betanken
Unable to change rootfs
Hallo all,
I have installed petalinux and successfully boot. Now I want use ubuntu rootfs because later a software will be installed on board.
I read ug1144 and use the command in page 49.
$ cd /media/rootfs
$ tar ubuntu-base-16.04.5-base-arm64.tar.gz
Because I have found ubuntu file-system on the website of ubuntu(ubuntu-base-16.04.5-base-arm64). So I copied it in to /media/rootfs of sd card.
But the board still use rootfs of Petalinux.....I don't know why.
Does someone have experience?
diego73
@betanken, yes. In the project you are defining the 0p1 partition, and in the boot arg the 0p2.
Please fix it to 0p2 and let me know.
No problems with your English, I perfectly understood.
/* Don't forget to give kudos and/or accept as a solution */
diego73
Hi @betanken
This scenario could be because you are compiling the rootfs in the ramdisk, so the image.ub will boot the Petalinux rootfs as defined in the kernel boot args, and will ignore what you put int the ext4 partition of the SD card.
Can you check if your rootfs option in Petalinux is set to "SD Card" instead of "ramdisk"?.
I've tried ubuntu rootfs on my Zynq 7020 thousand of times and I see no issues.
betanken
Hallo @diego73
Thanks for reply!
I'm using SD card in rootfs. Maybe the settings are wrong? The rootfs of Ubuntu is in 2rd partition of sd card, so perhaps I should change "Device node of sd device" into "/dev/mmcblk0p2"?
 I sawed another answer, they solved it use
set env bootargs 'console=ttyPS0,115200n8 root=/dev/mmcblk0p2 rw  rootfstype=ext4 rootwait'
But its still doesn't for me....
Thanks for help and forgive me for my bad english
diego73
betanken
Hallo @diego73
and is it possible to use command like apt-get when I use ubuntu rootfs?
Thanks for reply
diego73
Yes, it is possible, just make sure to update the repos first:
$ apt-get update
hokim
There is some booting problem in using original ubuntu base
Use tar.gz output file of the attached script.
It adds additional packages to original tar.gz to remove booting problem.
betanken
Hallo @diego73
I solved the problem, thanks.
May I ask how to configure the network of ubuntu? I mean, I'm using ubuntu rootfs now. I have tried to use $apt-get update, but its failed.
Here the errors:
All packages are up to date.
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/xenial/InRelease  Temporary failure resolving 'ports.ubuntu.com'
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/xenial-updates/InRelease  Temporary failure resolving 'ports.ubuntu.com'
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/xenial-security/InRelease  Temporary failure resolving 'ports.ubuntu.com'
W: Some index files failed to download. They have been ignored, or old ones used instead
I found something about configuration of network.
I write the flowing lines in /etc/network/interface.d/eth0,but I think its not enough,maybe I should add address and netmask in it?
                     auto eth0
                     iface eth0 inet static
Thanks a lot for help
betanken
Hallo @hokim
Its not the problem...
But thanks for reply
trigger
Voyager
Voyager
Hi@betanken,
Several things:
You said your problem is solved isn't ?
1. provide more information for others
2. mark the thread as resolved
3. Could you please open a new thread to ask your network question ?
PS: i'm not a cops but it's a mess...
Cheers,
Trigger
betanken
Hi @trigger
sorry I forgot to do it.
Because he @diego73 said that he used ubuntu rootfs many times. And its maybe easy for me to get an answer from him.
trigger
Voyager
Voyager
Hi @betanken
No problem ;)
Cheers,
Trigger
diego73
Hi @betanken
I think folks are right, may you open a new thread and I promise I'll put a guide on what you are having problems, if still are present.
BTW, thanks for the kudo, I answer much but got few :).
