VitisAiFPGA
Ultrascale boot issue (dma)
    Using petalinux tool, I created BOOT.BIN and image.ub for our customed board. While booting the system with sd card, Something Wrong occers. I don't know how to fix it, Can anyone give me a hand. I will very appreciate it.
The device tree was generated by petalinux, And I didn't change it.
amba_pl: amba_pl@0 {
#address-cells = <2>;
#size-cells = <2>;
compatible = "simple-bus";
ranges ;
axi_vdma_1: dma@a0005000 {
#dma-cells = <1>;
clock-names = "s_axi_lite_aclk", "m_axi_mm2s_aclk", "m_axis_mm2s_aclk", "m_axi_s2mm_aclk", "s_axis_s2mm_aclk";
clocks = <&zynqmp_clk 71>, <&zynqmp_clk 72>, <&zynqmp_clk 72>, <&zynqmp_clk 72>, <&zynqmp_clk 72>;
compatible = "xlnx,axi-vdma-6.3", "xlnx,axi-vdma-1.00.a";
interrupt-names = "mm2s_introut", "s2mm_introut";
interrupt-parent = <&gic>;
interrupts = <0 89 4 0 90 4>;
reg = <0x0 0xa0005000 0x0 0x1000>;
xlnx,addrwidth = <0x20>;
xlnx,flush-fsync = <0x1>;
xlnx,num-fstores = <0x3>;
dma-channel@a0005000 {
compatible = "xlnx,axi-vdma-mm2s-channel";
interrupts = <0 89 4>;
xlnx,datawidth = <0x8>;
xlnx,device-id = <0x0>;
xlnx,genlock-mode ;
xlnx,include-dre ;
dma-channel@a0005030 {
compatible = "xlnx,axi-vdma-s2mm-channel";
interrupts = <0 90 4>;
xlnx,include-dre ;
Here's the log:
Device: mmc@ff170000
Manufacturer ID: 27
OEM: 5048
Bus Speed: 50000000
Mode : SD High Speed (50MHz)
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 14.5 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
24807640 bytes read in 1612 ms (14.7 MiB/s)
Using 'conf@system-top.dtb' configuration
Trying 'kernel@1' kernel subimage
Description: Linux kernel
Type: Kernel Image
Compression: uncompressed
Data Start: 0x100000f8
Data Size: 18082304 Bytes = 17.2 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x00080000
Entry Point: 0x00080000
Hash algo: sha1
Hash value: c36c1e5a41389c67782f3a6b8949f5c7b8439f2b
## Loading ramdisk from FIT Image at 10000000 ...
Trying 'ramdisk@1' ramdisk subimage
Description: petalinux-user-image
Type: RAMDisk Image
Compression: gzip compressed
Data Start: 0x1114689c
Data Size: 6691499 Bytes = 6.4 MiB
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: sha1
Hash value: 9058188d0722e0c5749f6645e5528914d880c949
Trying 'fdt@system-top.dtb' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Data Start: 0x1113ebfc
Data Size: 31708 Bytes = 31 KiB
Hash algo: sha1
Hash value: 1df3b077577c8c6694835ef7428f8283a7353aeb
Booting using the fdt blob at 0x1113ebfc
Loading Kernel Image ... OK
Loading Ramdisk to 7899e000, end 78fffaab ... OK
Loading Device Tree to 0000000007ff5000, end 0000000007fffbdb ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 4.19.0-xilinx-v2019.2 (oe-user@oe-host) (gcc versi0
[ 0.000000] Machine model: xlnx,zynqmp
[ 0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[ 0.000000] bootconsole [cdns0] enabled
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 256 MiB at 0x0000000068800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] random: get_random_bytes called from start_kernel+0x94/0x3f8 wit0
[ 0.000000] percpu: Embedded 23 pages/cpu @(____ptrval____) s53656 r8192 d328
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1034240
[ 0.000000] Kernel command line: earlycon console=ttyPS0,115200 clk_ignore_ud
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 byte)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] software IO TLB: mapped [mem 0x7bfff000-0x7ffff000] (64MB)
[ 0.000000] Memory: 3777412K/4194304K available (10748K kernel code, 634K rw)
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 33.33MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycless
[ 0.000003] sched_clock: 56 bits at 33MHz, resolution 30ns, wraps every 2199s
[ 0.008168] Console: colour dummy device 80x25
[ 0.012390] Calibrating delay loop (skipped), value calculated using timer f)
[ 0.022667] pid_max: default: 32768 minimum: 301
[ 0.027346] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.033922] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.041643] ASID allocator initialised with 32768 entries
[ 0.046412] rcu: Hierarchical SRCU implementation.
[ 0.051351] EFI services will not be available.
