Visitor bmagnusen
UltraZed-EG Starter Kit hangs during Linux boot
I'm trying to boot PetaLinux 2017.4 on an Ultrazed-EG from SD card and it's hanging during Linux boot process.
Earlier I had another issue https://forums.xilinx.com/t5/Embedded-Linux/Ultrazed-EG-Starter-Kit-can-t-boot-from-SD-card-Unable-to-read/td-p/839637, but with help from @vish.bh30 I was able to get past it.
Basically there are a few different errors/warnings during the boot process (not sure which if any of them are clues as to the root cause of the problem) and then the boot hangs consistently at a certain point (after outputting message "PLL: shutdown").
Can anyone point me in the right direction regarding how to troubleshoot this?
Steps Taken To Produce SD Card
# Pre-Configuration
1) PetaLinux 2017.4 installed and its settings.sh file 'source'ed
2) HDF file from Vivado located at ~/hdf/uz3eg_iocc_dp_wrapper.hdf
3) SW2 Boot Mode switch (MODE[3:0]) configured as ON, OFF, ON, OFF
4) SD card present with partitions configured as:
   Partition    File System  Mount Point           Label   Size        Flags
   unallocated  unallocated                                  4.00 MiB
   /dev/sdb1    fat32        /media/brianm/BOOT    BOOT    128.00 MiB
   /dev/sdb2    ext4         /media/brianm/rootfs  rootfs   14.32 GiB
# Create the project
$ cd ~
$ petalinux-create -t project --template zynqMP --name myproject
# Import the hardware configuration
$ cd ~/myproject/
$ petalinux-config --get-hw-description=~/hdf/
# Modify system configuration to boot from SD card when the menuconfig interface is presented
Image Packaging Configuration -> Root filesystem type -> SD card
# Modify device tree
Set the contents of file ~/myproject/project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi to the following:
/include/ "system-conf.dtsi"
&sdhci0 {
       status = "disabled";
&sdhci1 {
       status = "okay";
# Build the project
$ petalinux-build
$ petalinux-package --boot --fsbl images/linux/zynqmp_fsbl.elf --fpga images/linux/uz3eg_iocc_dp_wrapper.bit --u-boot
# Prepare SD card
$ cp ~/myproject/BOOT.BIN /media/brianm/BOOT/
$ cp ~/myproject/images/linux/image.ub /media/brianm/BOOT/
$ cp ~/myproject/images/linux/system.dtb /media/brianm/BOOT/
$ cp ~/myproject/images/linux/rootfs.tar.gz /media/brianm/rootfs/
$ cd /media/brianm/rootfs/
$ tar xvf rootfs.tar.gz
Resulting Output
Xilinx Zynq MP First Stage Boot Loader
Release 2017.4   Mar 20 2018  -  10:43:43
NOTICE:  ATF running on XCZU3EG/silicon v4/RTL5.1 at 0xfffea000, with PMU firmware
NOTICE:  BL31: Secure code at 0x0
NOTICE:  BL31: Non secure code at 0x8000000
NOTICE:  BL31: v1.3(release):47af34b
NOTICE:  BL31: Built : 17:42:40, Mar 20 2018
U-Boot 2017.01 (Mar 20 2018 - 10:45:41 -0700) Xilinx ZynqMP ZCU102 revB
I2C:   ready
DRAM:  2 GiB
ERROR: usb dr_mode not found
at /home/brianm/myproject/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.4+gitAUTOINC+5fa7d2ed06-r0/git/drivers/usb/common/common.c:32/usb_get_dr_mode()
EL Level:       EL2
Chip ID:        xczu3eg
MMC:   sdhci@ff170000: 0 (SD)
zynqmp_qspi_ofdata_to_platdata: CLK 124999999
SF: Detected n25q256a with page size 512 Bytes, erase size 128 KiB, total 64 MiB
In:    serial
Out:   serial
Err:   serial
Net:   ZYNQ GEM: ff0e0000, phyaddr ffffffff, interface rgmii-id
eth0: ethernet@ff0e0000
U-BOOT for ndazynq
ethernet@ff0e0000 Waiting for PHY auto negotiation to complete...... done
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
Retry time exceeded
Hit any key to stop autoboot:  0
Device: sdhci@ff170000
Manufacturer ID: 27
OEM: 5048
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 14.5 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading image.ub
13412476 bytes read in 988 ms (12.9 MiB/s)
Manufacturer ID: 27
OEM: 5048
