Unable to boot Linux , maybe it's about uEnv.txt file ?
Hello friends !
Now I wanna boot a Linux on ZC706 . I have BOOT.bin , devicetree.dtb , uramdisk.image.gz and uImage files (but no uEnv.txt file) for zc706. And I have a Linux project aimed at booting Linux on zedboard which has uEnv.txt file and files mentioned above . They are proved to be useful on zedboard (Linux boots successfully using these files).
I can not boot Linux on zc706 , so I watch through the messages when I try to boot it , and compare the messages with those of zedboard .
(The whole message files of them will be uploaded witn .txt)
What is below is some messages of zedboard . I can't understand the sentences which is bold type . Does it mean the zedboard didn't boot the Linux according to the uEnv.txt file and turn to a default u-boot configuration ?
----------------------Separator Line of Zedboard---------------
(Some messages)
reading uEnv.txt
388 bytes read in 10 ms (37.1 KiB/s)
Loaded environment from uEnv.txt
Importing environment from SD ...
Running uenvcmd ...
Copying Linux from SD to RAM...
reading uImage
4106112 bytes read in 238 ms (16.5 MiB/s)
reading devicetree.dtb
13541 bytes read in 16 ms (826.2 KiB/s)
reading uramdisk.image.gz
19242207 bytes read in 1069 ms (17.2 MiB/s)
Wrong Image Format for bootm command
ERROR: can't get kernel image!
reading uImage
## Booting kernel from Legacy Image at 02080000 ...
Image Name: Linux-4.9.0-g5899204-dirty
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 4106048 Bytes = 3.9 MiB
Load Address: 00008000
Entry Point: 00008000
Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 04000000 ...
Image Name:
Image Type: ARM Linux RAMDisk Image (gzip compressed)
Data Size: 19242143 Bytes = 18.4 MiB
Load Address: 00000000
Entry Point: 00000000
## Flattened Device Tree blob at 02000000
Booting using the fdt blob at 0x2000000
Loading Kernel Image ... OK
Loading Ramdisk to 1d8bf000, end 1eb18c9f ... OK
Loading Device Tree to 1d8b8000, end 1d8be4e4 ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
(Some messages)
------------------------Separator Line of Zedboard-----------------------------
What is below is some error messages from zc706 , looks like the board did't find the uEnv.txt but still boot the Linux , is that right ?
I make some sentences bold type , is that the reason which makes booting Linux fail ?
-------------------------------Separator Line of zc706--------------------------
(some messages)
** Unable to read file uEnv.txt **
reading uImage
4321368 bytes read in 253 ms (16.3 MiB/s)
13563 bytes read in 17 ms (778.3 KiB/s)
26164156 bytes read in 1444 ms (17.3 MiB/s)
Image Name: Linux-4.14.0
Data Size: 4321304 Bytes = 4.1 MiB
Image Name:
Data Size: 26164092 Bytes = 25 MiB
Loading Ramdisk to 1e70c000, end 1ffffb7c ... OK
Loading Device Tree to 1e705000, end 1e70b4fa ... OK
Starting kernel ...
(省略)
Unhandled fault: imprecise external abort (0x406) at 0x00000000
pgd = c0004000
[00000000] *pgd=00000000
Internal error: : 406 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.14.0 #1
Hardware name: Xilinx Zynq Platform
task: ef03f840 task.stack: ef040000
PC is at axi_clkgen_mmcm_read+0x20/0x80
LR is at axi_clkgen_get_div+0x20/0x90
pc : [<c033af8c>] lr : [<c033b00c>] psr: a0000013
sp : ef041dc8 ip : dec0de1c fp : 00000000
r10: 00000000 r9 : c0b6c720 r8 : c08a41a0
r7 : 0883d3b6 r6 : c08a3dac r5 : 00000008 r4 : ef223290
r3 : 00002710 r2 : ef041ddc r1 : 00000009 r0 : ef223290
Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
Control: 18c5387d Table: 0000404a DAC: 00000051
Process swapper/0 (pid: 1, stack limit = 0xef040210)
Stack: (0xef041dc8 to 0xef042000)
1dc0: ef223290 00000008 c08a3dac c033b00c ef006300 ef223cc0
1de0: c0b6c720 00000001 ef223290 c033b130 c0b6c720 c0334c60 00000000 00000001
1e00: ef25fb00 c08a3dac ef223294 c08a41a0 c0b6c720 c0336d08 ef223294 c0336854
1e20: ef223294 ef223950 ef168610 ef223294 ef168610 ef223290 00000000 c0337068
1e40: ef223294 ef168600 ef041e54 c033ae4c ef7f62b8 de706831 c08fc07c ef7f62b8
1e60: c072d244 ef041e54 c0b6dc01 00000003 ef168610 ffffffed c0b1369c fffffdfb
1e80: 00000000 c03b26d4 ef168610 c0b6dc4c c0b6dc50 c0b1369c 00000000 c03b0ef4
1ea0: ef168610 c0b1369c ef168644 00000000 000000c6 c0a3083c c0a3adb0 c03b1048
1ec0: 00000000 c0b1369c c03b0fa4 c03af454 ef075f58 ef104ab4 c0b1369c ef0a9b80
1ee0: c0b18198 c03b0454 c08a46a0 00000000 c0a1687c c0b1369c 00000000 c0a1687c
1f00: c0b4e680 c03b18f0 ffffe000 00000000 c0a1687c c0101a20 c093fe3c 000000c6
