Visitor axmei
Unable to download dt_overaly.tcl
Re: Unable to download dt_overaly.tcl
The file is seen below:
set hdf <path to your hdf file>.hdf
set hw [hsi::open_hw_design $hdf]
hsi::set_repo_path ./repo
hsi::create_sw_design sw1 -proc psu_cortexa53_0 -os device_tree
hsi::set_property CONFIG.dt_overlay true [hsi::get_os]
hsi::generate_bsp -dir dtg_out
hsi::close_hw_design $hw
You can add this to a TCL, and source from XSCT.
I also have attached a helper_proc.tcl that you can use to create the pl.dtbo, and the bit.bin file needed when using overlays.
Source this in XSCT, and use the procs below to create the proc below:
  • generate_dts <path to hdf>.hdf
    bit2bin <path to bit>.bit
Hi @axmei,
I tested it and it is working for me. Can you try again? Maybe right click on the link and click save link as.
Florent
The link does not work for me either..  Might it be some premissions about being inside xilinx and outside ?  (is it published to the world)