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 14.5 GiB
Bus Width: 4-bit
reading system.dtb
33123 bytes read in 17 ms (1.9 MiB/s)
   Using 'conf@2' configuration
   Trying 'kernel@0' kernel subimage
     Description:  Linux Kernel
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x100000d8
     Data Size:    13378048 Bytes = 12.8 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x00080000
     Entry Point:  0x00080000
     Hash algo:    sha1
     Hash value:   a162cefd5e8ca781937c104a297d992caeeafd19
## Flattened Device Tree blob at 11800000
   Booting using the fdt blob at 0x11800000
   Loading Kernel Image ... OK
   Loading Device Tree to 0000000007ff4000, end 0000000007fff162 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.0-xilinx-v2017.4 (brianm@borma-vm) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP Tue Mar 20 10:36:04 PDT 2018
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[    0.000000] bootconsole [cdns0] enabled
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 256 MiB at 0x0000000070000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] percpu: Embedded 21 pages/cpu @ffffffc06ff7a000 s48152 r8192 d29672 u86016
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 517120
[    0.000000] Kernel command line: earlycon clk_ignore_unused root=/dev/mmcblk0p2 rw rootwait
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 1789188K/2097152K available (9084K kernel code, 584K rwdata, 2824K rodata, 512K init, 397K bss, 45820K reserved, 262144K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008960000   (  9088 KB)
[    0.000000]     .rodata : 0xffffff8008960000 - 0xffffff8008c30000   (  2880 KB)
[    0.000000]       .init : 0xffffff8008c30000 - 0xffffff8008cb0000   (   512 KB)
[    0.000000]       .data : 0xffffff8008cb0000 - 0xffffff8008d42200   (   585 KB)
[    0.000000]        .bss : 0xffffff8008d42200 - 0xffffff8008da5634   (   398 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf01c00000   (    28 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc080000000   (  2048 MB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 99.99MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x171015c90f, max_idle_ns: 440795203080 ns
[    0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511101ns
[    0.008251] Console: colour dummy device 80x25
[    0.012507] console [tty0] enabled
[    0.015871] bootconsole [cdns0] disabled
[    0.019781] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.99 BogoMIPS (lpj=399996)
[    0.019796] pid_max: default: 32768 minimum: 301
[    0.019910] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.019921] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.020554] ASID allocator initialised with 65536 entries
[    0.021100] zynqmp_plat_init Power management API v0.3
[    0.021185] EFI services will not be available.
[    0.021549] Detected VIPT I-cache on CPU1
[    0.021580] CPU1: Booted secondary processor [410fd034]
[    0.021865] Detected VIPT I-cache on CPU2
[    0.021884] CPU2: Booted secondary processor [410fd034]
[    0.022154] Detected VIPT I-cache on CPU3
[    0.022173] CPU3: Booted secondary processor [410fd034]
[    0.022210] Brought up 4 CPUs
[    0.022245] SMP: Total of 4 processors activated.
[    0.022253] CPU features: detected feature: 32-bit EL0 Support
[    0.022264] CPU: All CPU(s) started at EL2
[    0.022280] alternatives: patching kernel code
[    0.023026] devtmpfs: initialized
[    0.027650] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.033701] xor: measuring software checksum speed
[    0.071886]    8regs     :  2111.000 MB/sec
[    0.111917]    8regs_prefetch:  1882.000 MB/sec
[    0.151949]    32regs    :  2594.000 MB/sec
[    0.191979]    32regs_prefetch:  2180.000 MB/sec
