Unable to autorun petalinux x11 app after autologin
Hello ,
I have created petalinux app which should start as soon as the auto login is done. But while auto-login part is working after :
petalinux-config
Select Yocto-settings --> Enable debug-tweaks
 the auto run is not working and i have to manualy go and start the app.
I used UG1144 pg 60 and Avnet github display port files (https://github.com/Avnet/petalinux/tree/master/configs/meta-user.uz3eg_iocc_dp/recipes-apps) to create my x11 tutorial.
I have attached the relevant files. (Added .sh files as text files due to upload error)
Also, when i try to execute the X11 tutorial mLinApp, it states cannot run XOpenDisplay,  while i have included lX11 and x11-mali but not sure how to configure those inside the petalinux-config ??
Any help is much appriciated.
regards
Vishal
Re: Unable to autorun petalinux x11 app after autologin
Hi @sandeepg
Thanks for helping out.
So found the mistake in my setup
Previously my boot args was :
earlycon earlyprintk clk_ignore_unused root=/dev/mmcblk0p2 rw rootwait uio_prdv_genirq.of_id=generic-uio cma=1024 rootfstype=ext4
Now i changed it to -
earlycon earlyprintk clk_ignore_unused root=/dev/mmcblk0p2 rw rootwait uio_prdv_genirq.of_id=generic-uio cma=1024M rootfstype=ext4
Also added the destro_feature_check in th bb file as suggested by you
and also i changed the depth to 24 instead of 16.. (read it here https://forums.xilinx.com/t5/Video/DisplayPort-no-picture-on-ZCU102/td-p/800388) as i am using a DELL monitor..
Found it out here :
http://www.wiki.xilinx.com/Zynq+UltraScale%EF%BC%8B+MPSoC+Ubuntu+part+2+-+Building+and+Running+the+Ubuntu+Desktop+From+Sources
Got the app working fine !
Could you please just explain what cma is doing here ?
regards
Vishal
Hi @vish.bh30,
Use the updated version of tricube recipe. I have asked Mario to update the same on Avnet repo.
Can you share <plnx-proj-root>/project-spec/meta-plnx-generated/recipes-core/images/petalinux-user-image.bb file?
Sandeep
Hi @sandeepg
Thanks for the tricube attachment, but I am really interesed to create my own X11 tutorial from the start. I would really appreciate if you can share the details on the steps to reproduce it as the X11 tutorial doesn't have it.
for the starters, i see recipes-graphics in the tricube repo but how do i add those in petalinux project using petalinux-config -c kernel ? There were like 2 or 3 different X11 libs so i was not sure which one to pick.
Do i need to do these :
$ Petalinux-config -c rootfs
enable the following packages:
Filesystem Packages > libs> libmali-xlnx > libmali-xlnx
Filesystem Packages > libs > libmali-xlnx > libmali-xlnx-dev
Filesystem Packages > misc > packagegroup-petalinux-x11 > packagegroup-petalinux-x11
Filesystem Packages > misc > packagegroup-petalinux-x11 > packagegroup-petalinux-x11-dev
or different ones and any other libs along with it ?
Hi @vish.bh30,
Please refer https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug1209-embedded-design-tutorial.pdf page 145-149
Did you tried running your application manually first then you add to startup application.
Sandeep
Hi @sandeepg
While i was able to create my own X11 based program and able to package it and run it / auto-run it after login. The program i created is not using openGL or EGL libs. While those are installed on my system and compiled in the rootfs folder .. when i run the tutorial you have mentioned i see nothing on the screen connected to the board ... the screen however does initializes but the rotating cube/triangle does not appear. i get the debug info on my terminal such as running dographics ... etc  but no activity on the actual screen.
Please let me know what is going on with the code.
Btw, i have not included recipes-graphics in my app folder and have tricube.c and .h files (+makefile and relevant changes to .bb file )
regards,
Vishal
Hi @vish.bh30,
When you mentioned you are NOT using OpenGL/EGL then which graphics libraries(mesa?) are you using.
Sandeep
Hi @sandeepg ,
for my own tutorial i just used Xlib.h as the tutorial is pretty basic. now i am trying to use the opengl libs so wanted to tryout the already existing demo but it is not working as i have stated above.
Hi @sandeepg
One additional info. When i tried to execute the X11 tutorial which i got from avnet github repo, It worked fine on my ubuntu system. but the same code when i try to build and deploy on the ultrazed shows blank screen. So there is no issue with the code but may be some settings ? or screen resolution ?. Please let me know your views.
here is what i get in terminal :
ng,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Mon Mar 19 17:11:13 2018
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
Start Main
Calling OpenDisplay
Calling XCreateSimpleWindow
Calling XStoreName
Calling XMapWindow
>> I am done so far.. now starting OpenGL graphics code...
