Unable to configure spi to 5.5Mhz freq and how to avoid interbyte delay transfers in Linux version 4.9.0-xilinx-apf-g73402c0-dirty
Dear Xilinx experts,
I am facing lots of issues with spi driver in linux kernel version 4.9.0-xilinx-apf-g73402c0-dirty, could anybody please me, as I am stuck up with another issue, as all my development activites is going on 4.9.0 kernel, now i cant switch to any older kernel versions
After switching cpu freq to 333Mhz and having 0x00003F03 in 0xF8000158 spi transfers works fine with QSPI disabled in 4.9.0
But I want spi setup to be working with 5.5 Mhz without any interbyte delays, I even checked that the below registers output seems to be 0 for interbyte delays
devmem 0xE0006018
0x00000000
1. I am unable to get spi working with 5.5 clock freq, I check the spi_ref_clk_control register
devmem 0xF8000158
0x00003F03
devmem 0xF8000158 32 0x00000603 --> to achieve 5.5Mhz, am seeing the timeout issues,
Whereas I dont these issue in 4.6.0 kernel
2. I see interbyte delays between spi transfers as attached, even i dont these issue in 4.6.0 kernel
Could you please help me is there any workaround for the above two issues in 4.9.0 kernel?? am wandering that I would really get a fix for the above 2 issues,
Could anybody please take this as high priority in fixing this spi driver issues in 4.9.0 kernel, as many people in this forum are facing the same issue?
Kindly do the needful as early as possible
Eagerly awaiting for your replies
Many Thanks in advance
Re: Unable to configure spi to 5.5Mhz freq and how to avoid interbyte delay transfers in Linux version 4.9.0-xilinx-apf-g73402c0-dirty
I think the proper way to change SPI settings is through the device tree and/or ioctl calls in your software application. I would avoid to talk directly to the hardware.
my I/O PLL clock is 166Mhz, I have managed to achieve 5.2MHz for my SPI_clock changing the max frequency in the device tree
&spi0 {
      is-decoded-cs = <0>;
      num-cs = <1>;
      status = "okay";
      bus-num = <0>;
      spidev0@0 {
        compatible="spidev";
        reg = <0>; //chipselect
        //spi-max-frequency= <1660000>; //old_frequency
        spi-max-frequency= <6640000>; //new_frerquency
        spi-cpha;
        bus-num = <0>;
Rocco
May I know have u validated in 4.9.0 linux kernel version? , if so could u pls share me the system_top.bit, .vhd, .xdc and .vhd and fsbl
