jonesyx
Unable to compile drivers
Ive been working through the "Embedded open-source linux development" materials and labs from Xilinx and am able to compile my own kernel and programs for an embedded target (ml507) however im coming into problems compiling drivers for the board.
I keep getting errors such as the following:
[mjones@desectlws004 hellodriver]$ make
make ARCH=ppc CROSS_COMPILE=powerpc-linux-uclibc- -C /home/mjones/emb_linux/kernel/work M=/home/mjones/emb_linux/kernel/work/drivers/hellodriver modules
make[1]: Entering directory `/home/mjones/emb_linux/kernel/linux_xilinx/2.6.25'
  CC [M]  /home/mjones/emb_linux/kernel/work/drivers/hellodriver/hello.o
  Building modules, stage 2.
  MODPOST 1 modules
WARNING: "printk" [/home/mjones/emb_linux/kernel/work/drivers/hellodriver/hello.ko] undefined!
  CC      /home/mjones/emb_linux/kernel/work/drivers/hellodriver/hello.mod.o
/home/mjones/emb_linux/kernel/work/drivers/hellodriver/hello.mod.c:8: error: variable ‘__this_module’ has initializer but incomplete type
/home/mjones/emb_linux/kernel/work/drivers/hellodriver/hello.mod.c:9: error: unknown field ‘name’ specified in initializer
/home/mjones/emb_linux/kernel/work/drivers/hellodriver/hello.mod.c:9: warning: excess elements in struct initializer
/home/mjones/emb_linux/kernel/work/drivers/hellodriver/hello.mod.c:9: warning: (near initialization for ‘__this_module’)
/home/mjones/emb_linux/kernel/work/drivers/hellodriver/hello.mod.c:10: error: unknown field ‘init’ specified in initializer
/home/mjones/emb_linux/kernel/work/drivers/hellodriver/hello.mod.c:10: warning: excess elements in struct initializer
/home/mjones/emb_linux/kernel/work/drivers/hellodriver/hello.mod.c:10: warning: (near initialization for ‘__this_module’)
/home/mjones/emb_linux/kernel/work/drivers/hellodriver/hello.mod.c:14: error: unknown field ‘arch’ specified in initializer
/home/mjones/emb_linux/kernel/work/drivers/hellodriver/hello.mod.c:14: error: ‘MODULE_ARCH_INIT’ undeclared here (not in a function)
/home/mjones/emb_linux/kernel/work/drivers/hellodriver/hello.mod.c:14: warning: excess elements in struct initializer
/home/mjones/emb_linux/kernel/work/drivers/hellodriver/hello.mod.c:14: warning: (near initialization for ‘__this_module’)
make[2]: *** [/home/mjones/emb_linux/kernel/work/drivers/hellodriver/hello.mod.o] Error 1
make[1]: *** [modules] Error 2
make[1]: Leaving directory `/home/mjones/emb_linux/kernel/linux_xilinx/2.6.25'
make: *** [all] Error 2
My Makefile is the following:
obj-m += hello.o
KDIR=/home/mjones/emb_linux/kernel/work
EXTRA_CFLAGS := -I$(KDIR)/include
all:
    make ARCH=ppc CROSS_COMPILE=powerpc-linux-uclibc- -C $(KDIR) M=$(PWD) modules
clean:
    make ARCH=ppc CROSS_COMPILE=powerpc-linux-uclibc- -C $(KDIR) M=$(PWD) clean
hello.c is the following:
#include <linux/module.h>
#include <linux/kernel.h>
#include <linux/init.h>
MODULE_LICENSE("GPL");
static int hello_init(void) {
  printk("<1> Hello world!\n");
  return 0;
static void hello_exit(void) {
  printk("<1> Bye, cruel world\n");
module_init(hello_init);
module_exit(hello_exit);
And the paths are as follows:
Folder of mydriver (hello.c) = /home/mjones/emb_linux/kernel/work/drivers/hellodriver
Folder of kernel work = /home/mjones/emb_linux/kernel/work or ($WORK/kernel/work)
Ive tried combinations of the paths and nothing seems to work. The powerpc-linux-uclibc-gcc works and I have compiled simple c programs with it.