Calling prepareGraphics
Calling eglGetDisplay
Display Used 0x1 & EGL versions are 1.4
Your EGL Version is "1.4 Linux-r7p0-00rel0"
Your EGL Vendor is "ARM"
[   18.050572] xilinx-drm xilinx_drm: failed to allocate buffer with size 1077248
Calling doGraphics
iLocPosition = 0
iLocColor   = 0
iLocMVP = 0
[   91.446901] random: crng init done
Vishal
Hi @vish.bh30,
Did you kill the Xorg before running the X11 application.
root@xilinx-zcu102-2017_2:~# killall Xorg
root@xilinx-zcu102-2017_2:~# export DISPLAY=:0.0
root@xilinx-zcu102-2017_2:~# /usr/bin/Xorg -depth 16&
Sandeep
Hi @sandeepg
Yes i did.
Please check the boot logs for the two different apps. For both the apps , Xorg is killed and the steps that you mentioned are followed. Still the plain X11 app starts fine while tricube does not.
Hi Vishal
I have cleaned up your apps recipe(See attachment). Also I see in your application you need to call below API's
XDestroyWindow(d, w);
XCloseDisplay(d);
Refer the hellox11 example which I have created.
I was able to run your application using petalinux on Ultrazed board(Refer Attachment). We don't use petalinux scripts from Avnet github to build the petalinux project. We usually create a template project using hdf and add the required components.
Xilinx Zynq MP First Stage Boot Loader
Release 2017.2   Mar 20 2018  -  20:43:58
NOTICE:  ATF running on XCZU3EG/silicon v4/RTL5.1 at 0xfffea000, with PMU firmware
NOTICE:  BL31: Secure code at 0x0
NOTICE:  BL31: Non secure code at 0x8000000
NOTICE:  BL31: v1.3(release):0d9d51a
NOTICE:  BL31: Built : 15:45:25, Mar 21 2018
U-Boot 2017.01 (Mar 21 2018 - 09:46:06 -0600) Xilinx ZynqMP ZCU102 rev1.0
I2C:   Error, wrong i2c adapter 0 max 0 possible
ready
DRAM:  2 GiB
EL Level:       EL2
Chip ID:        xczu3eg
MMC:   sdhci@ff160000: 0 (eMMC), sdhci@ff170000: 1 (SD)
SF: Detected n25q256a with page size 512 Bytes, erase size 128 KiB, total 64 MiB
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Bootmode: SD_MODE1
Net:   ZYNQ GEM: ff0e0000, phyaddr 9, interface rgmii-id
eth0: ethernet@ff0e0000
U-BOOT for avnet-uz3eg-iocc-dp-2017.2
ethernet@ff0e0000 Waiting for PHY auto negotiation to complete...... done
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
DHCP client bound to address 172.20.9.102 (928 ms)
Hit any key to stop autoboot:  0
Device: sdhci@ff160000
Manufacturer ID: 13
OEM: 14e
Tran Speed: 25000000
Rd Block Len: 512
MMC version 5.0
High Capacity: Yes
Capacity: 7.1 GiB
Bus Width: 8-bit
Erase Group Size: 512 KiB
HC WP Group Size: 8 MiB
User Capacity: 7.1 GiB WRREL
Boot Capacity: 16 MiB ENH
RPMB Capacity: 4 MiB ENH
reading image.ub
45764668 bytes read in 3057 ms (14.3 MiB/s)
## Loading kernel from FIT Image at 10000000 ...
   Using 'conf@1' configuration
   Trying 'kernel@0' kernel subimage
     Description:  Linux Kernel
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x100000d8
     Data Size:    13105160 Bytes = 12.5 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x00080000