[ 0.055726] smp: Bringing up secondary CPUs ...
[ 0.060366] Detected VIPT I-cache on CPU1
[ 0.060391] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.060668] Detected VIPT I-cache on CPU2
[ 0.060685] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.060944] Detected VIPT I-cache on CPU3
[ 0.060961] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.061000] smp: Brought up 1 node, 4 CPUs
[ 0.095586] SMP: Total of 4 processors activated.
[ 0.100259] CPU features: detected: 32-bit EL0 Support
[ 0.106519] CPU: All CPU(s) started at EL2
[ 0.109437] alternatives: patching kernel code
[ 0.114635] devtmpfs: initialized
[ 0.120080] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
[ 0.126823] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.137874] xor: measuring software checksum speed
[ 0.177018] 8regs : 2639.000 MB/sec
[ 0.217044] 8regs_prefetch: 2280.000 MB/sec
[ 0.257070] 32regs : 3027.000 MB/sec
[ 0.297098] 32regs_prefetch: 2565.000 MB/sec
[ 0.297138] xor: using function: 32regs (3027.000 MB/sec)
[ 0.301438] pinctrl core: initialized pinctrl subsystem
[ 0.307170] NET: Registered protocol family 16
[ 0.311254] audit: initializing netlink subsys (disabled)
[ 0.316456] audit: type=2000 audit(0.264:1): state=initialized audit_enabled1
[ 0.324116] cpuidle: using governor menu
[ 0.328075] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval__)
[ 0.335344] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.342694] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.359648] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.426819] raid6: int64x1 gen() 497 MB/s
[ 0.494820] raid6: int64x1 xor() 500 MB/s
[ 0.562894] raid6: int64x2 gen() 757 MB/s
[ 0.630880] raid6: int64x2 xor() 665 MB/s
[ 0.698936] raid6: int64x4 gen() 1089 MB/s
[ 0.766975] raid6: int64x4 xor() 818 MB/s
[ 0.835023] raid6: int64x8 gen() 1294 MB/s
[ 0.903049] raid6: int64x8 xor() 843 MB/s
[ 0.971135] raid6: neonx1 gen() 818 MB/s
[ 1.039130] raid6: neonx1 xor() 977 MB/s
[ 1.107175] raid6: neonx2 gen() 1254 MB/s
[ 1.175223] raid6: neonx2 xor() 1303 MB/s
[ 1.243287] raid6: neonx4 gen() 1645 MB/s
[ 1.311303] raid6: neonx4 xor() 1575 MB/s
[ 1.379369] raid6: neonx8 gen() 1706 MB/s
[ 1.447402] raid6: neonx8 xor() 1623 MB/s
[ 1.447439] raid6: using algorithm neonx8 gen() 1706 MB/s
[ 1.451392] raid6: .... xor() 1623 MB/s, rmw enabled
[ 1.456322] raid6: using neon recovery algorithm
[ 1.461568] SCSI subsystem initialized
[ 1.464794] usbcore: registered new interface driver usbfs
[ 1.470106] usbcore: registered new interface driver hub
[ 1.475380] usbcore: registered new device driver usb
[ 1.480427] media: Linux media interface: v0.10
[ 1.484887] videodev: Linux video capture interface: v2.00
[ 1.490339] pps_core: LinuxPPS API ver. 1 registered
[ 1.495248] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
[ 1.504340] PTP clock support registered
[ 1.508239] EDAC MC: Ver: 3.0.0
[ 1.511678] zynqmp-ipi-mbox mailbox@ff990400: Probed ZynqMP IPI Mailbox driv.
[ 1.518830] FPGA manager framework
[ 1.522104] Advanced Linux Sound Architecture Driver Initialized.
[ 1.528276] Bluetooth: Core ver 2.22
[ 1.531591] NET: Registered protocol family 31
[ 1.535991] Bluetooth: HCI device and connection manager initialized
[ 1.542308] Bluetooth: HCI socket layer initialized
[ 1.547150] Bluetooth: L2CAP socket layer initialized
[ 1.552179] Bluetooth: SCO socket layer initialized
[ 1.557262] clocksource: Switched to clocksource arch_sys_counter
[ 1.563139] VFS: Disk quotas dquot_6.6.0
[ 1.567001] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.577622] NET: Registered protocol family 2
[ 1.578428] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 327)
[ 1.585941] TCP established hash table entries: 32768 (order: 6, 262144 byte)
[ 1.593266] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 1.600001] TCP: Hash tables configured (established 32768 bind 32768)
[ 1.606197] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 1.612174] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 1.618646] NET: Registered protocol family 1
[ 1.623036] RPC: Registered named UNIX socket transport module.
[ 1.628726] RPC: Registered udp transport module.