[    0.191993] xor: using function: 32regs (2594.000 MB/sec)
[    0.192093] pinctrl core: initialized pinctrl subsystem
[    0.192809] NET: Registered protocol family 16
[    0.214029] cpuidle: using governor menu
[    0.214255] Failed to initialise IOMMU /amba/smmu@fd800000
[    0.214433] vdso: 2 pages (1 code @ ffffff8008967000, 1 data @ ffffff8008cb4000)
[    0.214461] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.215076] DMA: preallocated 256 KiB pool for atomic allocations
[    0.225762] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
[    0.226637] ARM CCI_400_r1 PMU driver probed
[    0.229906] zynqmp-pinctrl ff180000.pinctrl: zynqmp pinctrl initialized
[    0.250323] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.316144] raid6: int64x1  gen()   372 MB/s
[    0.384220] raid6: int64x1  xor()   404 MB/s
[    0.452223] raid6: int64x2  gen()   618 MB/s
[    0.520285] raid6: int64x2  xor()   548 MB/s
[    0.588377] raid6: int64x4  gen()   902 MB/s
[    0.656385] raid6: int64x4  xor()   677 MB/s
[    0.724427] raid6: int64x8  gen()  1049 MB/s
[    0.792471] raid6: int64x8  xor()   684 MB/s
[    0.860513] raid6: neonx1   gen()   661 MB/s
[    0.928560] raid6: neonx1   xor()   695 MB/s
[    0.996622] raid6: neonx2   gen()  1069 MB/s
[    1.064684] raid6: neonx2   xor()   941 MB/s
[    1.132717] raid6: neonx4   gen()  1378 MB/s
[    1.200761] raid6: neonx4   xor()  1083 MB/s
[    1.268831] raid6: neonx8   gen()  1454 MB/s
[    1.336863] raid6: neonx8   xor()  1119 MB/s
[    1.336876] raid6: using algorithm neonx8 gen() 1454 MB/s
[    1.336889] raid6: .... xor() 1119 MB/s, rmw enabled
[    1.336901] raid6: using intx1 recovery algorithm
[    1.337345] GPIO IRQ not connected
[    1.337359] XGpio: /amba_pl@0/gpio@80000000: registered, base is 504
[    1.337636] GPIO IRQ not connected
[    1.337650] XGpio: /amba_pl@0/gpio@80010000: registered, base is 497
[    1.337882] GPIO IRQ not connected
[    1.337895] XGpio: /amba_pl@0/gpio@80020000: registered, base is 494
[    1.338631] SCSI subsystem initialized
[    1.338836] usbcore: registered new interface driver usbfs
[    1.338883] usbcore: registered new interface driver hub
[    1.338929] usbcore: registered new device driver usb
[    1.339019] media: Linux media interface: v0.10
[    1.339057] Linux video capture interface: v2.00
[    1.339093] pps_core: LinuxPPS API ver. 1 registered
[    1.339106] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.339139] PTP clock support registered
[    1.339175] EDAC MC: Ver: 3.0.0
[    1.339613] FPGA manager framework
[    1.339765] fpga-region fpga-full: FPGA Region probed
[    1.339880] Advanced Linux Sound Architecture Driver Initialized.
[    1.340219] Bluetooth: Core ver 2.22
[    1.340258] NET: Registered protocol family 31
[    1.340272] Bluetooth: HCI device and connection manager initialized
[    1.340291] Bluetooth: HCI socket layer initialized
[    1.340306] Bluetooth: L2CAP socket layer initialized
[    1.340330] Bluetooth: SCO socket layer initialized
[    1.340919] clocksource: Switched to clocksource arch_sys_counter
[    1.341019] VFS: Disk quotas dquot_6.6.0
[    1.341071] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.346293] NET: Registered protocol family 2
[    1.346700] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    1.346834] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    1.347124] TCP: Hash tables configured (established 16384 bind 16384)
[    1.347202] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    1.347256] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    1.347405] NET: Registered protocol family 1
[    1.347636] RPC: Registered named UNIX socket transport module.
[    1.347651] RPC: Registered udp transport module.
[    1.347663] RPC: Registered tcp transport module.