     Entry Point:  0x00080000
     Hash algo:    sha1
     Hash value:   3a51d2517c9149df572d7621495e3b7126fd4615
   Verifying Hash Integrity ... sha1+ OK
## Loading ramdisk from FIT Image at 10000000 ...
   Trying 'ramdisk@0' ramdisk subimage
     Description:  ramdisk
     Type:         RAMDisk Image
     Data Start:   0x10c87cc0
     Data Size:    32624517 Bytes = 31.1 MiB
     OS:           Linux
     Load Address: unavailable
     Entry Point:  unavailable
     Hash algo:    sha1
     Hash value:   f6b419040e8f39ee1f687401c43d6dcd31829049
## Loading fdt from FIT Image at 10000000 ...
   Trying 'fdt@0' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Data Start:   0x10c7f9d8
     Data Size:    33332 Bytes = 32.6 KiB
     Hash algo:    sha1
     Hash value:   6be621474d00a6eab22165a28a68a7fca65f88ec
   Booting using the fdt blob at 0x10c7f9d8
   Loading Kernel Image ... OK
   Loading Ramdisk to 7bfab000, end 7dec7f85 ... OK
   Loading Device Tree to 000000007bf9f000, end 000000007bfaa233 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.0-xilinx-v2017.2 (sandeepg@xcoapps62) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP Tue Mar 20 20:37:26 MDT 2018
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[    0.000000] bootconsole [cdns0] enabled
[    0.000000] cma: Reserved 1024 MiB at 0x000000003bc00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] percpu: Embedded 21 pages/cpu @ffffffc07ff7a000 s46232 r8192 d31592 u86016
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 517120
[    0.000000] Kernel command line: earlycon clk_ignore_unused earlyprintk uio_pdrv_genirq.of_id=xlnx,generic-uio cma=1024M
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 970972K/2097152K available (8894K kernel code, 574K rwdata, 2844K rodata, 448K init, 583K bss, 77604K reserved, 1048576K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008930000   (  8896 KB)
[    0.000000]     .rodata : 0xffffff8008930000 - 0xffffff8008c00000   (  2880 KB)
[    0.000000]       .init : 0xffffff8008c00000 - 0xffffff8008c70000   (   448 KB)
[    0.000000]       .data : 0xffffff8008c70000 - 0xffffff8008cff808   (   575 KB)
[    0.000000]        .bss : 0xffffff8008cff808 - 0xffffff8008d914ac   (   584 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf01c00000   (    28 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc080000000   (  2048 MB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 99.99MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x171015c90f, max_idle_ns: 440795203080 ns
[    0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511101ns
[    0.008273] Console: colour dummy device 80x25
[    0.012533] console [tty0] enabled
[    0.015898] bootconsole [cdns0] disabled
[    0.019808] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.99 BogoMIPS (lpj=399996)
[    0.019823] pid_max: default: 32768 minimum: 301
[    0.019943] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.019954] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.020651] ASID allocator initialised with 65536 entries
[    0.021196] zynqmp_plat_init Power management API v0.3
[    0.021648] Detected VIPT I-cache on CPU1
[    0.021682] CPU1: Booted secondary processor [410fd034]
[    0.021967] Detected VIPT I-cache on CPU2
[    0.021986] CPU2: Booted secondary processor [410fd034]
[    0.022258] Detected VIPT I-cache on CPU3
[    0.022277] CPU3: Booted secondary processor [410fd034]
[    0.022315] Brought up 4 CPUs
[    0.022349] SMP: Total of 4 processors activated.
[    0.022358] CPU features: detected feature: 32-bit EL0 Support
[    0.022369] CPU: All CPU(s) started at EL2
[    0.022385] alternatives: patching kernel code
[    0.023173] devtmpfs: initialized
[    0.027925] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.053644] xor: measuring software checksum speed
[    0.092038]    8regs     :  2111.000 MB/sec
[    0.132069]    8regs_prefetch:  1882.000 MB/sec
[    0.172103]    32regs    :  2594.000 MB/sec
[    0.212137]    32regs_prefetch:  2181.000 MB/sec
[    0.212150] xor: using function: 32regs (2594.000 MB/sec)
[    0.212270] pinctrl core: initialized pinctrl subsystem
[    0.212971] NET: Registered protocol family 16
[    0.213927] Failed to initialise IOMMU /amba/smmu@fd800000
[    0.214126] vdso: 2 pages (1 code @ ffffff8008937000, 1 data @ ffffff8008c74000)
[    0.214154] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.214808] DMA: preallocated 256 KiB pool for atomic allocations
[    0.225551] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
[    0.225931] ARM CCI_400_r1 PMU driver probed
[    0.228087] Write failed gate address:1000f02
[    0.232654] zynqmp-pinctrl ff180000.pinctrl: zynqmp pinctrl initialized
[    0.252479] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.320398] raid6: int64x1  gen()   373 MB/s
[    0.388438] raid6: int64x1  xor()   406 MB/s
[    0.456499] raid6: int64x2  gen()   616 MB/s
[    0.524478] raid6: int64x2  xor()   549 MB/s
[    0.592566] raid6: int64x4  gen()   901 MB/s
[    0.660624] raid6: int64x4  xor()   678 MB/s
[    0.728676] raid6: int64x8  gen()  1050 MB/s
[    0.796729] raid6: int64x8  xor()   684 MB/s
[    0.864827] raid6: neonx1   gen()   663 MB/s
[    0.932846] raid6: neonx1   xor()   695 MB/s
[    1.000871] raid6: neonx2   gen()  1068 MB/s
[    1.068949] raid6: neonx2   xor()   949 MB/s
[    1.136993] raid6: neonx4   gen()  1380 MB/s
[    1.205039] raid6: neonx4   xor()  1083 MB/s
[    1.273133] raid6: neonx8   gen()  1454 MB/s
[    1.341165] raid6: neonx8   xor()  1119 MB/s
[    1.341177] raid6: using algorithm neonx8 gen() 1454 MB/s
[    1.341190] raid6: .... xor() 1119 MB/s, rmw enabled
[    1.341202] raid6: using intx1 recovery algorithm
[    1.341637] GPIO IRQ not connected
[    1.341650] XGpio: /amba_pl@0/gpio@80000000: registered, base is 330
[    1.341798] GPIO IRQ not connected
[    1.341811] XGpio: /amba_pl@0/gpio@80010000: registered, base is 322
[    1.341954] GPIO IRQ not connected
[    1.341967] XGpio: /amba_pl@0/gpio@80020000: registered, base is 319
[    1.342407] SCSI subsystem initialized
[    1.342659] usbcore: registered new interface driver usbfs
[    1.342709] usbcore: registered new interface driver hub
[    1.342771] usbcore: registered new device driver usb
[    1.342865] media: Linux media interface: v0.10
[    1.342906] Linux video capture interface: v2.00
[    1.342946] pps_core: LinuxPPS API ver. 1 registered
[    1.342959] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.342993] PTP clock support registered
[    1.343031] EDAC MC: Ver: 3.0.0
[    1.343288] FPGA manager framework
[    1.343338] Advanced Linux Sound Architecture Driver Initialized.
