Participant coreyhahn
Unable to program PL from Petalinux via FPGA Manager
Running petalinux 2018.2
Ran through this how to.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841847/Solution+ZynqMP+PL+Programming
With the exception of no FPGA Manager in petalinux-config everything was ok.
When i boot into the resulting images I get the following error when attempting to load bin file from that Vivado created.
root@test02:~# echo /lib/firmware/test02_wrapper.bin > /sys/class/fpga_manager/fpga0/firmware
[ 2112.016472] fpga_manager fpga0: writing /lib/firmware/test02_wrapper.bin to Xilinx ZynqMP FPGA Manager
[ 2112.025911] fpga_manager fpga0: Direct firmware load for /lib/firmware/test02_wrapper.bin failed with error -2
[ 2112.036037] fpga_manager fpga0: Error requesting firmware /lib/firmware/test02_wrapper.bin
-sh: echo: write error: No such file or directory
I cannot find a reference to the error "-2". What can i try next?
Observer timor.knudsen
Re: Unable to program PL from Petalinux via FPGA Manager
Make sure the test02_wrapper.bin exists in /lib/firmware.
Then do not specify the path but only the filename when "echo" to the fpga_manager:
echo test02_wrapper.bin > /sys/class/fpga_manager/fpga0/firmware
Should work.
That did solve that error.  Thank you!
A new error immediately popped up.
root@test20181217:/media/card/coreydevdir# echo test1_wrapper.bin > /sys/class/fpga_manager/fpga0/firmware
[20892.164512] fpga_manager fpga0: writing test1_wrapper.bin to Xilinx ZynqMP FPGA Manager
Crypto flags not matched with Image crypto operation
[20892.193289] fpga_manager fpga0: Error while writing image data to FPGA
-sh: echo: write error: Invalid argument
I am not doing, nor have touched any crypto settings.
Edit:  Seems to have to do with compressing the bit/bin file. No compression fixes this.
Now on to my third error.
[ 77.653958] fpga_manager fpga0: writing test1_wrapper.bin to Xilinx ZynqMP FPGA Manager
FPGA fail to get the done status
[ 77.791600] fpga_manager fpga0: Error while writing image data to FPGA
Observer gosha-z
Are you definitely need to load bitstream through FPGA Manager? Why not to let U-Boot load it from FIT bundle?
I do both.  It should be possible to do both.  Trying to understand the limitations before I need it work.
