
Prasanna
watari
Professor
Professor
Hi @puv97
I strongly recommend that it is formatted by FAT32 on 1st partition and this size is less 1GB.
And, I agree @Prasanna_K , you should that it is formatted by ext4 or other proper file system on 2nd partition.
1st partition : FAT32 : /boot
2nd partition : ext4 : /
puv97
OK, I follow that tutorial but I still having the same error: [ end Kernel panic - not syncing: No working init found. Try passing init= option to kernel. See Linux Documentation/admin-guide/init.rst for guidance. ]
shabbirk
Hi @puv97
Can you confirm if you are able to boot first the ready files (Boot images) provided as part of this wiki?
Shabbir
puv97
Hi @shabbirk
Yes, I'm able to boot the system using the Ubuntu images of that tutorial, also I cannot use the keyboard or the mouse but Ubuntu initializes normally. So, Could the problem be the generation of the images using petalinux ? Is there the possibility to use a bitstream for the PL using the boot images provided in the tutorial ?
Thanks !
watari
Professor
Professor
Hi @puv97
Would you share whole boot log and Xorg's log to investigate the route cause ?
puv97
Thanks !