[    1.343669] Bluetooth: Core ver 2.22
[    1.343701] NET: Registered protocol family 31
[    1.343715] Bluetooth: HCI device and connection manager initialized
[    1.343732] Bluetooth: HCI socket layer initialized
[    1.343748] Bluetooth: L2CAP socket layer initialized
[    1.343779] Bluetooth: SCO socket layer initialized
[    1.344523] clocksource: Switched to clocksource arch_sys_counter
[    1.344619] VFS: Disk quotas dquot_6.6.0
[    1.344667] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.349455] NET: Registered protocol family 2
[    1.349864] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    1.349997] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    1.350297] TCP: Hash tables configured (established 16384 bind 16384)
[    1.350378] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    1.350431] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    1.350587] NET: Registered protocol family 1
[    1.350840] RPC: Registered named UNIX socket transport module.
[    1.350854] RPC: Registered udp transport module.
[    1.350866] RPC: Registered tcp transport module.
[    1.350878] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.351042] Trying to unpack rootfs image as initramfs...
[    2.857602] Freeing initrd memory: 31856K (ffffffc07bfab000 - ffffffc07dec7000)
[    2.857981] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    2.858725] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    2.858817] audit: initializing netlink subsys (disabled)
[    2.858871] audit: type=2000 audit(2.844:1): initialized
[    2.859440] workingset: timestamp_bits=62 max_order=19 bucket_order=0
[    2.860173] NFS: Registering the id_resolver key type
[    2.860202] Key type id_resolver registered
[    2.860214] Key type id_legacy registered
[    2.860232] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.860260] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    2.868711] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    2.868745] io scheduler noop registered
[    2.868758] io scheduler deadline registered
[    2.868777] io scheduler cfq registered (default)
[    2.869938] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[    2.870203] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[    2.870325] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[    2.870447] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[    2.870571] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[    2.870693] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[    2.870816] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[    2.870940] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[    2.871065] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[    2.871191] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[    2.871317] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[    2.871441] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[    2.871563] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[    2.871689] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[    2.871813] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[    2.871936] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[    2.872060] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[    2.872250] zynqmp_pm firmware: Power management API v0.3
[    2.903982] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    2.905287] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 214, base_baud = 6249999) is a xuartps
[    3.906632] console [ttyPS0] enabled
[    3.910465] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 215, base_baud = 6249999) is a xuartps
[    3.919704] [drm] Initialized
[    3.922965] [drm] load() is defered & will be called again
[    3.928796] PLL: shutdown
[    3.931453] xilinx-drm-dp-sub fd4aa000.dp_sub: Xilinx DisplayPort Subsystem is probed
[    3.939316] Unable to detect cache hierarchy from DT for CPU 0
[    3.950165] brd: module loaded
[    3.956245] loop: module loaded
[    3.960191] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[    3.969105] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[    3.979603] scsi host0: ahci-ceva
[    3.983073] scsi host1: ahci-ceva
[    3.986441] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 211
[    3.994377] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 211
[    4.002512] mtdoops: mtd device (mtddev=name/number) must be supplied
[    4.010583] libphy: Fixed MDIO Bus: probed
[    4.015912] tun: Universal TUN/TAP device driver, 1.6
[    4.020895] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    4.027174] CAN device driver interface
[    4.031947] libphy: MACB_mii_bus: probed
[    4.040109] macb ff0e0000.ethernet eth0: Could not attach to PHY
[    4.113230] usbcore: registered new interface driver asix
[    4.118603] usbcore: registered new interface driver ax88179_178a
[    4.124657] usbcore: registered new interface driver cdc_ether
[    4.130471] usbcore: registered new interface driver net1080
[    4.136113] usbcore: registered new interface driver cdc_subset
[    4.142015] usbcore: registered new interface driver zaurus
[    4.147584] usbcore: registered new interface driver cdc_ncm
[    4.153528] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.159982] ehci-pci: EHCI PCI platform driver
[    4.164669] usbcore: registered new interface driver cdc_acm
[    4.170249] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    4.178270] usbcore: registered new interface driver uas
[    4.183569] usbcore: registered new interface driver usb-storage
[    4.189805] mousedev: PS/2 mouse device common for all mice
[    4.195696] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[    4.202920] i2c /dev entries driver
[    4.206515] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 206
[    4.213339] at24 1-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[    4.220193] at24 1-0051: 4 byte 24mac402 EEPROM, read-only, 0 bytes/write
[    4.226969] idt5901_probe
[    4.229520] idt5901 1-006a: input-freq: 25000000 Hz
[    4.234379] idt5901 1-006a: settings property missing or error (-22). The settings property is optional.