[    1.347675] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.348125] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.348895] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    1.349006] audit: initializing netlink subsys (disabled)
[    1.349049] audit: type=2000 audit(1.340:1): initialized
[    1.349591] workingset: timestamp_bits=62 max_order=19 bucket_order=0
[    1.350298] NFS: Registering the id_resolver key type
[    1.350325] Key type id_resolver registered
[    1.350337] Key type id_legacy registered
[    1.350354] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.350383] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    1.355184] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.355211] io scheduler noop registered
[    1.355223] io scheduler deadline registered
[    1.355241] io scheduler cfq registered (default)
[    1.356461] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[    1.356769] Write failed gate address:1000f02
[    1.356872] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[    1.357037] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[    1.357180] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[    1.357324] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[    1.357465] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[    1.357610] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[    1.357752] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[    1.357897] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[    1.358111] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[    1.358261] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[    1.358404] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[    1.358550] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[    1.358691] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[    1.358842] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[    1.358986] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[    1.359131] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[    1.359319] zynqmp_pm firmware: Power management API v0.3
[    1.359429] xenfs: not registering filesystem on non-xen platform
[    1.391177] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.392349] [drm] Initialized
[    1.392749] [drm] load() is defered & will be called again
[    1.393325] xilinx-drm-dp-sub fd4aa000.dp_sub: Xilinx DisplayPort Subsystem is probed
[    1.393519] Unable to detect cache hierarchy from DT for CPU 0
[    1.398999] brd: module loaded
[    1.402301] loop: module loaded
[    1.403172] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[    1.403201] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[    1.404147] scsi host0: ahci-ceva
[    1.404384] scsi host1: ahci-ceva
[    1.404542] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 37
[    1.404565] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 37
[    1.404736] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.405632] m25p80 spi0.0: found n25q256a, expected n25q512a
[    1.405762] m25p80 spi0.0: n25q256a (65536 Kbytes)
[    1.405790] 3 ofpart partitions found on MTD device spi0.0
[    1.405804] Creating 3 MTD partitions on "spi0.0":
[    1.405821] 0x000000000000-0x000000100000 : "boot"
[    1.406408] 0x000000100000-0x000000140000 : "bootenv"
[    1.406931] 0x000000140000-0x000001740000 : "kernel"
[    1.408370] libphy: Fixed MDIO Bus: probed
[    1.409591] tun: Universal TUN/TAP device driver, 1.6
[    1.409611] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.409774] CAN device driver interface
[    1.410418] macb ff0e0000.ethernet: Not enabling partial store and forward
[    1.410969] libphy: MACB_mii_bus: probed
[    1.413358] macb ff0e0000.ethernet eth0: Could not attach to PHY
[    1.473611] usbcore: registered new interface driver asix
[    1.473675] usbcore: registered new interface driver ax88179_178a
[    1.473717] usbcore: registered new interface driver cdc_ether
[    1.473756] usbcore: registered new interface driver net1080
[    1.473795] usbcore: registered new interface driver cdc_subset
[    1.473836] usbcore: registered new interface driver zaurus
[    1.473888] usbcore: registered new interface driver cdc_ncm
[    1.474296] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.474312] ehci-pci: EHCI PCI platform driver
[    1.474562] usbcore: registered new interface driver uas
[    1.474612] usbcore: registered new interface driver usb-storage
[    1.474941] mousedev: PS/2 mouse device common for all mice
[    1.475384] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[    1.475438] i2c /dev entries driver
[    1.475670] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 32
[    1.476741] usbcore: registered new interface driver uvcvideo
[    1.476756] USB Video Class driver (1.1.1)
[    1.477331] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer at ffffff8008f8f000 with timeout 10s
[    1.477527] Bluetooth: HCI UART driver ver 2.3
[    1.477543] Bluetooth: HCI UART protocol H4 registered
[    1.477556] Bluetooth: HCI UART protocol BCSP registered
[    1.477569] Bluetooth: HCI UART protocol LL registered
[    1.477581] Bluetooth: HCI UART protocol ATH3K registered
[    1.477594] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    1.477646] Bluetooth: HCI UART protocol Intel registered
[    1.477697] Bluetooth: HCI UART protocol Broadcom registered
[    1.477711] Bluetooth: HCI UART protocol QCA registered
[    1.477760] usbcore: registered new interface driver bcm203x
[    1.477807] usbcore: registered new interface driver bpa10x