Any help would be greatly appreciated.
Many Thanks
Michael.
linnj
You need to get a clean tree and start from scratch.  I'm sorry to say, but I don't know the instructions that you are following there.  I have seen a course materials from Xilinx but it's been a long time, maybe it's out of date (sorry).
The wiki is the place that I can be sure of.  When you switch architectures like that, you may need to do make ARCH=.... mrproper as there are links in the kernel tree that must be setup corrrectly.
You need to get a good baseline (clean kernel tree from git) and follow the wiki to get the baseline. It should build and run on the Xilinx boards right out of the box.
-- John
linnj
Hi Michael,
ARCH=ppc is your problem.  ARCH ppc is no longer supported, you should be using ARCH=powerpc.  I'm not sure what documentation you're using, but the wiki, at http://xilinx.wikidot.com, should reflect that.
Give it a try and that should help.
John
jonesyx
Well that make a difference, im not sure if good or bad: Compilation throws up even more errors now :
- See attached txt file, too big to post now.
Im using the "Embedded Open-Source Linux Development" workbook (embd22000-10-wkbp-rev1) from xilinx.
I set an envirnonment variable at the start ARCH=ppc however all the tools ive used such as the compiler are powerpc. Now ive changed the ARCH variable to powerpc my kernal won't compile anymore.Im being asked for step by step y/n questions on what to include, and errors such as the following:
include/linux/elf.h:30: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘Elf64_Off’
include/linux/elf.h:31: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘Elf64_Sword’
include/linux/elf.h:32: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘Elf64_Word’
include/linux/elf.h:33: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘Elf64_Xword’
include/linux/elf.h:34: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘Elf64_Sxword’
include/linux/elf.h:128: error: expected specifier-qualifier-list before ‘Elf32_Sword’
include/linux/elf.h:136: error: expected specifier-qualifier-list before ‘Elf64_Sxword’
include/linux/elf.h:151: error: expected specifier-qualifier-list before ‘Elf32_Addr’
include/linux/elf.h:156: error: expected specifier-qualifier-list before ‘Elf64_Addr’
include/linux/elf.h:161: error: expected specifier-qualifier-list before ‘Elf32_Addr’
include/linux/elf.h:167: error: expected specifier-qualifier-list before ‘Elf64_Addr’
Is there a newer version of the workbook available?
linnj
-- John
jonesyx
Thanks John,
Im going to have a look at that kernel, your help on this and my other thread is greatly appreciated.
Michael
ccdoss
I know this topic has been described as closed, but I followed the instructions on xilinx.wikidot.com, as well as followed the format in this thread, and am unable to compile my helloworld driver. Here's my setup:
in main directory:
  1. hwmodule.c:
MODULE_LICENSE("Dual BSD/GPL");
printk(KERN_ALERT "Hello, world\n");
return 0;
printk(KERN_ALERT "Goodbye, cruel world\n");
2. Makefile:
obj-m := hwmodule.o
KDIR=~/xlinux
all:
   make ARCH=powerpc CROSS_COMPILE=powerpc-linux-uclibc- -C $(KDIR) M=$(PWD) modules
clean:
   make ARCH=powerpc CROSS_COMPILE=powerpc-linux-uclibc- -C $(KDIR) M=$(PWD) clean
The xlinux directory contains the git download of the Xilinx kernel. I have successfully built the kernel.
When I type make in the home directory, I get "Nothing to be done for 'all'"
What am I doing wrong?
ccdoss
For some reason, when I typed
make ARCH=powerpc CROSS_COMPILE=ppc_4xx- -C xlinux M=/home/christopher modules
it compiled it. So, I guess it's a problem with the makefile?