[    4.243847] idt5901 1-006a: clk-freq: 75000000 Hz
[    4.248526] idt5901 1-006a: output-num: 4
[    4.252578] idt5901 1-006a: get_divs: got register offsets: int_div @ 0x5d, frac_div @ 0x52
[    4.262083] idt5901 1-006a: get_divs: 0x0 0x40 int_div: 4
[    4.267478] idt5901 1-006a: get_divs: 0x2 0x0 0x0 0x0 frac_div: 8388608
[    4.276030] idt5901 1-006a: idt5901_read_from_hw:vco. bypass: 1, prediv2: 0, ref_div: 3, fb_intdiv: 108, fb_fracdiv: 0, input freq: 25000000 Hz
[    4.288838] idt5901 1-006a: idt5901_read_from_hw: vco_freq: 2700000000 Hz. CLK_CONFIG [0x67]=0x1, OUTPUT_DIV_CTRL [0x51]=0x81, CLK_OS [0x69]=0xfc
[    4.301953] idt5901 1-006a: get_divs: got register offsets: int_div @ 0x5d, frac_div @ 0x52
[    4.310236] idt5901 1-006a: get_divs: 0x0 0x40 int_div: 4
[    4.313586] ata1: SATA link down (SStatus 0 SControl 330)
[    4.320987] idt5901 1-006a: get_divs: 0x2 0x0 0x0 0x0 frac_div: 8388608
[    4.323747] ata2: SATA link down (SStatus 0 SControl 330)
[    4.332968] idt5901 1-006a: recalc_rate. vco: 2700000000, intdiv: 4, fracdiv: 8388608, numer: 45298483200000000, denom: 150994944, result: 300000000
[    4.346332] idt5901 1-006a: input-freq: 25000000 Hz, output-num: 4, clk1-freq: 75000000 Hz
[    4.354530] idt5901 1-006a: calc_divs. intdiv: 18, remainder: 0, *2^24: 0
[    4.361289] idt5901 1-006a: calc_divs. frac: 0
[    4.365716] idt5901 1-006a: calc_divs. input: 75000000, vco: 2700000000,  int: 18, frac: 0
[    4.373971] idt5901 1-006a: I2C->0x5d : [hex] 1 20
[    4.379224] idt5901 1-006a: I2C->0x52 : [hex] 0 0 0 0
[    4.384741] idt5901 1-006a: set_frequency: CLKx_OS already set.
[    4.390589] idt5901 1-006a: set_frequency: EN_CLKBUFx already set.
[    4.396749] idt5901 1-006a: set_frequency: ODx_EN_FOD already set.
[    4.402910] idt5901 1-006a: I2C->0x76 : [hex] c3
[    4.407882] idt5901 1-006a: I2C->0x76 : [hex] e3
[    4.412800] idt5901 1-006a: get_divs: got register offsets: int_div @ 0x5d, frac_div @ 0x52
[    4.421091] idt5901 1-006a: get_divs: 0x1 0x20 int_div: 18
[    4.426547] idt5901 1-006a: get_divs: 0x0 0x0 0x0 0x0 frac_div: 0
[    4.432624] idt5901 1-006a: recalc_rate. vco: 2700000000, intdiv: 18, fracdiv: 0, numer: 45298483200000000, denom: 603979776, result: 75000000
[    4.445393] idt5901 1-006a: registered: output 75000000 Hz on CKL4
[    4.451557] i2c i2c-0: Added multiplexed i2c bus 1
[    4.456446] i2c i2c-0: Added multiplexed i2c bus 2
[    4.461166] pca954x 0-0070: registered 2 multiplexed busses for I2C switch pca9543
[    4.468891] vivid-000: using single planar format API
[    4.475934] vivid-000: V4L2 capture device registered as video0
[    4.481846] vivid-000: V4L2 output device registered as video1
[    4.487673] vivid-000: V4L2 capture device registered as vbi0, supports raw and sliced VBI
[    4.495935] vivid-000: V4L2 output device registered as vbi1, supports raw and sliced VBI
[    4.504107] vivid-000: V4L2 capture device registered as swradio0
[    4.510195] vivid-000: V4L2 receiver device registered as radio0
[    4.516190] vivid-000: V4L2 transmitter device registered as radio1
[    4.523466] usbcore: registered new interface driver uvcvideo
[    4.529136] USB Video Class driver (1.1.1)
[    4.533854] Bluetooth: HCI UART driver ver 2.3
[    4.538227] Bluetooth: HCI UART protocol H4 registered
[    4.543344] Bluetooth: HCI UART protocol BCSP registered
[    4.548638] Bluetooth: HCI UART protocol LL registered
[    4.553759] Bluetooth: HCI UART protocol ATH3K registered
[    4.559140] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    4.565432] Bluetooth: HCI UART protocol Intel registered
[    4.570812] Bluetooth: HCI UART protocol Broadcom registered
[    4.576415] Bluetooth: HCI UART protocol QCA registered
[    4.581660] usbcore: registered new interface driver bcm203x
[    4.587303] usbcore: registered new interface driver bpa10x
[    4.592857] usbcore: registered new interface driver bfusb
[    4.598325] usbcore: registered new interface driver btusb
[    4.603758] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    4.609460] usbcore: registered new interface driver ath3k
[    4.615016] EDAC MC: ECC not enabled
[    4.618655] EDAC DEVICE0: Giving out device to module edac controller cache_err: DEV edac (POLLED)
[    4.627714] EDAC DEVICE1: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    4.640042] sdhci: Secure Digital Host Controller Interface driver
[    4.646146] sdhci: Copyright(c) Pierre Ossman
[    4.650481] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.656286] PLL: enable