[    1.477855] usbcore: registered new interface driver bfusb
[    1.477901] usbcore: registered new interface driver btusb
[    1.477915] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    1.477980] usbcore: registered new interface driver ath3k
[    1.478119] EDAC MC: ECC not enabled
[    1.478293] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    1.478812] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1099999 KHz
[    1.478891] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1199999 KHz
[    1.479335] sdhci: Secure Digital Host Controller Interface driver
[    1.479349] sdhci: Copyright(c) Pierre Ossman
[    1.479361] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.524935] mmc0: SDHCI controller on ff170000.sdhci [ff170000.sdhci] using ADMA 64-bit
[    1.525153] ledtrig-cpu: registered to indicate activity on CPUs
[    1.525295] usbcore: registered new interface driver usbhid
[    1.525308] usbhid: USB HID core driver
[    1.527134] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    1.527671] xilinx-dp-snd-pcm dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
[    1.527722] xilinx-dp-snd-pcm dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
[    1.529040] Two devices are using vpll which is forbidden
[    1.529090] ------------[ cut here ]------------
[    1.529113] WARNING: CPU: 3 PID: 1 at /home/brianm/myproject/build/tmp/work-shared/plnx_aarch64/kernel-source/drivers/clk/zynqmp/pll.c:190 zynqmp_pll_set_rate+0x200/0x220
[    1.529142] Modules linked in:
[    1.529156]
[    1.529169] CPU: 3 PID: 1 Comm: swapper/0 Not tainted 4.9.0-xilinx-v2017.4 #1
[    1.529183] Hardware name: xlnx,zynqmp (DT)
[    1.529196] task: ffffffc06d866c00 task.stack: ffffffc06d868000
[    1.529210] PC is at zynqmp_pll_set_rate+0x200/0x220
[    1.529224] LR is at zynqmp_pll_set_rate+0x200/0x220
[    1.529237] pc : [<ffffff8008459aa0>] lr : [<ffffff8008459aa0>] pstate: 60000045
[    1.529255] sp : ffffffc06d86bb20
[    1.529266] x29: ffffffc06d86bb20 x28: 0000000000000000
[    1.529281] x27: ffffff8008c7e298 x26: ffffff8008d46000
[    1.529296] x25: 0000000001588800 x24: 0000000000000000
[    1.529311] x23: ffffffc06da4f410 x22: ffffffc06da5d500
[    1.529325] x21: 0000000001fca055 x20: 0000000001fca055
[    1.529340] x19: 000000008f8e0000 x18: 0000000000000010
[    1.529354] x17: 0000000000000000 x16: 0000000000000000
[    1.529369] x15: 0000000000000006 x14: ffffff8088d4b1d7
[    1.529383] x13: ffffff8008d4b1e5 x12: 0000000000000103
[    1.529398] x11: ffffffc06d86b880 x10: 0000000000000104
[    1.529412] x9 : 000000000000003d x8 : 2073692068636968
[    1.529427] x7 : 77206c6c70762067 x6 : ffffff8008d4b214
[    1.529441] x5 : ffffff800843f498 x4 : 0000000000000000
[    1.529455] x3 : 0000000000000000 x2 : 0000000000000532
[    1.529470] x1 : ffffff8008cca9c8 x0 : 000000000000002d
[    1.529484]
[    1.529496] ---[ end trace 9fefda757a61c6c8 ]---
[    1.529509] Call trace:
[    1.529521] Exception stack(0xffffffc06d86b950 to 0xffffffc06d86ba80)
[    1.529536] b940:                                   000000008f8e0000 0000008000000000
[    1.529558] b960: ffffffc06d86bb20 ffffff8008459aa0 ffffff8008d4d5f8 000000000000002d
[    1.529580] b980: ffffffc06d86b9a0 ffffff80080d908c ffffff8008d4ac68 ffffff8008aeb9e8
[    1.529601] b9a0: ffffffc06d86ba40 ffffff80080d9364 000000008f8e0000 0000000001fca055
[    1.529623] b9c0: 0000000001fca055 ffffffc06da5d500 ffffffc06da4f410 0000000000000000
[    1.529645] b9e0: 0000000001588800 ffffff8008d46000 000000000000002d ffffff8008cca9c8
[    1.529666] ba00: 0000000000000532 0000000000000000 0000000000000000 ffffff800843f498
[    1.529688] ba20: ffffff8008d4b214 77206c6c70762067 2073692068636968 000000000000003d
[    1.529709] ba40: 0000000000000104 ffffffc06d86b880 0000000000000103 ffffff8008d4b1e5
[    1.529730] ba60: ffffff8088d4b1d7 0000000000000006 0000000000000000 0000000000000000
[    1.529752] [<ffffff8008459aa0>] zynqmp_pll_set_rate+0x200/0x220
[    1.529769] [<ffffff80084547d8>] clk_change_rate+0x1e0/0x238
[    1.529785] [<ffffff8008454890>] clk_core_set_rate_nolock+0x60/0xc8
[    1.529800] [<ffffff8008454920>] clk_set_rate+0x28/0x58
[    1.529816] [<ffffff8008734b88>] xilinx_dp_codec_probe+0xd8/0x1e8
[    1.529833] [<ffffff8008504940>] platform_drv_probe+0x58/0xc0
[    1.529850] [<ffffff8008502de4>] driver_probe_device+0x1fc/0x2a8
[    1.529865] [<ffffff8008502f3c>] __driver_attach+0xac/0xb0
[    1.529881] [<ffffff8008500e34>] bus_for_each_dev+0x64/0xa0
[    1.529896] [<ffffff80085025d0>] driver_attach+0x20/0x28
[    1.529911] [<ffffff8008502120>] bus_add_driver+0x110/0x230
[    1.529926] [<ffffff8008503720>] driver_register+0x60/0xf8
[    1.529940] [<ffffff8008504878>] __platform_driver_register+0x40/0x48
[    1.529959] [<ffffff8008c60f8c>] xilinx_dp_codec_driver_init+0x18/0x20
[    1.529975] [<ffffff80080830b8>] do_one_initcall+0x38/0x128
[    1.529991] [<ffffff8008c30c94>] kernel_init_freeable+0x140/0x1e0
[    1.530006] [<ffffff80089462d8>] kernel_init+0x10/0x100
[    1.530020] [<ffffff8008082e80>] ret_from_fork+0x10/0x50
[    1.530638] Write failed to divider address:fd1a007c
[    1.530816] xilinx-dp-snd-codec dp_snd_codec0: Xilinx DisplayPort Sound Codec probed
[    1.531246] xilinx-dp-snd-card dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[    1.531393] xilinx-dp-snd-card dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[    1.531780] xilinx-dp-snd-card dp_snd_card: Xilinx DisplayPort Sound Card probed
[    1.531905] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    1.535014] Netfilter messages via NETLINK v0.30.
