Ultrascale+ Uboot-xlnx not initialing after FSBL
using Vivado 2017.2  to generate the FSBL.elf and the using the u-boot-xlnx from github, branch 2017.2.
I am not using the petalinux tool, I am loading my own root file system.
the .bif file assigns the following config:
the_ROM_image:
         [fsbl_config]a53_x64
          [bootloader]./path to /folder/projectName.sdk/fsbl/Debug/fsbl.elf
          [pmufw_image]./path to/folder/ProjectName.sdk/firmware/Debug/firmware.elf
          [destination_cpu = a53-0]./u-boot-xlnx/u-boot.elf
The FSBL loads correctly as shown:
Xilinx Zynq MP First Stage Boot Loader
Release 2017.2 Aug 16 2018 - 17:29:19
Reset Mode : System Reset
Platform: Silicon (4.0), Cluster ID 0x80000000
Running on A53-0 (64-bit) Processor, Device Name: XCZU9EG
Board Configuration successful
Processor Initialization Done
================= In Stage 2 ============
SD1 with level shifter Boot Mode
SD: rc= 0
File name is BOOT.BIN
Multiboot Reg : 0x0
Image Header Table Offset 0x8C0
*****Image Header Table Details********
Boot Gen Ver: 0x1020000
No of Partitions: 0x2
Partition Header Address: 0x440
Partition Present Device: 0x0
Initialization Success
======= In Stage 3, Partition No:1 =======
UnEncrypted data Length: 0x3E69A
Data word offset: 0x3E69A
Total Data word length: 0x3E69A
Destination Load Address: 0x8000000
Execution Address: 0x8000000
Data word offset: 0xF590
Partition Attributes: 0x116
Partition 1 Load Success
All Partitions Loaded
================= In Stage 4 ============
PM Init Success
Protection configuration applied
Running Cpu Handoff address: 0x8000000, Exec State: 0
Exit from FSBL
It gets stock here, u-boot should print that is started loading. But I don't actually get any prints from u-boot.
Is it possible that the FSBL not finding u-boot in address 0x8000000?
I running blind here!! I was looking at the XSCT console from the SDk to try to print the values of the addresses over JTAG, not sure if this would help.
Any ideas?
Re: Ultrascale+ Uboot-xlnx not initialing after FSBL
I solved it. At first I was building the ATF firmware on the master branch, and then I tried building it on the xilinx-v2018.3 tag. But my SDK version is 2018.2. Switching to the xilinx-v2018.2 tag of the arm-trusted-firmware allowed it to boot.
I am having the exact same problem. Did you ever solve this?
At least, you forget about bl31 AKA atf (ARM Trusted Firmware)
If you dont want to use the petalinux, then you can use the OSL flow here:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841722/ZCU102+Image+creation+in+OSL+flow
Can you share your defconfig for your uboot? what is the address here?
I am using the xilinx_zynqmp_zcu102_rev1_0_defconfig with no other changes. The load address is 0x8000000.
I tried booting again using bl31.elf instead of bl31.bin and I got something new:
  ATF running on XCZU9EG/silicon v4/RTL5.1 at 0xfffea000
NOTICE:  BL31: Secure code at 0x0
NOTICE:  BL31: Non secure code at 0x8000000
NOTICE:  BL31: v1.5(release):xilinx-v2018.3
NOTICE:  BL31: Built : 07:01:47, Feb  7 2019
ERROR:   BL31: Platform Management API version error. Expected: v1.1 - Found: v1.0
ERROR:   Error initializing runtime service sip_svc
PMUFW is not found - Please load it!
### ERROR ### Please RESET the board ###
I built bl31.elf from the source git repo using tag xilinx-v2018.3 so I don't know why there is a version mismatch. I also am using the PMU firmware from the SDK and it is definitely installed in my BOOT.bin, so not sure why it's saying it's not found.
Here is my BIF file:
//arch = zynqmp; split = false; format = BIN
the_ROM_image:
	[bootloader]D:\Workspace\arcs_zcu102\arcs_zcu102.sdk\fsbl\Debug\fsbl.elf
	[pmufw_image]D:\Workspace\arcs_zcu102\arcs_zcu102.sdk\pmu_fw\Debug\pmu_fw.elf
	[destination_device = pl]D:\Workspace\arcs_zcu102\arcs_zcu102.sdk\arcs_wrapper_hw_platform_0\arcs_wrapper.bit
	[destination_cpu = a53-0, exception_level = el-3, trustzone]D:\Workspace\arcs_zcu102\bl31.elf
	[destination_cpu = a53-0, exception_level = el-2]D:\Workspace\arcs_zcu102\u-boot.elf
You're talking about U-Boot. I'm talking about ARM Trusted Firmware for ZynqMP. It's a mandatory component.
Did you read my last reply? I have ATF (bl31.elf) included.
Sorry, missed it. Try "manual" boot of the system. Boot sequence mentioned in this topic. And please share your console output during this "manual" startup