[    4.704534] mmc0: SDHCI controller on ff160000.sdhci [ff160000.sdhci] using ADMA 64-bit
[    4.760532] mmc1: SDHCI controller on ff170000.sdhci [ff170000.sdhci] using ADMA 64-bit
[    4.768682] ledtrig-cpu: registered to indicate activity on CPUs
[    4.776778] usbcore: registered new interface driver usbhid
[    4.782275] usbhid: USB HID core driver
[    4.788177] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    4.795028] xilinx-dp-snd-pcm amba:dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
[    4.802658] xilinx-dp-snd-pcm amba:dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
[    4.812216] Write failed to divider address:fd1a007c
[    4.817279] xilinx-dp-snd-codec amba:dp_snd_codec0: Xilinx DisplayPort Sound Codec probed
[    4.825816] xilinx-dp-snd-card amba:dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[    4.837986] xilinx-dp-snd-card amba:dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[    4.848351] xilinx-dp-snd-card amba:dp_snd_card: Xilinx DisplayPort Sound Card probed
[    4.856189] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    4.866095] mmc0: new HS200 MMC card at address 0001
[    4.866103] Netfilter messages via NETLINK v0.30.
[    4.866224] ip_tables: (C) 2000-2006 Netfilter Core Team
[    4.866276] Initializing XFRM netlink socket
[    4.875679] NET: Registered protocol family 10
[    4.881013] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    4.881056] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    4.881443] NET: Registered protocol family 17
[    4.881454] NET: Registered protocol family 15
[    4.881468] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    4.881470] Ebtables v2.0 registered
[    4.881521] can: controller area network core (rev 20120528 abi 9)
[    4.881556] NET: Registered protocol family 29
[    4.881559] can: raw protocol (rev 20120528)
[    4.881561] can: broadcast manager protocol (rev 20161123 t)
[    4.881566] can: netlink gateway (rev 20130117) max_hops=1
[    4.885261] Bluetooth: RFCOMM TTY layer initialized
[    4.885269] Bluetooth: RFCOMM socket layer initialized
[    4.885278] Bluetooth: RFCOMM ver 1.11
[    4.885283] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    4.885285] Bluetooth: BNEP filters: protocol multicast
[    4.885291] Bluetooth: BNEP socket layer initialized
[    4.885293] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.885298] Bluetooth: HIDP socket layer initialized
[    4.885477] 9pnet: Installing 9P2000 support
[    4.885495] Key type dns_resolver registered
[    4.885891] registered taskstats version 1
[    4.909252] mmc1: new high speed SDHC card at address aaaa
[    4.909514] mmcblk1: mmc1:aaaa SL08G 7.40 GiB (ro)
[    4.910589]  mmcblk1: p1
[    4.936929] Btrfs loaded, crc32c=crc32c-generic
[    4.944260] [drm] load() is defered & will be called again
[    4.944955] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:8 protocol:4 pll_locked:yes
[    4.945207] xilinx-drm-dp fd4a0000.dp: device found, version 4.010
[    4.945211] xilinx-drm-dp fd4a0000.dp: Display Port, version 1.0200 (tx)
[    4.945959] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.945973] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    4.946218] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x00010010
[    4.946243] xhci-hcd xhci-hcd.0.auto: irq 220, io mem 0xfe200000
[    4.946356] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.946361] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.946364] usb usb1: Product: xHCI Host Controller
[    4.946367] usb usb1: Manufacturer: Linux 4.9.0-xilinx-v2017.2 xhci-hcd
[    4.946370] usb usb1: SerialNumber: xhci-hcd.0.auto
[    4.946653] hub 1-0:1.0: USB hub found
[    4.946673] hub 1-0:1.0: 1 port detected
[    4.946798] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.946807] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    4.946846] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.946906] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    4.946910] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.946914] usb usb2: Product: xHCI Host Controller
[    4.946917] usb usb2: Manufacturer: Linux 4.9.0-xilinx-v2017.2 xhci-hcd
[    4.946920] usb usb2: SerialNumber: xhci-hcd.0.auto
[    4.947153] hub 2-0:1.0: USB hub found
[    4.947170] hub 2-0:1.0: 1 port detected
[    4.947821] OF: graph: no port node found in /amba/xilinx_drm
[    4.947825] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    4.947827] [drm] No driver support for vblank timestamp query.