[ 1.633392] RPC: Registered tcp transport module.
[ 1.638062] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.644762] Trying to unpack rootfs image as initramfs...
[ 1.896979] Freeing initrd memory: 6532K
[ 1.897340] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 1.902508] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters ae
[ 1.910845] Initialise system trusted keyrings
[ 1.914534] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[ 1.921497] NFS: Registering the id_resolver key type
[ 1.925899] Key type id_resolver registered
[ 1.930038] Key type id_legacy registered
[ 1.934021] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.940687] jffs2: version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
[ 2.925531] NET: Registered protocol family 38
[ 2.978903] Key type asymmetric registered
[ 2.978941] Asymmetric key parser 'x509' registered
[ 2.982247] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[ 2.989563] io scheduler noop registered
[ 2.993452] io scheduler deadline registered
[ 2.997722] io scheduler cfq registered (default)
[ 3.002363] io scheduler mq-deadline registered
[ 3.006861] io scheduler kyber registered
[ 3.011732] xilinx-vdma a0005000.dma: failed to get axi_aclk (-517)
[ 3.041217] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 3.044554] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 3.052011] brd: module loaded
[ 3.055514] loop: module loaded
[ 3.056165] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 3.061719] libphy: Fixed MDIO Bus: probed
[ 3.065723] tun: Universal TUN/TAP device driver, 1.6
[ 3.069712] CAN device driver interface
[ 3.074209] usbcore: registered new interface driver asix
[ 3.078819] usbcore: registered new interface driver ax88179_178a
[ 3.084854] usbcore: registered new interface driver cdc_ether
[ 3.090651] usbcore: registered new interface driver net1080
[ 3.096273] usbcore: registered new interface driver cdc_subset
[ 3.102154] usbcore: registered new interface driver zaurus
[ 3.107696] usbcore: registered new interface driver cdc_ncm
[ 3.113873] usbcore: registered new interface driver uas
[ 3.118599] usbcore: registered new interface driver usb-storage
[ 3.124988] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rt0
[ 3.131762] i2c /dev entries driver
[ 3.136478] usbcore: registered new interface driver uvcvideo
[ 3.140886] USB Video Class driver (1.1.1)
[ 3.145296] Bluetooth: HCI UART driver ver 2.3
[ 3.149367] Bluetooth: HCI UART protocol H4 registered
[ 3.154466] Bluetooth: HCI UART protocol BCSP registered
[ 3.159760] Bluetooth: HCI UART protocol LL registered
[ 3.164845] Bluetooth: HCI UART protocol ATH3K registered
[ 3.170223] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 3.176471] Bluetooth: HCI UART protocol Intel registered
[ 3.181817] Bluetooth: HCI UART protocol QCA registered
[ 3.187015] usbcore: registered new interface driver bcm203x
[ 3.192637] usbcore: registered new interface driver bpa10x
[ 3.198174] usbcore: registered new interface driver bfusb
[ 3.203622] usbcore: registered new interface driver btusb
[ 3.209048] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 3.214709] usbcore: registered new interface driver ath3k
[ 3.220231] EDAC MC: ECC not enabled
[ 3.223864] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac contro)
[ 3.236371] sdhci: Secure Digital Host Controller Interface driver
[ 3.241919] sdhci: Copyright(c) Pierre Ossman
[ 3.246242] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.252107] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.257874] zynqmp_firmware_probe Platform Management API v1.1
[ 3.263632] zynqmp_firmware_probe Trustzone version v1.0
[ 3.290410] zynqmp_clk_mux_get_parent() getparent failed for clock: lpd_wdt,2
[ 3.293032] alg: No test for xilinx-zynqmp-aes (zynqmp-aes)
[ 3.298236] zynqmp_aes zynqmp_aes: AES Successfully Registered
[ 3.298236]
[ 3.305720] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
[ 3.311849] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
[ 3.317435] usbcore: registered new interface driver usbhid
[ 3.322780] usbhid: USB HID core driver
[ 3.328571] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[ 3.333307] usbcore: registered new interface driver snd-usb-audio
[ 3.339844] pktgen: Packet Generator for packet performance testing. Version5
[ 3.346989] Initializing XFRM netlink socket
[ 3.350960] NET: Registered protocol family 10
[ 3.355625] Segment Routing with IPv6
[ 3.359015] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 3.365107] NET: Registered protocol family 17
[ 3.369238] NET: Registered protocol family 15
[ 3.373653] bridge: filtering via arp/ip/ip6tables is no longer available by.