1f20: 00000000 c0138578 00000000 c08bfc58 00000006 00000006 c0888f18 00000000
1f40: c0891924 c0888f8c efffce09 00000000 00000000 00000007 c0b4e680 c0a30830
1f60: 00000007 c0b4e680 c0a30834 c0b4e680 000000c6 c0a00dc0 00000006 00000006
1f80: 00000000 c0a005a8 00000000 c06b13d0 00000000 00000000 00000000 00000000
1fa0: 00000000 c06b13d8 00000000 c0107a30 00000000 00000000 00000000 00000000
1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
1fe0: 00000000 00000000 00000000 00000000 00000013 00000000 0191040d 11000243
[<c033af8c>] (axi_clkgen_mmcm_read) from [<c033b00c>] (axi_clkgen_get_div+0x20/0x90)
[<c033b00c>] (axi_clkgen_get_div) from [<c033b130>] (axi_clkgen_recalc_rate+0x20/0xec)
[<c033b130>] (axi_clkgen_recalc_rate) from [<c0336d08>] (clk_register+0x330/0x640)
[<c0336d08>] (clk_register) from [<c0337068>] (devm_clk_hw_register+0x3c/0x84)
[<c0337068>] (devm_clk_hw_register) from [<c033ae4c>] (axi_clkgen_probe+0x140/0x180)
[<c033ae4c>] (axi_clkgen_probe) from [<c03b26d4>] (platform_drv_probe+0x50/0xac)
[<c03b26d4>] (platform_drv_probe) from [<c03b0ef4>] (driver_probe_device+0x238/0x2e8)
[<c03b0ef4>] (driver_probe_device) from [<c03b1048>] (__driver_attach+0xa4/0xa8)
[<c03b1048>] (__driver_attach) from [<c03af454>] (bus_for_each_dev+0x4c/0x9c)
[<c03af454>] (bus_for_each_dev) from [<c03b0454>] (bus_add_driver+0x188/0x20c)
[<c03b0454>] (bus_add_driver) from [<c03b18f0>] (driver_register+0x78/0xf4)
[<c03b18f0>] (driver_register) from [<c0101a20>] (do_one_initcall+0x44/0x168)
[<c0101a20>] (do_one_initcall) from [<c0a00dc0>] (kernel_init_freeable+0x148/0x1d4)
[<c0a00dc0>] (kernel_init_freeable) from [<c06b13d8>] (kernel_init+0x8/0x108)
[<c06b13d8>] (kernel_init) from [<c0107a30>] (ret_from_fork+0x14/0x24)
Code: 0a000018 e590c000 e59cc074 f57ff04f (e31c0801)
---[ end trace e54b4a34e906ff48 ]---
Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
CPU0: stopping
CPU: 0 PID: 0 Comm: swapper/0 Tainted: G D 4.14.0 #1
[<c010edbc>] (unwind_backtrace) from [<c010b6f4>] (show_stack+0x10/0x14)
[<c010b6f4>] (show_stack) from [<c069f0a4>] (dump_stack+0x8c/0xa0)
[<c069f0a4>] (dump_stack) from [<c010d4dc>] (ipi_cpu_stop+0x64/0x74)
[<c010d4dc>] (ipi_cpu_stop) from [<c010dc1c>] (handle_IPI+0x6c/0x7c)
[<c010dc1c>] (handle_IPI) from [<c0101464>] (gic_handle_irq+0x8c/0x90)
[<c0101464>] (gic_handle_irq) from [<c010c20c>] (__irq_svc+0x6c/0xa8)
Exception stack(0xc0b01f40 to 0xc0b01f88)
1f40: 00000001 00000000 00000000 c01179e0 ffffe000 c0b03cb4 c0b03c68 c0a42a48
1f60: c0b48ee0 00000000 00000000 00000000 2ed8e000 c0b01f90 c0108480 c0108484
1f80: 60000013 ffffffff
[<c010c20c>] (__irq_svc) from [<c0108484>] (arch_cpu_idle+0x38/0x3c)
[<c0108484>] (arch_cpu_idle) from [<c0150e14>] (do_idle+0x16c/0x1f8)
[<c0150e14>] (do_idle) from [<c0151148>] (cpu_startup_entry+0x18/0x1c)
[<c0151148>] (cpu_startup_entry) from [<c0a00c6c>] (start_kernel+0x394/0x3a0)
[<c0a00c6c>] (start_kernel) from [<0000807c>] (0x807c)
---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
---------------------------Separator Line of zc706-------------------------------------
I'm confused by :
(1) Does zedboard boot the Linux according to uEnv.txt ? If YES , I think I do need a uEnv.txt for zc706 (but I don't know how to write one , this is the most embarrassing part ... ) . If NO , I think I don't need a uEnv.txt for zc706 , is that right ?
(2) What does the error messages from zc706 mean ? Is there something wrong with my fpga_project.bit , or something else ?
My question is a bit long , thanks a lot for your time !
How you are building the images. Using yocto flow? Try building the images through petalinux and see if this works
Best Regards
Shabbir
Thanks a lot for your reply !
I built the kernel image using ADI's kernel image tool : https://github.com/analogdevicesinc/linux . In fact , I'm trying to build a Linux to run v4l2 on board and the ADI's kernel image has USB's and video capture's driver with it . I don't know how to modify the configuration of petalinux to make the image.ub support the driver , so I turn to ADI's .
Best Regards !
Hi !
This is the ADI's wiki which I learn to build kernel image : https://wiki.analog.com/resources/eval/user-guides/ad-fmcomms2-ebz/software/linux/zynq_2014r2 .
Here is the steps I built kernel according to the wiki:
(1) make zynq_xcomm_adv7511_defconfig
(2) make -j5 UIMAGE_LOADADDR=0x8000 uImage
So the error probably comes from kernel image ? I will focus on it .
Perhaps you can give me a guide about how to configure the petalinux to support v4l2 ?
Best Regards !