[    5.191653] idt5901 1-006a: calc_divs. intdiv: 5, remainder: 72500000, *2^24: 1216348160000000
[    5.191658] idt5901 1-006a: calc_divs. frac: 2314649
[    5.191663] idt5901 1-006a: calc_divs. input: 262750000, vco: 2700000000,  int: 5, frac: 2314649
[    5.191669] idt5901 1-006a: I2C->0x5d : [hex] 0 50
[    5.191672] mmcblk0: mmc0:0001 Q2J55L 7.09 GiB
[    5.191782] mmcblk0boot0: mmc0:0001 Q2J55L partition 1 16.0 MiB
[    5.191892] mmcblk0boot1: mmc0:0001 Q2J55L partition 2 16.0 MiB
[    5.191991] mmcblk0rpmb: mmc0:0001 Q2J55L partition 3 4.00 MiB
[    5.192110] idt5901 1-006a: I2C->0x52 : [hex] 0 8d 46 64
[    5.192522] idt5901 1-006a: set_frequency: CLKx_OS already set.
[    5.192525] idt5901 1-006a: set_frequency: EN_CLKBUFx already set.
[    5.192528] idt5901 1-006a: set_frequency: ODx_EN_FOD already set.
[    5.192532] idt5901 1-006a: I2C->0x76 : [hex] c3
[    5.192902]  mmcblk0: p1
[    5.192906] idt5901 1-006a: I2C->0x76 : [hex] e3
[    5.193282] idt5901 1-006a: get_divs: got register offsets: int_div @ 0x5d, frac_div @ 0x52
[    5.193291] idt5901 1-006a: get_divs: 0x0 0x50 int_div: 5
[    5.193295] idt5901 1-006a: get_divs: 0x0 0x8d 0x46 0x64 frac_div: 2314649
[    5.193301] idt5901 1-006a: recalc_rate. vco: 2700000000, intdiv: 5, fracdiv: 2314649, numer: 45298483200000000, denom: 172401458, result: 262750000
[    5.324058] Console: switching to colour frame buffer device 480x135
[    5.510117] random: fast init done
[    5.561297] xilinx-drm amba:xilinx_drm: fb0:  frame buffer device
[    5.580532] [drm] Initialized xilinx_drm 1.0.0 20130509 on minor 0
[    5.587021] rtc_zynqmp ffa60000.rtc: setting system clock to 2018-03-21 22:19:17 UTC (1521670757)
[    5.596107] clk: Not disabling unused clocks
[    5.600384] ALSA device list:
[    5.603330]   #0: DisplayPort monitor
[    5.607591] Freeing unused kernel memory: 448K (ffffffc000c00000 - ffffffc000c70000)
INIT: version 2.88 booting
Starting udev
[    5.745379] udevd[1675]: starting version 3.2
[    5.754444] udevd[1676]: starting eudev-3.2
[    5.814402] mali: loading out-of-tree module taints kernel.
Populating dev cache
Starting internet superserver: inetd.
Running postinst /etc/rpm-postinsts/100-sysvinit-inittab...
Running postinst /etc/rpm-postinsts/101-locale-base-en-gb...
cannot create temporary file: /usr/lib/locale/locale-archive.gHP7jV: No such file or directory
Running postinst /etc/rpm-postinsts/102-xserver-nodm-init...
usage: update-rc.d [-n] [-f] [-r <root>] <basename> remove
       update-rc.d [-n] [-r <root>] [-s] <basename> defaults [NN | sNN kNN]
       update-rc.d [-n] [-r <root>] [-s] <basename> start|stop NN runlvl [runlvl] [...] .
INIT: Entering runlevel: 5
Configuring network interfaces... ifconfig: SIOCGIFFLAGS: No such device
Starting system message bus: dbus.
Starting Dropbear SSH server: Generating key, this may take a while...
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCh/uFihRopY8XedD8crUkHlTiih7i4WYXm7Yatf/WJrTyUQQmjpoiVWwUvMcbnM0nAqZ/X85NGfKVE87DSwz1R/D44EPTzmhxVdT+q/v5lJ5VrWY3+3ER2+XBcG85UWmKT/pIYY1/fUI+RChxhgnK9Ax7fxXTWt+rAMTeW+642x4llQ8Mw4s4pbIP8Q+sg6XDDPgZDy5Q2FkVBrX5xmzFBs9asbkhJLGhzfhE0LljTbtW05BMUKUUjvBsiM23EAcki/DBXUVIH4pCEZToBsZUN0FkaznOa0XvplYTG6Zjph8baMGEX+YZ1li1jsU00KQqOPYrGwRn+dx1a7UmveVZN root@avnet-uz3eg-iocc-dp-2017.2
Fingerprint: md5 30:ed:ee:c4:e2:d9:8b:dd:6c:24:ea:13:bd:c6:71:ea
dropbear.