[ 3.386568] can: controller area network core (rev 20170425 abi 9)
[ 3.392727] NET: Registered protocol family 29
[ 3.397085] can: raw protocol (rev 20170425)
[ 3.401322] can: broadcast manager protocol (rev 20170425 t)
[ 3.406946] can: netlink gateway (rev 20170425) max_hops=1
[ 3.412447] Bluetooth: RFCOMM TTY layer initialized
[ 3.417244] Bluetooth: RFCOMM socket layer initialized
[ 3.422351] Bluetooth: RFCOMM ver 1.11
[ 3.426064] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.431337] Bluetooth: BNEP filters: protocol multicast
[ 3.436529] Bluetooth: BNEP socket layer initialized
[ 3.441458] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.447341] Bluetooth: HIDP socket layer initialized
[ 3.452366] 9pnet: Installing 9P2000 support
[ 3.456522] Key type dns_resolver registered
[ 3.461097] registered taskstats version 1
[ 3.464816] Loading compiled-in X.509 certificates
[ 3.469852] Btrfs loaded, crc32c=crc32c-generic
[ 3.479605] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 41, base_baud s
[ 3.489124] console [ttyPS0] enabled
[ 3.492723] bootconsole [cdns0] disabled
[ 3.500684] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 42, base_baud s
[ 3.513623] of-fpga-region fpga-full: FPGA Region probed
[ 3.519378] Internal error: synchronous external abort: 96000010 [#1] SMP
[ 3.526150] Modules linked in:
[ 3.529191] CPU: 2 PID: 32 Comm: kworker/2:1 Not tainted 4.19.0-xilinx-v20191
[ 3.536661] Hardware name: xlnx,zynqmp (DT)
[ 3.540836] Workqueue: events deferred_probe_work_func
[ 3.545959] pstate: 20000005 (nzCv daif -PAN -UAO)
[ 3.550735] pc : xilinx_dma_chan_reset+0x20/0x138
[ 3.555429] lr : xilinx_dma_probe+0x3a8/0x8f8
[ 3.559767] sp : ffffff800930bb00
[ 3.563066] x29: ffffff800930bb00 x28: ffffffc87b199c18
[ 3.568360] x27: ffffffc87b199a18 x26: 00000000006080c0
[ 3.573655] x25: ffffffc87fff5b28 x24: 0000000000000000
[ 3.578950] x23: ffffffc87bbd8810 x22: 0000000000000000
[ 3.584245] x21: ffffff8009128648 x20: ffffffc87fff5348
[ 3.589540] x19: ffffffc87b199a18 x18: 0000000000000001
[ 3.594835] x17: 0000000000000000 x16: 0000000000000000
[ 3.600130] x15: ffffffffffffffff x14: ffffff8009128648
[ 3.605424] x13: ffffff0000000000 x12: 0000000000000028
[ 3.610719] x11: 0101010101010101 x10: ffff7f7f7f7f7f7f
[ 3.616014] x9 : 0000000000000000 x8 : ffffffc87956d840
[ 3.621309] x7 : 0000000000000000 x6 : ffffffc87956da40
[ 3.626604] x5 : ffffffc87956da40 x4 : ffffffc87956dbc0
[ 3.631898] x3 : ffffffc87b199c30 x2 : ffffffc87b199a90
[ 3.637193] x1 : 0000000000000000 x0 : ffffff800924d000
[ 3.642490] Process kworker/2:1 (pid: 32, stack limit = 0x(____ptrval____))
[ 3.649432] Call trace:
[ 3.651865] xilinx_dma_chan_reset+0x20/0x138
[ 3.656205] xilinx_dma_probe+0x3a8/0x8f8
[ 3.660197] platform_drv_probe+0x50/0xa0
[ 3.664191] really_probe+0x1c8/0x280
[ 3.667837] driver_probe_device+0x54/0xe8
[ 3.671916] __device_attach_driver+0xb8/0xe8
[ 3.676256] bus_for_each_drv+0x78/0xc8
[ 3.680075] __device_attach+0xd4/0x130
[ 3.683894] device_initial_probe+0x10/0x18
[ 3.688061] bus_probe_device+0x90/0x98
[ 3.691880] deferred_probe_work_func+0x6c/0xa0
[ 3.696394] process_one_work+0x1e4/0x340
[ 3.700386] worker_thread+0x248/0x488
[ 3.704120] kthread+0x124/0x128
[ 3.707331] ret_from_fork+0x10/0x18
[ 3.710891] Code: b9400801 f9400000 f9400000 8b010000 (b9400000)
[ 3.716974] ---[ end trace b357d338c1edf66d ]---
VitisAiFPGA
Since nobody help me, I can only do it by myself. And I have fixed the problem. Here is some experiences to share.
    I found this is some problems on the PL side. The axi-interconnect IP core throw critical warning, I replaced the IP with a new one, And problem solved.
VitisAiFPGA
