kganesh90
Unable to boot linux using load address
I want to boot linux from the SD card on my Xilinx Zynq Zturn board.My bif file is as follows.
//arch = zynq; split = false; format = BIN
the_ROM_image:
[bootloader]C:\Users\ganes\Desktop\Zturn\GPIO_Loopback\Encryption\BOOT\fsbl.elf
C:\Users\ganes\Desktop\Zturn\GPIO_Loopback\Encryption\Encrypted-From_Disc\design_1_wrapper.bit
C:\Users\ganes\Desktop\Zturn\GPIO_Loopback\Encryption\BOOT\u-boot.elf
[load = 0x2000000]C:\Users\ganes\Desktop\Zturn\GPIO_Loopback\Encryption\Backup-SD\devicetree.dtb
[load = 0x2080000]C:\Users\ganes\Desktop\Zturn\GPIO_Loopback\Encryption\Backup-SD\uImage
[load = 0x4000000]C:\Users\ganes\Desktop\Zturn\GPIO_Loopback\Encryption\Backup-SD\uramdisk.image.gz
The load addresses were obtained from the config file of u-boot which was used to build u-boot. These were the default address. Nothing changed.
I generated the BOOT.bin and put it on to the SD card. But it does not boot at all. I just see black screen with fpga configured with the given bitstream.  What might be wrong?
kganesh90
Thanks for the response. I got this working. The issue was in the uEnv.txt file. I could load u-boot but for some reason, u-boot was throwing an error "Unable to read uEnv.txt" . Later I added a custom uEnv.txt file along with BOOT.bin on SD card and I got the linux booted and running just fine as expected.
shabbirk
Did you check whether boot mode pins are properly for SD card?
Best Regards
Shabbir
trigger
Have you try to change ramdisk load address :
dow -data uImage 0x3A00000
dow -data uramdisk.image.gz 0x2000000
dow -data zynq-board.dtb 0x3900000
dow u-boot.elf
0x4000000 - 0x390000 --> 7Mo max size for u-boot
You should also try to load u-boot only and test to boot before load everything else.
Keep in touch,
Trigger
debrajr
To understand this the first option should be to turn on Debug prints in FSBL. You can go to SDK, select FSBL and add a macro -DFSBL_DEBUG_INFO. It would print the FSBL log and we can check further. If you are not getting the FSBL print also then try to use a simple hello world type application and FSBL. It should print that. If that is also not happening, then do cross verify the SD boot mode settings to see if it is fine or not. Let us know how it goes.
Debraj
kganesh90