Starting syslogd/klogd: done
Starting tcf-agent: OK
PetaLinux 2017.2 avnet-uz3eg-iocc-dp-2017.2 /dev/ttyPS0
avnet-uz3eg-iocc-dp-2017.2 login: root
Password:
root@avnet-uz3eg-iocc-dp-2017:~#
root@avnet-uz3eg-iocc-dp-2017:~# killall Xorg
killall: Xorg: no process killed
root@avnet-uz3eg-iocc-dp-2017:~# export DISPLAY=:0.0
root@avnet-uz3eg-iocc-dp-2017:~# /usr/bin/Xorg -depth 16&
[1] 2104
X.Org X Server 1.18.4
Release Date: 2016-07-19
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.32-573.el6.x86_64 x86_64
Current Operating System: Linux avnet-uz3eg-iocc-dp-2017.2 4.9.0-xilinx-v2017.2 #1 SMP Tue Mar 20 20:37:26 MDT 2018 aarch64
Build Date: 19 June 2017  09:37:47PM
Current version of pixman: 0.34.0
        Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Mar 21 22:20:07 2018
root@avnet-uz3eg-iocc-dp-2017:~# mLinApp
>>> Hello World!!!!  from mLinAPP -------
>>> Start ...
^C
root@avnet-uz3eg-iocc-dp-2017:~# Xorg: ../../xorg-server-1.18.4/include/privates.h:122: dixGetPrivateAddr: Assertion `key->initialized' failed.
[1]+  Aborted                 /usr/bin/Xorg -depth 16
Sandeep
Hi sandeepg
I am so sorry for the confusion, but the code you executed works fine for me... it is the tricube application given out by xilinx/avnet which is not working ..
the tricube code i found from here : https://github.com/Avnet/petalinux/tree/master/configs/meta-user.uz3eg_iocc_dp/recipes-apps
I made the project similar to what you guys did, and not using the project script from avnet  and creating my own from the scratch. I just used this tricube cpp and .h file code from the github repo.
The diff is i just use runtricube.sh script to start the app instead of all the trd files. This approach was working fine with the code you executed but when i modifies the script to start the tricube app, it gave me the issue i mentioned earlier in the thread.
Also i do not have reciepe-graphics included in my app repo.
i'll try you code as well but, i am switching between the x11 app  and tricube app when i update the runtricube script.
Update:
here are some pics that i captured which will help to understand what is happening :
1. tricube application running on my ubuntu system:
2. when i run the same application in the board :
The green screen is something i have added to verify is the code is running or not at all ... the green screen is part of X11 lib code portion. The code after it which make use of openGL tricube to display rotating cube / triangle does not show up unlike on my ubuntu system.
regards,
Vishal
Hi Vishal,
This is what I heard from Avnet 6 months back when I asked for supported monitors and they support below monitors tested with Ultrazed.
Currently Ultrazed doesn't support 1080p monitors running OpenGL applications but we do support 1080p monitors with ZCU102/ZCU106 boards.
Monitors:
Make/Model
Native Resolution
Viewsonic VP2780-4K
3840x2160 (60/30Hz)
Acer S277HK
3840x2160 (60/30Hz)
Dell P2415Q
3840x2160 (30Hz)
SAMSUNG U24E590D
3840x2160
Dell 2415Qb
3840x2160 (30Hz)
I have Dell 2415Qb and I can run tricube application.
Also I have Dell 2414Hb(1080p) where I can run same tricube application with ZCU102 board but not with Ultrazed.
Password:
[1] 2104
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Mar 21 22:17:44 2018
root@avnet-uz3eg-iocc-dp-2017:~# tricube
Start Main
Calling OpenDisplay
Calling XStoreName
Calling XMapWindow
Calling doGraphics
iLocPosition = 0
iLocColor   = 1
iLocMVP = 0
^C
Sandeep
Hi @sandeepg
Found it out here :
regards
Vishal
Hi @vish.bh30,
Contiguous Memory Allocator (CMA) in linux is a framework, which allows setting up a machine-specific configuration for physically-contiguous memory management. Memory for devices is then allocated according to that configuration.
On any embedded systems have no scatter-getter and/or IO map support and as such require contiguous blocks of memory to operate. For example in  cameras, hardware video decoders and encoders, etc. Such devices often require big memory buffers (a full HD frame is more than 2 mega pixels large, i.e. more than 6 MB of memory), which makes kmalloc() as ineffective.
Refer kernel docs https://www.kernel.org/doc/html/v4.14/admin-guide/kernel-parameters.html
CMA is optional for running simple GPU application. I don't use on ZCU102 board to run tricube application.
Avnet Ultrazed uses video_ea linux branch https://github.com/Xilinx/linux-xlnx/tree/2017.2_video_ea to support some video IP they are using CMA in bootargs.
Sandeep
