Unable to Detect JEDEC ID of SPI Slave
Hardware: Enclustra Mercury+ XU1 (Built around Xilinx's Zynq Ultrascale+™ MPSoC)
I am trying to add spi node entry in DTS file (zynqmp-enclustra-xu1.dts):
Add Pin Mux in pinctrl_spi0_default
pinctrl_spi0_default: spi0-default {
mux {
groups = "spi0_0_grp";
function = "spi0";
conf {
bias-disable;
slew-rate = <SLEW_RATE_SLOW>;
io-standard = <IO_STANDARD_LVCMOS18>;
mux-cs {
groups = "spi0_0_ss0_grp", "spi0_0_ss1_grp",
"spi0_0_ss2_grp";
function = "spi0_ss";
conf-cs {
"spi0_0_ss2_grp";
bias-disable;
&spi0 {
status = "okay";
num-cs = <1>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_spi0_default>;
spi0_flash0: flash@0 {
#address-cells = <1>;
#size-cells = <1>;
compatible = "sst,sst25wf080", "jedec,spi-nor";
spi-max-frequency = <50000000>;
reg = <0>;
partition@0 {
label = "data";
reg = <0x0 0x100000>;
When i try to boot kernel then get following error:
# dmesg | grep spi
[ 2.273824] m25p80 spi0.0: unrecognized JEDEC id bytes: ff, ff, ff
Please help...
Re: Unable to Detect JEDEC ID of SPI Slave
Can you share the defconfig for this board? Can you share the the dtb too?
Also, the hdf to see the config in pcw.
Hi. Thank you for your attention to the topic.
These are my kernel configuration files and dts-file:
Ok, the dts (I only checked the spi node) looks fine based on the settings in the PCW. You have a 50Mhz clk, so 50 / 6 will be the clock used.
I think the issue is the defconfig. I can see a few missing configs. For example:
CONFIG_SPL_SPI_FLASH_SUPPORT=y
CONFIG_SPL_SPI_SUPPORT=y
CONFIG_ZYNQMP_QSPI=y
CONFIG_DM_SPI_FLASH=y
CONFIG_SPI_FLASH=y
CONFIG_SPI_FLASH_BAR=y
CONFIG_SPI_FLASH_ISSI=y
CONFIG_SPI_FLASH_MACRONIX=y
CONFIG_SPI_FLASH_SPANSION=y
CONFIG_SPI_FLASH_STMICRO=y
CONFIG_SPI_FLASH_WINBOND=y
You should compare this with a the zcu102 defconfig to see what is missing.
For debugging, you could enable the debug in the uboot:
https://github.com/Xilinx/u-boot-xlnx/blob/master/drivers/spi/Makefile
ccflags-y = -DDEBUG
Recompile and reboot and do a sf probe again to see the debug messages to get a better idea
of where exactly this is failing.