[    1.535146] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.535210] Initializing XFRM netlink socket
[    1.535272] NET: Registered protocol family 10
[    1.537718] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    1.537775] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.538165] NET: Registered protocol family 17
[    1.538187] NET: Registered protocol family 15
[    1.538212] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    1.538235] Ebtables v2.0 registered
[    1.538293] can: controller area network core (rev 20120528 abi 9)
[    1.538340] NET: Registered protocol family 29
[    1.538353] can: raw protocol (rev 20120528)
[    1.538366] can: broadcast manager protocol (rev 20161123 t)
[    1.538382] can: netlink gateway (rev 20130117) max_hops=1
[    1.539886] Bluetooth: RFCOMM TTY layer initialized
[    1.539904] Bluetooth: RFCOMM socket layer initialized
[    1.539923] Bluetooth: RFCOMM ver 1.11
[    1.539939] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    1.539951] Bluetooth: BNEP filters: protocol multicast
[    1.539967] Bluetooth: BNEP socket layer initialized
[    1.539980] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.539995] Bluetooth: HIDP socket layer initialized
[    1.540167] 9pnet: Installing 9P2000 support
[    1.540194] Key type dns_resolver registered
[    1.540634] registered taskstats version 1
[    1.542359] Btrfs loaded, crc32c=crc32c-generic
[    1.548187] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 39, base_baud = 6249999) is a xuartps
[    1.661541] mmc0: error -84 whilst initialising SD card
[    1.723614] ata2: SATA link down (SStatus 0 SControl 330)
[    1.723649] ata1: SATA link down (SStatus 0 SControl 330)
[    3.527756] console [ttyPS0] enabled
[    3.531686] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 40, base_baud = 6249999) is a xuartps
[    3.545528] PLL: shutdown
Re: UltraZed-EG Starter Kit hangs during Linux boot
hi @bmagnusen
Great to see that you got the previous issue resolved. PLL Shutdown is due to clock used in the vivado design, Are you using a custom vivadohdf exported to petalinux ?
If so ,
then you neet to changes the clocks DPLL and VPLL assignments.
Go to vivado desgn and open ultrascale block --> Clock Configuration
You should then select "Output Clocks" and expand Advance Clocks.
there is a known issue : AR # 69764 : https://www.xilinx.com/support/answers/69764.html
under advance clocks you need to find and change the TOPSW_MAIN to DPLL and DP_VIDEO to VPLL.
original post : https://forums.xilinx.com/t5/Xilinx-Boards-and-Kits/PLL-shutdown-when-Display-Port-is-enabled-in-the-devicetree/td-p/785164
hi @bmagnusen
If so ,
In AR https://www.xilinx.com/support/answers/69764.html
Please read the note.
  • DDR PLL (DPLL): mainly used to generate clocks for the DDR controller.
  • APU PLL (APLL): mainly used to generate clocks for the APU.
  • RPU PLL (RPLL): mainly used to generate clocks for the RPU.
  • I/O PLL (IOPLL): mainly used to generate clocks for the peripheral I/Os
  • Video PLL (VPLL): generates clocks for the video blocks used in the PS subsystem.
Sandeep
Ultrazed-EG/IOCC
Tools version 2018.2
None of these suggestions or references fixed their bug for me.
Bummer!
